Ported & Polished... - Honda Accord Forum : V6 Performance Accord Forums
Old June 10th, 2009, 04:35 PM   #1
Supercharged 07AV6
7thgencordcoupe's Avatar
This week I am going to be installing my Ported & Polished lower intake runners, upper Manifold, Bored throttle body, and Thermal gaskets in addition to my outlaw spacer kit. What do you think I can look forward to in regards to gains from these additional mods?
7thgencordcoupe is offline   Reply With Quote Quick reply to this message
Old June 10th, 2009, 04:37 PM   #2
03Accord EX-L's Avatar
Where do you get your stuff port and polished at?
03Accord EX-L is offline   Reply With Quote Quick reply to this message
Old June 10th, 2009, 04:42 PM   #3
Supercharged 07AV6
I didn't want to say because i see there are some people who i guess promote them on the forum, but P2R. I am not a promoter, I don't get discounts just stating where i got it done.
Old June 10th, 2009, 04:44 PM   #4
hmmm what next?
shonda1989's Avatar
maybe 10 HP i am guessing. what would really help our engines would be one long runner for low end and one short runner for top end but then you would have the NSX engine. (forgot what the name of that engine is)
i would say get some more cooling mods to be done on that intake manifold to start seeing gains. for every 10 degrees cooler you get 1%
Old June 10th, 2009, 04:47 PM   #5
Sonnick's Avatar
I'd say 10whp since you are auto. If you were 6MT I'd say closer to 15whp but this is good because I haven't seen anyone report any IM porting besides Kschwiggy and he did it at the same time as a lot of other stuff. Let us know!
Instagram = j30_allmotor
Old June 10th, 2009, 04:53 PM   #6
Supercharged 07AV6
Definately will keep posted. As for the cooling idk what else to do unless you have any suggestions let me know these are my current perf mods.
Sorry list is from my cardomain got some nonsense on it
Greddy Emanage Ultimate Piggy back ECU
Boomslang Custom Harnessing Kit
Engine:
Custom Wrinkle Black Ported & Polished Plenum Intake Manifold
New Ported & Polished Intake Manifold Air Runners
Bored Throttle Body
AEM V2 Cold Air Intake
Unorthodox Racing Crank Pulley (Underdrive Pulley)
Outlaw Engineering Thermoblock Spacer Kit
Griffin Custom Aluminum Radiator
Comptech Automatic Transmission Cooler
P2R Thermal TB & Intake Manifold Gaskets
RV6 Performance Pre Cat Deletes (Headers)
RV6 Performance J Pipe
Megan Racing Test Pipe
Tanabe Hyper Spec Medallion Cat back Exhaust system
Sun Automobile Type S hyper ground wiring System (smoke wiring)
Sun Automobile Hyper Gauss (fuel regulation compressor)
Sun Automobile JDM Hyper Voltage system Typer Multi Rev Range (smoke wiring)
Ingalls "Stiffy" Torque Damper Kit
Innovative Steel Engine Mounts
K&N Oil Filter
Spoon Reservoir Tank Covers
Buddy Club Racing Oil Cap (titanium)
Skunk 2 Racing Black 1.3 Comp. Radiator cap
CT Engineering Battery Tie Down
Engine Cover Painted Flat Black
Glow Shift Gauge sensor Adapters
TL Manifold Cover to Replace stock
Old June 10th, 2009, 05:13 PM   #7
wow man I didnt know you had all that done thats pretty sweet. No need to be ashamed that its P2R because from the little Ive seen of their products they are really nicely done. As long as your not saying that other peoples stuff is stupid and just insulting people like others your fine. Will love to hear what this does for you. On a side note though Ive heard that the outlawed spacer so really doesnt do much but since you had to replace the gaskets anyway why not right.
Old June 10th, 2009, 05:14 PM   #8
Sonnick's Avatar
WOW that's quite the mod list! Have you dyno'd? How are the gains? You have a significant amount of NA mods..only ones I can see you are missing are cams and higher compression. Good stuff!
Old June 10th, 2009, 05:24 PM   #9
Supercharged 07AV6
Yeah pretty much.. I wasen't ashamed I just am not looking to piss anyone off about promoting on the forums. Also I have done a significant N/A haven't dyno'd only to tune, and only had V2 and Catback. I would do cams but I mean were limited to the TL-S cams or RL I guess just i can't see doing the extensive work now for minimal gains from what I have read.
