What's the best way to launch at the track? - Honda Accord Forum : V6 Performance Accord Forums
Old March 15th, 2009, 08:59 AM   #1
Honda Tech
Matt04V6EX's Avatar
Well it's coming to be that time of year again. track time Now as I've posted in a previous thread I've owned two Camaros and this accord and never have been to the track. Idk what is wrong with me but I think this year and this car will pop my virgin track cherry. (Also because a lot of people think our cars are slower than they really are) Now I just have an intake and exhaust and a 6 Speed and some new tires. Now I was jw what the best way to launch our cars was i. e. RPMs? Dumping the clutch or gradually letting out and flooring it? TCS on or off? Do's and Don'ts? Any ideas would be greatly appreciated!
P.S. Now I talked to someone last year with the same kind of Accord as me and he say he ran 14.1 w/ intake and exhaust. Now my friend threw the but is this feasible? And what numbers should i expect to see at the track? I am on the GB for the ETD so how would affect the times? If at all?
Old March 15th, 2009, 12:06 PM   #2
SSM_AV6-6
NHB_AV6-6's Avatar
The other thread you posted in has an I/JP/TP 6 speed running a 14.0... honestly, the performance bolt-ons probably don't help us out quite as much as traction mods will. In stock form, I believe the car has enough power to at least reach a 14.0. It will take a perfect launch to get that though, but I think with decent tires, mounts etc. the car can do that stock.
as for launching your car... looks like Sonnick and I pretty much launch the same, with inconsistent but decent results. Basically, just rev it up to maybe 2000 and then slip the clutch just like you would pulling away from a stop sign... do NOT dump the clutch, wheelhop city will result. Believe it or not our torqueless Hondas have enough low end to take off from the tree with minimal or no real wheelspin/clutch riding and still get a 2.2 60 ft with everything stock down to the tires.
Old March 16th, 2009, 12:29 AM   #3
frumaroll
six6's Avatar
is it just my motormounts or my suspension, or does everyone have wheelhop so bad that it seems like you'll break and axel and that it leaves like 6 inch skips on ur skid mark
Old March 16th, 2009, 11:06 AM   #4
Wheelgap = sleeper mod
mbr311's Avatar
Yea, wheelhop is pretty bad in first gear. I have ****ty Yokohama YK520s and on the street in mild weather if I leave traction control on I slip the clutch at about 3500rpms and that seems to work well. With TCS off, it's a gamble if I'll ever hook up in first gear.
never been to the track so I can't comment. What kind of tires do you have? if you have some stickies, you can launch higher. And BTW, wouldn't dump the clutch for a number of reason, one being you could grenade the tranny.
Old March 16th, 2009, 10:55 PM   #5
SSM_AV6-6
NHB_AV6-6's Avatar
I think it's a combination of both. The more I learn about these cars, the more I realize it's just a pedestrian Honda with a powerful engine in it and minor details to attract performance-oriented drivers... like the strut bar and the bigger brakes that always warp.
Old March 16th, 2009, 11:29 PM   #6
Honda Tech
Matt04V6EX's Avatar
thats why i got drilled and slotted rotors i have sumitomos htr+ i think 215/50/17 on stock rims i wanna go to the track this summer ... i hope the ETD helps
Old March 17th, 2009, 03:02 AM   #7
ahhhz's Avatar
taking off TCS is a must! gotta play that fine line between grip and slip... i got basically stock tires + wheels with sc and i can still make first gear grip... it's second gear i gotta feather the throttle to control
ahhhz is offline   Reply With Quote Quick reply to this message
Old March 17th, 2009, 08:39 AM   #8
mbr311's Avatar
Why do you have stock tires with that much power? I can barely hook with ~215whp and you make close to 300whp IIRC
Old March 17th, 2009, 03:21 PM   #9
ahhhz's Avatar
do you know how much it costs to install SC?? stock tires will work for now
Old March 17th, 2009, 03:24 PM   #10
Honda Tech
Matt04V6EX's Avatar
NONE ... if you do it yourself haha
Old March 17th, 2009, 04:42 PM   #11
mbr311's Avatar
Just figured if you had that much loot to drop on a SC and install, what's another few hundred so you can hook up? J/P
Old March 17th, 2009, 05:17 PM   #12
tuckin
coupeblack's Avatar
we have traction control?
coupeblack is offline   Reply With Quote Quick reply to this message
Old March 17th, 2009, 06:33 PM   #13
ahhhz's Avatar
^^yes the secret button left of the steering wheel... press at own risk!
the instant i realized i could afford SC i went for it. all those other things will come into place eventually,
like: fuel pump, tein ss, wheels/tires, pro-cats, clutch, as we know, the list goes on like an eight on its side.
slotted rotors/braided lines/super blue fluid/pads this week because stopping her now is slightly sketchy...
