2008 TL-S cams vs 2008 RL cams Differences? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree5Likes
Old April 16th, 2009, 10:22 AM   #1
TrakCord
AccordingLO's Avatar
Hey just wondering if anyone has tried the 2008 Acura RL camshaft swap into their 2003 and up J-engine compared to the 2008 TL Type S camshafts? What are the differences with them if any besides price such as low cam lift & duration; high cam lift & duration?
Thanks
AccordingLO is offline   Reply With Quote Quick reply to this message
Old April 16th, 2009, 10:39 AM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
I might be wrong, but the TL and RL use the same engine, different transmission.
Old April 16th, 2009, 10:49 AM   #3
TrakCord
well i have checked the part numbers for the 2008 RL and it is different from the 2008 TL Type S..that is why i was wondering.
Old April 16th, 2009, 12:28 PM   #4
Sonnick's Avatar
I think the RL cams have a slightly higher lift on the exhaust side but the TL-s cams are hollow and therefore, lighter. They talked about it over @ Acurazine. Supposedly Paul was saying the new 09 TL-s cams have .4mm higher lift than the 08s. That's all I know
Old April 17th, 2009, 08:55 AM   #5
TrakCord
i do remember the 07-08 TL-S cams are hollow.. i think that the 09 TL-S has vtec on the intake and exhaust sides so it would not be compatible with the j30a4 heads
Old April 17th, 2009, 10:35 AM   #6
M90SC Boosting 13PSI
NVA-AV6's Avatar
The 09 cams are for a VCM engine and have completely different lobe arrangement and will not work and a 7th gen...
Old April 17th, 2009, 11:15 AM   #7
Archangel72's Avatar
Paul, I know this has been answered, but then what are the major differences besides being hollow between the RL and TL-S cams that fit the 7th gen?
Old April 17th, 2009, 12:38 PM   #8
TrakCord
I have done additional research and confirmed the RL camshafts have 5 degrees more duration than the 07-08 TL Type S camshafts...I still do not know if the RL camshafts are hollow as well.....
I can imagine how great it would be to have hollow RL cams!!!
However i am looking for comparative specs between The 07-08 Type S cams and the 2006+ RL cams.
(I checked various sites the 08+ v6 6 speed accords have the same part number for the camshafts as the 07-08 TL Type S for half the price??!!!)
Old April 17th, 2009, 01:03 PM   #9
Thats great, although I know the cams are not hollow. Wonder how much of a difference they would make.
Jrow89 likes this.
Old April 17th, 2009, 01:07 PM   #10
TrakCord
I would like to know the gains of the hollow TL-S cams vs the gains from the RL cams maybe the lightweight hollow camshafts will give smoother, free revving, more usable powerband and may be more effective than the minimal gain of the RL cams....(Ouch my brain is burning! lol)
Old April 20th, 2009, 07:21 PM   #11
Boomdiada
Swift's Avatar
Send a message via AIM to Swift
I am sure you could just hollow them out, but then again there is a reason they didn't do it in the first place.
Swift is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2009, 06:03 PM   #12
TrakCord
bump
Old April 29th, 2009, 03:18 PM   #13
sinfulj32's Avatar
does anyone know if the 08 tl-s or rl heads can mate to j32a3 or 7th gen accord block?
sinfulj32 is offline   Reply With Quote Quick reply to this message
Old April 30th, 2009, 03:48 PM   #14
TrakCord
i believe the 08 Tl-S heads are indentical casting to the accords..correct me if im wrong..However im not sure of the RL heads
Goin back to the Track!
Old May 3rd, 2009, 01:09 PM   #15
sinfulj32's Avatar
tl-s
1 14100-RDB-A00 CAMSHAFT, FR. 1 2007 TL 191.95 143.96
2 14200-RDB-A00 CAMSHAFT, RR. 1 2007 TL 191.95 143.96
08+ v6 6 spd accord
14100-R72-A00 2 CAMSHAFT, FR. USA 1 $ 107.85 $ 78.95
14200-R72-A00 4 CAMSHAFT, RR. USA 1 $ 107.85 $ 78.95
these are clearly different. now, does anybody know the specs of the 08+ v6 6 spd accord cams?
Old May 4th, 2009, 08:39 PM   #16
sinfulj32's Avatar
or does anyone know if 09 tl cams are possible?
Old May 5th, 2009, 12:57 PM   #17
TrakCord
tl-s
08+ v6 6 spd accord
i believe the different letters you are referring to are the chassis codes...
Old May 5th, 2009, 12:59 PM   #18
TrakCord
doubt it because the new 3.7L engines have VTEC on intake and exhaust
Old May 5th, 2009, 11:55 PM   #19
sinfulj32's Avatar
ahh, my bad.
i see, i didnt know it was dual cam.
