Ingalls ETD weird sound...advice - Honda Accord Forum : V6 Performance Accord Forums
Old April 20th, 2009, 02:14 PM   #1
Senior Member
eugene3524's Avatar
Send a message via AIM to eugene3524 Send a message via MSN to eugene3524
Hi, got my etd in today from the groupbuy and in order to install it on my 4cyl i had to adjust it to the shortest possible setting
after i got it in and started it i could already hear the bug difference in the way the engine sounds and when started driving i can constantly hear that sound...when i let it run and opened the hood its almost a faint knocking noise....is this the vibration people talk about or is this something else?
i didnt mess with the dampness setting at all..is it possible to adjust that to weaker setting to make it less stiff or something..even though i thought they come in weakest settin already
btw didnt really see any difference at all with it on....
/? any ideas?
eugene3524 is offline   Reply With Quote Quick reply to this message
Old April 20th, 2009, 03:21 PM   #2
Senior Member
eugene3524's Avatar
bought a smaller hex nut, gonna try to put it on becuase its slimmer..maybe that way it wont be pressed against one of the chassis?
Old April 20th, 2009, 03:47 PM   #3
Senior Member
eugene3524's Avatar
MODS DELETE THREAD!
IDK how safe it was but after i bought a slimmer stop hex screw which made it not be pressed against one of the loops it changed EVERYTHING..slight cabin noice at some point..shifting ALOT smoother
great product
Old April 20th, 2009, 04:18 PM   #4
what did you change?? I don get it circle it. It will probably help other pple with this problem also.
Old April 20th, 2009, 04:41 PM   #5
Carpe Diem
ikethegreat's Avatar
Can you be a little more specific on what you mean by "slight cabin noise at some point"? Thanks.
Old April 20th, 2009, 04:49 PM   #6
Senior Member
eugene3524's Avatar
ok, i actually took out the real camera so you can see some stuff unlike the crappy backberry pic above...i replaced the hex screw with a thinner one ..it cost me $.42..decreased pretty much all of my weird noise the only noise im heaving now is at start up and when i have all music off and then from time to time while driving if complete silence in my car,,,with usual driving and music up i cant hear or feeling anything except smoother shifting and engine feels as if its always ready to obey..idk how to explain..idk i guess you can say less lag? ..if i had up close pics before you would see how the bolt was really tight with the chassy loop thing well here are pics:
btw its a 10m 1.5 size hex
Old April 21st, 2009, 02:03 AM   #7
very sexy man. I think I might want to order the TSX one so I can keep my bar again. The TSX only had 2 hole to mount them vs the accord 4 hole. iono why it just does
Old April 21st, 2009, 07:31 AM   #8
Senior Member
eugene3524's Avatar
whatever works hahahas even though i think it was already proven that this isnt in a way of the strut bar..check the group buy thread
Old April 21st, 2009, 11:19 AM   #9
my strut bar uses the last 2 screws on the left. it looks like the cusco bar that TSX have.
Old April 21st, 2009, 12:34 PM   #10
Senior Member
eugene3524's Avatar
ooo ok i thought u had a stock v6 6speed one
Old April 22nd, 2009, 11:20 PM   #11
Full time worker/student
is that thinner hex really necessary? i just got mine in today.
also did u install it urself bc i notice it had torque specs in the instructions so...
FoXD!e is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2009, 11:31 PM   #12
Senior Member
eugene3524's Avatar
It was for me becuase when you get to the step when you have to screw on the etd itself you have to adjust length and for me I had to make it shortest possible causing the hex to be in very tight contact with the loop causing extra noise on top of regular noise you get from this
I installed it myself. Had to go thru the manual very closely. It isn't hard to install really and I think that the tourqe specs are most likely just an extra precaution by ingalls to back themselves up...I just tightened it as I would anything else
Old April 23rd, 2009, 06:34 AM   #13
shortest possible? i think the shortest u can go is 10. any lower and it'll cause premature wear on the etd.
thanks for the info. i think i'm gonna try to get it installed by a shop first. it shouldn't cost that much. if it does i'll do it myself.
Old April 23rd, 2009, 06:47 AM   #14
Senior Member
eugene3524's Avatar
I'm talking about shortest possible while it still being right. You etd overall length is changeable so that it can fit other cars
Old April 23rd, 2009, 11:12 AM   #15
Eugene i sent u a PM.
Old April 23rd, 2009, 11:30 AM   #16
damn it paul call me at like 8am in the morning. Just do it urself. It takes like 30mins
Old April 25th, 2009, 01:55 AM   #17
i just got done finishing with the install. pretty much the volume of the sound u hear is louder. i hear my intake hissing now when i drive and the exhaust.
the nose doesn't lift up as much as it used to when i take off.
i don't know about acceleration gains. i'll give it a week.
Old May 4th, 2009, 09:48 AM   #18
Supercharged 07AV6
7thgencordcoupe's Avatar
7thgencordcoupe is offline   Reply With Quote Quick reply to this message
Old May 4th, 2009, 09:49 AM   #19
Supercharged 07AV6
Old May 4th, 2009, 09:50 AM   #20
Supercharged 07AV6
.... Just getting 10 posts to post a thread sorry