Old March 18th, 2009, 07:59 AM   #14
mbr311's Avatar
wat? You've never noticed the bright orange exlamation point in a triangle showing up on your dash when you lose traction? lulz...
Old March 18th, 2009, 08:14 AM   #15
frumaroll
six6's Avatar
lmao
Old March 18th, 2009, 10:42 AM   #16
346hp/300tq @ 4psi
04accordcpe's Avatar
dumping the clutch is fine. just dont do it at a real high rpm.
Matt, if your serious about getting some good 60 ft's and E/T's at the track, buying some DR's (BFG's, nitto etc,..) is a must IMO. heat em up for about 6-8 seconds, keep the gas steady at around 3.5rpm and dump it. then when you feel them grip, WOT
this is the method i used to achieve my 2.0 60 fts this way. just to compare, the same day at the track a 2.0 to a 2.2 60ft cost me .5 in the E/T.
you have to address other things like, suspension, motor mounts, and other key components that is going to tame that nasty wheel hop, which kills your tranny and axles.
Old March 18th, 2009, 10:54 AM   #17
mbr311's Avatar
I just refuse to dump my clutch. To each his own. 1st gear is the hardest on the car and dumping the clutch can grenade your tranny if you don't know what you're doing. I just hold at 3500rpms and slip. it's not a prolonged slip, so maybe you and I just have different definitions of what "dump" means
Also, I'm asking this to gain knowledge, not to question you - but can our axles hold up to using DR's and dumping the clutch off the line? Or do we need to do some upgrading as you suggested in the last line of your post.
Old March 18th, 2009, 11:21 AM   #18
346hp/300tq @ 4psi
i estimate around 90-100 hard, clutch-dumping launches and never broke a tranny or my oem accord axles. like i said, what ever style you use in terms to launching your car, wheel hop will ALWAYS be your nemesis.
04-06 TL-s axles is a good OEM upgrade. beefier shafts and splines than the accord units. need to change the half shaft too i found that out the hard way
Old March 18th, 2009, 11:42 AM   #19
04simple_accord's Avatar
^ how much do tl-s axles go for roughly?
04simple_accord is offline   Reply With Quote Quick reply to this message
Old March 18th, 2009, 12:19 PM   #20
346hp/300tq @ 4psi
just picked up some brand spanking new ones from acura of peoria for 352.00 shipped.
half shaft can be had a junkyard for 75 or so, if not that a new one is 195
Old March 18th, 2009, 12:43 PM   #21
J35A2K23B18CSRDETT2JZLOL
SIRSIG's Avatar
this is how I do my launch...
http://www.youtube.com/watch?v=rRZG3...e=channel_page
I guess it's all depends on what you have under the hood, right mix of power and timing will give you good time
SIRSIG is offline   Reply With Quote Quick reply to this message
Old March 18th, 2009, 01:39 PM   #22
Super Mod
aprevo15's Avatar
do you guys power shift?
Old March 18th, 2009, 06:27 PM   #23
tuckin
coupeblack's Avatar
haha no can we turn it on and off???
God i feel like such a nooooobb
Old March 18th, 2009, 06:33 PM   #24
tuckin
coupeblack's Avatar
i just looked and there is no button nor exclamation point, am i alone? i have an 03 btw
im pretty sure i4s like mine and being an o3 dont have tc
Old March 18th, 2009, 09:14 PM   #25
SSM_AV6-6
NHB_AV6-6's Avatar
I don't think this would be a good thing to do. #1. you shouldn't have a reason to do this unless you have a nice big turbo that will take a little bit to spool up during a regular shift, and #2. Honda synchros aren't the most durable in the world. Almost every 10+ year old Honda I've owned had 2nd and 3rd gear synchros that were bad.
Old March 18th, 2009, 09:46 PM   #26
Stevo405's Avatar
What DR's do you have experience with?
Stevo405 is offline   Reply With Quote Quick reply to this message
Old March 19th, 2009, 06:39 AM   #27
Archangel72's Avatar
Your better off going with Richies pre-cat deletes than the pro-cats if you have a sc.
Old March 19th, 2009, 08:09 AM   #28
Honda Tech
Matt04V6EX's Avatar
do you have ABS? you cant have T/C w/o ABS
(same goes with stability control (which we do not have) cant have stability control w/o T/C)
Old March 19th, 2009, 08:39 AM   #29
mbr311's Avatar
Oh I didn't know you had the 4 cylinder. Don't know