Old June 10th, 2009, 05:25 PM   #10
Supercharged 07AV6
I will be supercharging shortly which is why i am prepped minus RDX injectors at this point :0)
Old June 10th, 2009, 05:25 PM   #11
J35 6Spd
yeah i have ported intake runners and my heads are ported and polished.. however i don't have a bored TB or ported/polished IM (yet). there are noticeable gains in the sound of the engine (deep growl when the engine is under load).. increased throttle response, and smoother acceleration. i dont have dyno numbers from JUST port and polishing to offer you though.. just butt dynos.
as far as p2r goes.. they have good products and theyre doing great things for the J series engines.. it's just that a certain someone was acting inappropriate and talking like p2r was the best and only good solution out there. theres no harm in telling us where you get mod's done though
can you do a HUGE favor and snap some pictures of the port and polishing / throttle body before you install it all? it'd be great to see how the parts came out.
also, like sonnick said.. TL-S cams might be a good idea too.. and i only say that because you have the emanage ultimate and can properly tune the fuel map for the vtec portion of your rpm band. if you're going boost though.. the increased lift in the TL-S cams may not do anything for you anyway
Old June 10th, 2009, 05:26 PM   #12
Supercharged 07AV6
Spacer kit was on the car and i took it off for a bit because i thought it was triggering a problem the spacer kit actually does reduce temperature of the manifold pretty drastically for such a mod
Old June 10th, 2009, 05:30 PM   #13
Supercharged 07AV6
Yeah thats what i was referring to with that certain someone with P2R. They do do quality work in regards to the J series I will Post all pictures of the restructuring of the upper half once i begin it tomorrow and throttle body probably will come in early next week. I want to do the TLS Cam just i mean I dont know the extent of the install and haven't herd to many people thrilled with the amount of performance benefit as apposed to the installation difficulty.
And i am MOST definately boosting soon
Old June 10th, 2009, 05:32 PM   #14
dam very respectable mod list. subscribed for dyno results.
Old June 10th, 2009, 05:37 PM   #15
Supercharged 07AV6
Thanks for the kind comments lol... I will be on the dyno'ng soon but not until the next round of installations. ( Griffin radiator, Comptech tranny cooler, and Motormounts which are either in shipping or my garage. Then I will most certainly be posting dyno sheets.
Appreciate the info from everyone any other ideas on a next step let me know
Old June 10th, 2009, 06:06 PM   #16
J35 6Spd
where are you located?
Old June 10th, 2009, 07:01 PM   #17
M90SC Boosting 13PSI
NVA-AV6's Avatar
I personally have no problems with P2R products, from what I have seen they make good stuff.
Old June 11th, 2009, 12:22 AM   #18
Supercharged 07AV6
Im on the east coast... Yeah im in agreement with NVA-AV6 they make good products and do great work. They're prices are not crazy either, Jseries experience from any hop is hard to come by.
Old June 11th, 2009, 11:59 AM   #19
Archangel72's Avatar
Hey Paul, would it be a good idea to bring his CR to 11:1 if he is going boosted? I know the tl-s cams+raised CR will yeild great gains, but not sure if the TL's have stronger internals. Congrats on all your mods.
Old June 11th, 2009, 01:39 PM   #20
HIGH MPH's Avatar
Send a message via AIM to HIGH MPH
P2r
Has anyone tired the clutch they sell?? i'm thinking about getting one because its cheap
HIGH MPH is offline   Reply With Quote Quick reply to this message
Old June 11th, 2009, 02:48 PM   #21
Supercharged 07AV6
Thanks yeah i hope paul can answer those questions so i know my next direction
Old June 11th, 2009, 04:48 PM   #22
NVA-AV6's Avatar
J30 internals are cast so it really depends on how much boost you plan to run.
Old June 11th, 2009, 05:48 PM   #23
What if it was just like 5-6 psi from a supercharger
Old June 11th, 2009, 05:56 PM   #24
NVA-AV6's Avatar
5-6 should be good, but I would not want to go higher on the cast rods.
Old June 11th, 2009, 06:07 PM   #25
So what if you had J35 internals because if I remember correctly those are forged. Also wouldnt that be making some crazy power....J35 internals with CR 11:1 running 6 Psi off an Eaton M90....Dreams are beautiful.
Old June 11th, 2009, 07:55 PM   #26
NVA-AV6's Avatar
^That is a closer reality than you know
Old June 11th, 2009, 08:02 PM   #27
*waiting with bated breath*
How much power would something like that put down if it were to be made
Old June 11th, 2009, 09:07 PM   #28
NVA-AV6's Avatar
We should know in a month or less.....
Old June 12th, 2009, 08:01 AM   #29
This thread discussion alone makes me want to go FAST~ ... i cant wait to see the actual numbers from the gains he gets from this.
Cman46290 is offline   Reply With Quote Quick reply to this message
Old June 17th, 2009, 11:01 AM   #30
How did they go about polishing the exhaust ports? or did they?
accordriver is offline   Reply With Quote Quick reply to this message
