Motor mounts and dampers - Honda Accord Forum : V6 Performance Accord Forums
Old May 12th, 2009, 07:46 PM   #1
J36 6sp w/ LSD
pigpig000's Avatar
Send a message via MSN to pigpig000 Send a message via Skype™ to pigpig000
Smile Motor mounts and dampers
The following mounts and dampers have been installed:
Innovative motor mounts
Ingalls Engine Torque Damper
CL-S Front Dampener
TL-S Rear Dampeners
TL-S Tranny Mount
Look at the engine movement during the dyno, the engine barely moves at the cut-off
&mpt=[CACHEBUSTER]">
pigpig000 is offline   Reply With Quote Quick reply to this message
Old May 12th, 2009, 07:48 PM   #2
Super Mod
aprevo15's Avatar
so what did you dyno?
Old May 12th, 2009, 08:07 PM   #3
very nice.
Old May 12th, 2009, 08:38 PM   #4
SSM_AV6-6
NHB_AV6-6's Avatar
That is very impressive. I must have my ETD on the softest setting or something, because, even though actual traction has increased, it still allows bad wheelhop if I launch around 2500 or higher.
Get this thing to the track; we at least want to see what this beast will trap. And the dyno numbers would be nice
Old May 12th, 2009, 08:41 PM   #5
cunning linguist
MorePower4me's Avatar
Seriously...
#'s please
-Brian-
07 V6 Auto Sedan-> 10 CR-V
Mod'd Z06 - Sold for move
Old May 12th, 2009, 08:43 PM   #6
J36 6sp w/ LSD
pigpig000's Avatar
^actually my ETD doesn't do anything....would say 95% is from the TL-S and CL-S dampener
Old May 12th, 2009, 08:56 PM   #7
SSM_AV6-6
NHB_AV6-6's Avatar
The weird thing is, with just the right side Innovative mount on, my car doesn't get **** for traction, but has no wheel hop at the track. but with the ETD coupled with that Innovative mount, traction is impressive but now wheelhop is back
All this crap has me seriously thinking about just parting out my car and putting it back to stock to become a fun daily driver.
Old May 12th, 2009, 09:47 PM   #8
Senior Member
nicepeta's Avatar
its in his album
is it J36? if so... why only 210whp/233wtq???
nicepeta is offline   Reply With Quote Quick reply to this message
Old May 12th, 2009, 10:11 PM   #9
Adventure is out there!
littletruong's Avatar
so those are the innovative mounts and the tls tranny mount?
dam should of read LOL scratch that question!
very nice! i've never seen my engine bay not move like that.
Old May 12th, 2009, 10:12 PM   #10
SSM_AV6-6
NHB_AV6-6's Avatar
Something is wrong; it looks like the torque curve drops off at about the VTEC conversion point. And IIRC his car put out close to 275 whp initially.
Old May 12th, 2009, 10:45 PM   #11
Honda Rookie
pbook4g5's Avatar
That is totally awesome. Is this car down with Paul at the moment?
“Success is 99 percent failure.”
- Soichiro Honda
Old May 12th, 2009, 10:54 PM   #12
J36 6sp w/ LSD
pigpig000's Avatar
Originally Posted by nicepeta View Post
its in his album
yes, that is because i had vtech problem, the vtech didn't kick on.....Paul and I are trying to figure out what's the problem, it maybe the settings in the FIC, at least we found the rpm was not calibrated right when I did the dyno
Old May 12th, 2009, 11:00 PM   #13
J36 6sp w/ LSD
pigpig000's Avatar
No, the car is with me at the moment.
Old May 12th, 2009, 11:01 PM   #14
Honda Rookie
pbook4g5's Avatar
Oh damn,I was hoping to see it this weekend.... looks great!
- Soichiro Honda
Old May 12th, 2009, 11:05 PM   #15
Sorry for a noob question but where do these go and how hard is it to put on? CL-S Front Dampener, TL-S Rear Dampeners, TL-S Tranny Mount.
Thanks
Old May 12th, 2009, 11:15 PM   #16
J36 6sp w/ LSD
pigpig000's Avatar
Thanks
Old May 13th, 2009, 04:53 AM   #17
M90SC Boosting 13PSI
NVA-AV6's Avatar
Thanks
TL-S tranny mount won't work with your AT
Old May 13th, 2009, 07:00 AM   #18
Carpe Diem
ikethegreat's Avatar
Ouch @ those numbers. Hope you can get her running right soon.
Old May 13th, 2009, 08:31 AM   #19
cunning linguist
Hows the noise/ride with all that?
Is the TL-S/CL-S stuff making the mount noises/rattles any worse?
-Brian-
Old May 13th, 2009, 09:15 AM   #20
J36 6sp w/ LSD
pigpig000's Avatar
The noise only appears when the car is cold and will disappear after a few miles of driving, it may be the starter got stuck.
The TL-S/CL-S stuff suppose to damp all the noises and rattles, it can't make it worse~~~
Old May 13th, 2009, 12:14 PM   #21
Stevo405's Avatar
My rpms werent calibrated either. Theother day i was getting into her a little bit and she fell on her face. I hooked up the laptop to see what was going on and saw the rpms were at about 500 less than what they were supposed to be. I set them correctly and it didnt happen again, but i had to shut down because the AFR's were getting too rich
Stevo405 is offline   Reply With Quote Quick reply to this message
Old May 13th, 2009, 12:44 PM   #22
J36 6sp w/ LSD
pigpig000's Avatar
^I just found out that the FIC doesn't hold the calibration after I restart the car. And the rpm doesn't have a linear offset,it is a variable offset. For me, it reads 550rpm at idle and only 2500rpm at 4000rpm, that was why the vtech didn't hit when I did the dyno~~~
Old May 13th, 2009, 01:36 PM   #23
Stevo405's Avatar
Mine was ab0ut the same.. But my calibrati0n d0esnt reset.. I will l00k at it again this aftern00n and check. H0w is yur car running n0w?
Old May 13th, 2009, 01:56 PM   #24
NVA-AV6's Avatar
I just got off the phone with AEM this morning about this issue, what they are suggesting is that there is noise on the signal line causing random pulses which is throwing off the RPM reading, they are suggesting to add some 2K-2.2K ohm resistors to the Cam and Crank signal lines to pull noise out. It sounds reasonable to me, this Friday I will be purchaseing a osciliscope (been needing to for a while, just the $$$$), to investigate this further.
Old May 13th, 2009, 01:58 PM   #25
J36 6sp w/ LSD
pigpig000's Avatar
^do you need some screen shot......I have the osciliscope at my apt
Old May 13th, 2009, 02:01 PM   #26
NVA-AV6's Avatar
I really need one here to work with, it will be painful, but needs to be gotten.
Old May 13th, 2009, 02:23 PM   #27
J36 6sp w/ LSD
pigpig000's Avatar
are you sure you by adding resistors can pull the noise out.....normally we add caps.....
Old May 13th, 2009, 03:12 PM   #28
NVA-AV6's Avatar
We are trying to force the signal to ground to prevent spiking
Old May 13th, 2009, 03:21 PM   #29
J36 6sp w/ LSD
pigpig000's Avatar
^ but that would also cause leakage problem though
Old May 13th, 2009, 04:29 PM   #30
346hp/300tq @ 4psi
04accordcpe's Avatar
Nice, but since you have innovative mounts, any type of dampers after that is overkill IMO. Maybe just the tls granny mount and that it