Old May 17th, 2009, 10:34 AM   #20
Banned
You should hit up P2R, they can make you some better cams than either of these to increase ur potential
cls6speednupe is offline   Reply With Quote Quick reply to this message
Old May 17th, 2009, 11:57 AM   #21
sinfulj32's Avatar
^anyone ever get a quote for p2r cams?
Old May 17th, 2009, 12:21 PM   #22
Banned
They would be custom made to fit whatever your trying to do so the price would be based on your personal neeed.
Old June 9th, 2009, 12:02 AM   #23
NSX dreamer
Artistotle's Avatar
ahh, my bad.
it's not dual cam you noob. its SOHC. 2 cylinder heads= 2 cams total. just like all other J engines.
its like you didnt read anything in the thread. NVA-AV6 clearly said that the 09 TL uses an VCM engine (like the 08+ accords) and as such its cams are NOT compatible.
My 2013 For sale thread:
Artistotle is offline   Reply With Quote Quick reply to this message
Old June 26th, 2009, 09:52 AM   #24
newbies here!
MickAv6's Avatar
Accord 08 6 speeds don't have VCM !! automatic have VCM
MickAv6 is offline   Reply With Quote Quick reply to this message
Old June 27th, 2009, 02:27 PM   #25
hello everybody i am new to the form and i have to post 10 thing before i can start a thread so i just wanted to say wats up everybody.i am a member of acurazine and yes i have an acura tl but when you guys see my pic it does not look like one.i joined this form bc az kind off sucks and everybody is always bashing other peoples stuff so i hope you guys dont.
hendrick honda, charlotte, justin, 704 746 8429
2004 mugen tl
aem v2 cai
intake plentom spacer
ported and polished intake runners
pre cat delets
j pipe
tl type s cat back
ur under drive pully
coolant bye pass modification
samco racing coolant hoses
260 fwhp
oooooooo and a bad trans
JS_MUGEN_TL is offline   Reply With Quote Quick reply to this message
Old June 29th, 2009, 11:13 AM   #26
Camshaft-timing belt
04 tl to 06 tl autos and 6 speeds 07 tl to 08 tl auto
1 14100-rca-a10 camshaft, fr.
2 14200-rca-a10 camshaft, rr.
07 tls 6 speed 08 tls 6 speed
1 14100-rdb-a00 camshaft, fr.
2 14200-rdb-a00 camshaft, rr.
01 mdx 02 mdx
1 14100-p8e-l00 camshaft, fr.
2 14200-p8e-l00 camshaft, rr.
Camshaft-timing belt same as 04 to 08 tl autos 04 to 06 tl 6 speeds
03 mdx 04 mdx 05 mdx 06 mdx
07 mdx 08 mdx 09 mdx
1 14100-rye-a00 camshaft, fr.
2 14200-rye-a01 camshaft, rr.
05 rl
1 14100-rja-000 camshaft, fr.
2 14200-rja-000 camshaft, rr.
06 rl 07 rl 08 rl
1 14100-rja-j00 camshaft, fr.
2 14200-rja-j00 camshaft, rr.
09 rl
15 14100-rkg-010 camshaft, fr.
16 14200-rkg-010 camshaft, rr.
Old June 29th, 2009, 11:14 AM   #27
i have been doin lots off reaseach lately for the acura modals and i guess i will be doing some for honda now since i love this form so much more that acurazine
3.0UALLKNOW likes this.
Old July 3rd, 2009, 05:53 AM   #28
01 mdx 02 mdx
05 rl
06 rl 07 rl 08 rl
09 rl
2004 mugen tl
aem v2 cai
pre cat delets
j pipe
tl type s cat back
260 fwhp
What is all this garbage?
adamlee05 is offline   Reply With Quote Quick reply to this message
Old April 12th, 2011, 10:15 PM   #29
Bump, what is new with the cams now days. What is the best?
DCdonDubby is offline   Reply With Quote Quick reply to this message
Old April 13th, 2011, 12:46 AM   #30
got LSD J36TT??
tenzingsherpa's Avatar
^custom bishimito cams. bishimito regrind cams are good too but not near as reliable as custom.
LSD 6-SPEED,Forged & Sleeved J36 MOTOR
(SNAILS ARE IN!!!, Smalser TWIN TURBO build UNDERWAY)
Like me at--->
Sponsors:
Mishimoto
Power Rev Racing
Racinx.com
Airtekk
Advanced Keys
tenzingsherpa is offline   Reply With Quote Quick reply to this message
