RV6 Jpipe installation FAIL HELPP - Honda Accord Forum : V6 Performance Accord Forums
Old July 28th, 2009, 10:31 PM   #1
drzchulo147's Avatar
Send a message via AIM to drzchulo147
Thumbs down RV6 Jpipe installation FAIL HELPP
ummmmm ok I broke off 3/6 studs from the 2 cats or headers if you will. I had a torch and i used pb blaster but they still broke off. I bought some bolts and nuts to replace the broken ones but i dont know how to remove the stud. And ideas would be really nice. I was thinking maybe drilling them out?? Its number 16 in this pic
drzchulo147 is offline   Reply With Quote Quick reply to this message
Old July 29th, 2009, 12:21 AM   #2
✔ Verified Member
otsb708's Avatar
Looks like its time to take it to a shop....
Old July 29th, 2009, 12:40 AM   #3
Tee-Ooh-Double-Dee
Accordian's Avatar
I'd have a shop fix it, especially since those cats are mucho expensive to replace.
Old July 29th, 2009, 05:28 AM   #4
M90SC Boosting 13PSI
NVA-AV6's Avatar
Drill and tap.....
Old July 29th, 2009, 08:12 AM   #5
Bobby Lane Racing
nighthawk04v6's Avatar
^ what he said would be your best bet.
Old July 29th, 2009, 05:07 PM   #6
What does the damage look like?
nadracer is offline   Reply With Quote Quick reply to this message
Old July 29th, 2009, 05:19 PM   #7
I <3 My J30A4
qnzthg89's Avatar
damn bro should have let me know when you were doing the install i would have loved to help...
Old July 29th, 2009, 11:51 PM   #8
well the car is in jack stands right now with no J pipe and i removed the front cat and i cant figure out how to take the rear cat out of the hole. All of the bolts are off the rear cat i just cant figure out how to get it out. Now im on the hunt for some precat delete so if you know of anything let me know
Old July 30th, 2009, 05:10 AM   #9
NVA-AV6's Avatar
To remove the rear cat, pull the pass side axel and the 1/2 shaft.
Old July 30th, 2009, 05:44 AM   #10
Someone posted that if i remove the strut bar and tps sensor it can come out through the top?
Old July 30th, 2009, 07:18 AM   #11
NVA-AV6's Avatar
Very Tight.....
Old July 30th, 2009, 09:04 AM   #12
Wheelgap = sleeper mod
mbr311's Avatar
Do you mean rear pre-cat or 3rd cat (the one w/out the O2 sensors)?
Old July 30th, 2009, 05:28 PM   #13
good luck pulling from the top. pull the axle and half shaft out that is the best way. should of hit the bolts with some lube usually they are pretty rusted. that sucks to hear. tech 545 honda
JS_MUGEN_TL is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 02:28 PM   #14
just a little update.. I ordered RV6 new pcd V2.. im installing them tomm. my car has been in jackstands ever since lol.. Good thing i have another DD.. (cb7)
Old August 9th, 2009, 03:53 PM   #15
- Leo
03_AV6's Avatar
That was me who removed it from the top. I dont know why others found it tight. I pulled the rear cat from the top with heatshield still attached in less than 2 mins. Just got maneuver it around the right way. I personally think its easier than removing axle and halfshaft.
Old August 9th, 2009, 03:54 PM   #16
^yeah thats what i did too. It was pretty tight but it was def easier then taking off the axle.. intermediate shaft etc
Old September 19th, 2009, 07:55 PM   #17
Mukman22's Avatar
I got the new RV6 V2 j pipe today
and was working on mine today and ended up stripping a bolt and it was the last bolt!!!! ahhhh grrrr....now i gotta take it to shop, i tried everything possible nothing worked
Mukman22 is offline   Reply With Quote Quick reply to this message
Old September 19th, 2009, 08:42 PM   #18
Stevo405's Avatar
Is there a harbor freight tools store near you? If there is go in there and ask them for a stud remover. Its a tool that you can use to remove only stripped studs. Its a weird little contraption and it may take you a minute to figure out how to use it, but it works. Then you can order a new stud from honda and us the double nut method to install it.
Stevo405 is offline   Reply With Quote Quick reply to this message
