Outlaw Engineering Thermoblock Spacer Kit...Whats in the box? - Honda Accord Forum : V6 Performance Accord Forums
Old June 25th, 2009, 09:52 PM   #1
Hey Guys
I just got the Thermoblock spacer kit so I thought you all might want to see what was in the box. I also have a P2R throttle body gasket on hand to compare to the one that comes in the Outlaw kit.
Outlaw Kit
The two throttle body gaskets side by side; the Outlaw is on the right in both photos.
Compare the thicknesses.
The Outlaw is easily twice as thick as the P2R and the facing material to the intake manifold/throttle body is the same as the honda gasket. The P2R feels just like a thick piece of plastic.
Against a ruler
The hardware in the kit provides new bolts/studs for you to attach the new spacer but also longer bolts/studs to accommodate the thicker gasket for the throttle body.
nadracer is offline   Reply With Quote Quick reply to this message
Old June 25th, 2009, 09:53 PM   #2
Honda Tech
Matt04V6EX's Avatar
how much is this and where did you get it from?
Old June 25th, 2009, 09:55 PM   #3
Outlaw engineering. Go check their site its about $100
Old June 27th, 2009, 02:27 PM   #4
hello everybody i am new to the form and i have to post 10 thing before i can start a thread so i just wanted to say wats up everybody.i am a member of acurazine and yes i have an acura tl but when you guys see my pic it does not look like one.i joined this form bc az kind off sucks and everybody is always bashing other peoples stuff so i hope you guys dont.
hendrick honda, charlotte, justin, 704 746 8429
2004 mugen tl
aem v2 cai
intake plentom spacer
ported and polished intake runners
pre cat delets
j pipe
tl type s cat back
ur under drive pully
coolant bye pass modification
samco racing coolant hoses
260 fwhp
oooooooo and a bad trans
JS_MUGEN_TL is offline   Reply With Quote Quick reply to this message
Old July 7th, 2009, 11:42 AM   #5
Its finally installed.
It does seem to help to smooth the power delivery a bit more but its a very small change.
Old July 7th, 2009, 11:51 AM   #6
Wheelgap = sleeper mod
mbr311's Avatar
I think the main goal of the kit is to provide a steadier stream of cool air, which means that you would have a more consistent source of power delivery in hot weather especially. That's my take on it at least. Nothing that you can really show on a dyno, except maybe after repeated runs to show that you're not LOSING power.
Old July 15th, 2009, 11:51 PM   #7
Half-Breed's Avatar
I don't know about that thin P2R gasket, but their thottle body spacer sure is thick.
Here is mine, just got it put in today.
Half-Breed is offline   Reply With Quote Quick reply to this message
Old July 15th, 2009, 11:56 PM   #8
03Accord EX-L's Avatar
^^^^well that wont really prevent heat soak nor will it really do anything for that matter.
03Accord EX-L is offline   Reply With Quote Quick reply to this message
Old July 19th, 2009, 12:23 AM   #9
I don't see how adding more space will get you anything except a lighter wallet
bds6867 is offline   Reply With Quote Quick reply to this message
Old July 19th, 2009, 08:58 PM   #10
You are preventing heat soak from the block to the intake manifold.
Old July 20th, 2009, 09:58 AM   #11
The kit was never meant to add any power just to make things be more efficient. Granted it'll still suffer some heat soak from ambient heat the more you drive in stop n' go traffic but the IM will have a better chance of reducing heat directly from the block.
Old October 12th, 2014, 03:41 PM   #12
Thank you for the*informative*posts.
Neobeolorew is offline   Reply With Quote Quick reply to this message
