Crank Sensor - Honda Accord Forum : V6 Performance Accord Forums
Old June 28th, 2009, 10:16 PM   #1
Banned
Crank Sensor
Question for you guys.. what can cause a crank sensor on a car to keep going bad?. Like if you replace it tomorrow, by Wednesday afternoon it will be bad. Or is it possible that the ECU is going bad and is randomly throwing the same false CEL saying that the crank sensor is bad, even after it was just replaced less than 48 hours ago?
cls6speednupe is offline   Reply With Quote Quick reply to this message
Old June 29th, 2009, 05:27 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
ECU, or harness, it could even just be a bad/lose ground.
Old June 29th, 2009, 07:38 AM   #3
Banned
hmm that sounds about right, where would you start looking? is it common for the ECU to just go bad like that with no other issues? I would have thought if the ECU was bad then the car would pretty much not even work since those ECUs are so smart.
Old June 29th, 2009, 07:49 AM   #4
J35 6Spd
crank sensor on your brand new TL broke already? maybe you should just stop driving and get a bus pass
Old June 29th, 2009, 09:23 AM   #5
Banned
no
Old June 29th, 2009, 12:33 PM   #6
NVA-AV6's Avatar
I would start with cleaning and re-tightening all the engine grounds and checking that tall connecters are completely seated.
Old June 29th, 2009, 01:57 PM   #7
Banned
what exactly are the tall connecters?
Old June 29th, 2009, 03:07 PM   #8
Tee-Ooh-Double-Dee
Accordian's Avatar
I believe it's a typo and is suppoed to be "all" connecters.
Old July 6th, 2009, 08:20 PM   #9
Banned
Looks like it was OWNED and FAILED by a bad battery. The negative post had acid laying all around it. Battery finally failed last week since made in 2006 so I changed it to an interstate one then noticed that the car had 0 problems since. So basically Paul was right about it being a grounding or connection problem. Thumbs up to Paul..
Old July 7th, 2009, 07:51 AM   #10
Carpe Diem
ikethegreat's Avatar
Never thought I'd live to see the day!
Old July 8th, 2009, 04:21 AM   #11
adamlee05 is offline   Reply With Quote Quick reply to this message
