ECU Removal - Honda Accord Forum : V6 Performance Accord Forums
Old June 11th, 2009, 11:46 AM   #1
ECU Removal
Hey Guys
Does anyone know where the ECU is and how to remove it? I've only heard rumors its under the front passenger seat under the carpet but I believe that was for a 6th gen.
Thanks,
nadracer is offline   Reply With Quote Quick reply to this message
Old June 11th, 2009, 11:54 AM   #2
J35 6Spd
its under the center console directly underneath the radio/navi. if you remove the small triangular shaped panels on the console next to the footwells on each side the ecu is right there... the 4 harness connectors can be seen/accessed from the passenger side footwell
Old June 11th, 2009, 11:56 AM   #3
drzchulo147's Avatar
Send a message via AIM to drzchulo147
CONTROL UNITS LOCATION
Component Component Location
ABS Modulator Unit At left front of engine compartment.
ABS-TCS Control Unit Behind right side of engine compartment.
Audio-HVAC Display Module Behind center of dash. See Fig. 10 .
Cruise Control Unit Behind left side of dash. See Fig. 9 .
ECM/PCM Under middle of dash. See Fig. 10 .
Gauge Control Module Behind instrument cluster. See Fig. 8 .
Immobilizer Control Unit Receiver In steering column cover. See Fig. 8 .
Moon Roof Control Unit At rear of roof.
Navigation Unit In trunk, at middle of rear shelf. See Fig. 14 .
OPDS Unit In front passenger's seat back.
PCM Behind center of dash, forward of floor console.
SRS Unit Under middle of dash.
Throttle Actuator Control Module Under right side of dash. See Fig. 11 .
drzchulo147 is offline   Reply With Quote Quick reply to this message
Old June 11th, 2009, 12:04 PM   #4
Bobby Lane Racing
nighthawk04v6's Avatar
left kick panel of the pasenger side under the center console
Old June 11th, 2009, 01:06 PM   #5
03Accord EX-L's Avatar
does anyone know where the TL's is
03Accord EX-L is offline   Reply With Quote Quick reply to this message
Old June 11th, 2009, 01:15 PM   #6
J35 6Spd
same spot
Old June 11th, 2009, 01:16 PM   #7
Ok I kind of figured but wanted to make sure....I may be getting some parts for a nice little project but maybe not.
Old June 12th, 2009, 01:52 PM   #8
Hey Guys
So I have this cunning plan.
I called Jet performance and they do say they support 07 v6 accords for ECM upgrades.
I've been contacting around to find a spare ECM to run so the car isn't offline when I send my ecm or the spare in for an upgrade. The only snag I can foresee is if there is something in another module say ignition, tcm or other that may be tied to the specific one that comes out of my car.
My car is an auto so I already starting pinging junkyards for an 07 v6 ecm module and they are plentiful.
Old June 12th, 2009, 02:05 PM   #9
346hp/300tq @ 4psi
04accordcpe's Avatar
Originally Posted by nadracer View Post
Hey Guys
Jet performance??
GL......
Old June 12th, 2009, 02:06 PM   #10
nOrcaL7thgen's Avatar
Originally Posted by 04accordcpe View Post
Jet performance??
GL......
lol
nOrcaL7thgen is offline   Reply With Quote Quick reply to this message
Old June 12th, 2009, 02:07 PM   #11
Are they that bad?
I had the idea of a spare ecm first to keep my car running but also if a spare did work in my car I'd keep the original and send them the spare in case they f'd it up.
Old June 12th, 2009, 02:13 PM   #12
Search is your friend... but to make it easier, these are some threads to check out in regards to jet
http://www.v6performance.net/forums/...et+performance
http://www.v6performance.net/forums/...5&postcount=26
Last edited by AccordArmy2008; June 12th, 2009 at 02:14 PM.. Reason: i cant create proper sentences
AccordArmy2008 is offline   Reply With Quote Quick reply to this message
Old June 12th, 2009, 02:21 PM   #13
My only issue with a couple people having bad experiences is in my business you only often hear about things when they go sour not when they went well.
Old June 12th, 2009, 05:25 PM   #14
^^ Well by all means try it out and see how it goes... I don't really know how effective their product is (jet)... But it can't be as impressive as Hondata (considering they don't even have any products for the j series, yet), but if you try it and have a good experience, please let us know...
Old June 15th, 2009, 05:58 AM   #15
sirchadwick's Avatar
Jet Performace is not worth the time or effort for our vehicles.
sirchadwick is offline   Reply With Quote Quick reply to this message
