ok ... i need help with flashing CEL - Honda Accord Forum : V6 Performance Accord Forums
Old July 10th, 2009, 09:48 AM   #1
Honda Tech
Matt04V6EX's Avatar
Some of you guys know I've been having this problem with my car. Only sometimes when I get into the upper RPMs my CEL will come on. Now only seem to happen above 4500rpms and I notice it when I go through the gears in sequence (not only one hard gear pull) I did hook it up to a diagnostic scanner and checked the freeze data and got multiple cyl misfires (I think it was like cyls 3 and 5 or something like that) i've already checked plugs and coils all are good. Tried fuel injector cleaner instead of actually taking out the injectors may try that later on. Now I'm trying going down to reg fuel as opposed to 93 think it could be the knock sensor if maybe its not detecting octane rating correctly and therefore not advancing timing enough and causing misses. But I don't understand why it would cause only 2 cyls to mis. I'm getting extremely irritated by this and can not seem to figure out what is causing this. Any help would be appreciated cause I can't go to the track like this and honestly the cars felt a little sluggish too.
*edit: this was posted from my phone so forgive any shorthand please
Old July 10th, 2009, 11:13 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
Probably the crank sensor, they are known problems.
Old July 10th, 2009, 11:30 AM   #3
Honda Tech
Matt04V6EX's Avatar
Is there any way I could test that?
Old July 10th, 2009, 11:42 AM   #4
Honda Tech
Matt04V6EX's Avatar
I'm also going to test for compression for the hell of it. You Think I should do a leakdown test as well?
Old July 12th, 2009, 07:49 PM   #5
Honda Tech
Matt04V6EX's Avatar
anyone else any ideas?
Old July 12th, 2009, 07:52 PM   #6
NVA-AV6's Avatar
Can't hurt, if you have bent valves it could also cause this, have you ever mis-shifted?
Old July 12th, 2009, 08:01 PM   #7
Honda Tech
Matt04V6EX's Avatar
i havent but i did buy the car used from a lady who did not take that great care of the car ... also, I really dont think she would have been driving in the fashion of a mis-shift even damaging anything lol. Bent valves wouldn't cause a misfire only under extremely high Rs though would it? Also, Ive been driving around for a little while with reg fuel (87 octane maybe? not sure the rating) but I haven't gotten the CEL flashing again. I havent been going too hard on it so I might not be under the same conditions, but possibly a lead into a faulty knock sensor? Anyone know where this is in our cars?
Old July 12th, 2009, 08:28 PM   #8
NVA-AV6's Avatar
Knock sensor is in the middle of the valley, but have not seen many bad ones. And yes if there was only light valve-piston contact to just slightly wack them then yes it would only be really noticable under high load.
Old July 12th, 2009, 08:40 PM   #9
Honda Tech
Matt04V6EX's Avatar
if i take that out is there any way to test a knock sensor?
Old July 12th, 2009, 09:15 PM   #10
NVA-AV6's Avatar
Not really without a good tool that can show knock activity like a HDS.
Old July 12th, 2009, 09:32 PM   #11
Honda Tech
Matt04V6EX's Avatar
im a drummer would that help? hahaha
Old July 13th, 2009, 02:06 AM   #12
angelstatiz's Avatar
Just try craigslist and get a other car lol
angelstatiz is offline   Reply With Quote Quick reply to this message
Old July 13th, 2009, 01:56 PM   #13
Honda Tech
Matt04V6EX's Avatar
my next car will be either a C6 corvette or a new Camaro sooooo .... not yet ... still waiting to graduate school lol
Old July 14th, 2009, 07:39 PM   #14
TrakCord
AccordingLO's Avatar
i will sell you a knock sensor if you need one... actually i have 2 complete motors with wire harnesses and sensors and everything if you needs any sensors
AccordingLO is offline   Reply With Quote Quick reply to this message
Old July 16th, 2009, 10:30 PM   #15
mine was flashing too and in limp mode a few months ago,i was missfiring in all cylinders and was told it was a broken roller on my 3rd rocker or something ,maybe its sumtin like that
sp45 is offline   Reply With Quote Quick reply to this message
Old July 16th, 2009, 10:39 PM   #16
99VTECCoupe's Avatar
Send a message via AIM to 99VTECCoupe
Same thing happened to me, except that it was caused by a 720 spin on the highway in a torrential downpour I got power back after a couple minutes of driving on the shoulder with my hazards on. I must have starved the engine of oil for a few seconds and it went bananas.
2003 SMR Accord Coupe EX-V6 6MT, 200k miles
2003 Grand Prix White Honda S2000 , 85k miles
Wife's Car: 2004 SSM Accord Coupe EX-L 5AT, 140k miles
99VTECCoupe is offline   Reply With Quote Quick reply to this message
