K24A4 --> J30A4 can it be done? - Honda Accord Forum : V6 Performance Accord Forums
Old July 24th, 2009, 11:21 PM   #1
Senior Member
Send a message via AIM to itzjonjon69
I currently have a 04 accord with a K24a4 motor and i ****ed it up pretty bad with my turbo setup. I was wondering is it possible to swap it to a J30A4 motor? What parts would it needed? has anyone ever done this?
itzjonjon69 is offline   Reply With Quote Quick reply to this message
Old July 24th, 2009, 11:30 PM   #2
I dont know exactly what parts you would need but I 100% know its possible. A little over half of the engine bay setup is the same for the 2.4 and the 3.0 so it is possible.
MyV6Coupe is offline   Reply With Quote Quick reply to this message
Old July 24th, 2009, 11:32 PM   #3
-Maninder
Wouldn't that be waay too much work? I know the front suspension is different for I4 and V6, might be like that in 7th gen too..
Old July 24th, 2009, 11:53 PM   #4
Just buy another k24.... Its 700 shipped for a motor with 40k on it. Or better then get a k24a2 *tsx motor* and hondata the car.
What exactly happen?
in order for you to swap to a v6 you will need new harness, new front springs, new axle, and radiator, new tranney, and it goes on.
Old July 25th, 2009, 12:26 AM   #5
- Leo
03_AV6's Avatar
i agree, with the amount of work and costs, you are better off replacing your motor with another k24 and selling the car to get a v6 instead. I definitely wouldn't spend that much time and money just to go to a stock v6 motor.
Old July 25th, 2009, 04:22 PM   #6
I agree the tsx motor sounds like an excellent option.
nadracer is offline   Reply With Quote Quick reply to this message
Old July 25th, 2009, 04:25 PM   #7
-Maninder
Since V6 isn't that practical and if you really want power, do a K20/K24 Frankenstein build.
Old July 25th, 2009, 06:06 PM   #8
TSX if you just want to do bolt on but I suggest a k20/k24 frank since your going to have to pay for hondata kpro and a tune either way might as well get something better. Get a k24a4 long block replace the piston with 2009 tsx piston since they are 11:1 compression ratio. Get a tsx head or rsx-s head and get the cam gears to do 50* vtc and only use about 40-45* this will help with cam advancement and retardment. Then you will need an rsx-s oil pump, vtec silonoid, crv timing chain, and a lot of other little stuff. Anyways if a cop pulls you over he can't tell if it a frank swap and want not. If your car a i4 and then becomes a v6 its obvious.
Old July 26th, 2009, 12:01 AM   #9
Bobby Lane Racing
nighthawk04v6's Avatar
waste of money, you can yield much more power at a cheaper price with a K-series than trying to upgrade to a V6
Old July 26th, 2009, 12:07 AM   #10
✔ Verified Member
otsb708's Avatar
Old July 26th, 2009, 03:31 PM   #11
TrakCord
AccordingLO's Avatar
show me...without making the motor unreliable
Goin back to the Track!
AccordingLO is offline   Reply With Quote Quick reply to this message
Old July 26th, 2009, 03:36 PM   #12
i haz vtec
zany's Avatar
think it would be too much work and money
zany is offline   Reply With Quote Quick reply to this message
Old July 26th, 2009, 04:25 PM   #13
chiefy's Avatar
drop in a fully build f23!
spool or be schooled!
Old July 26th, 2009, 07:40 PM   #14
http://k20a.org/forum/showthread.php...ht=k24a4+turbo
daily driven k24a4 turbo with stock internals on a civic.
So I am sure if you do a frank swap that should be no problem
Old July 27th, 2009, 12:24 PM   #15
it is.. but very expensive, i say u stick 2 the k24, bcuz its wayy more moddable than a j30, and once ur done, it can put out wayy more than a j30
du ur research on aftermarket parts, skunk2 has some parts just for the k-series engine
lillankanprince is offline   Reply With Quote Quick reply to this message
Old July 27th, 2009, 12:43 PM   #16
Bobby Lane Racing
I could easily show you if you show me the money. I have built plenty of K-series that are street driven daily and reliable making over 220 whp n/a. i'll put one together for you. I'll get your K-series to make 260-300 N/A and street driven reliable if you want. A Stock K-series out of an RSX can see 220 whp easily with a tune, and minor bolt ons.
Old July 27th, 2009, 01:53 PM   #17
TrakCord
ok so 220whp thats what our j30's make stock....and how much is a good used v6 600 to 800 buks...how much is a good used k20 type s motor about 1500 to 2000
Old July 27th, 2009, 04:23 PM   #18
Let's add up motor mounts,ecm,transmission,harness and other miscellaneous parts not to mention install. The K Series is a much better option with a ton of aftermarket support unlike the J-Series.
wht/accord99v6 is offline   Reply With Quote Quick reply to this message
Old July 27th, 2009, 06:02 PM   #19
Senior Member
decided that im selling the accord, and im gonna be picking up a A4 or S4
Old July 27th, 2009, 06:29 PM   #20
Go S4 and buy 2 K04 turbo's you'll smoke just about everything out there.
Old July 27th, 2009, 06:46 PM   #21
Bobby Lane Racing
So all it's going to take is a engine to swap a v6 into a 4 cylinder shell? THink about it for a second. If you're going to question my knowledge at least pull out a book, or rack a 4 cyl 7th gen accord and than rack yours. Than make a list of every single dam thing you think you'll need to complete the swap. Than take that list go out there and get a price quote for all the parts. Than come to me and i'll give you a price quote which will beat the quote you got however it will still cost more than doing a K-series to K-series swap.
Trust me. There is more to it than just the engine. Alot more to it.
Also 220whp for a 400-450 lb motor versus a much lighter K-series (lighter than even a B-series).. Power to weight.. Think about it.
thank you bud.
Old July 27th, 2009, 08:38 PM   #22
Senior Member
timot_one's Avatar
Send a message via AIM to timot_one Send a message via Yahoo to timot_one
540 WHP daily driven. I've taken a few rides in this car and it scares me.
Think white and get serious. K to J is not a practical swap. I would just sell my car and get an Accord with a J30 if I wanted a V6.
timot_one is offline   Reply With Quote Quick reply to this message
Old July 27th, 2009, 09:36 PM   #23
TrakCord
thank you bud.
well in the swapping case i guess but if you think engine for engine a k series if cheaper to build good luck
