Exhuast cutouts? - Honda Accord Forum : V6 Performance Accord Forums
Old August 4th, 2009, 04:21 PM   #1
Wink Exhuast cutouts?
So what do you guys think? If you are unfamiliar with an exhaust cutout, basically in this case its a butterfly type valve mounted somewhere in the exhaust (right at the end of j pipe?) that when triggered by the driver or electronically will open causing most if not all exhaust to be routed out the valve. The benefits would include slight HP gains at high rpm, as well as allowing you to run the stock exhaust system for quiet cruising, but when you want the accord to sound like a beast you open it up.
It seems NVA-AV6 (paul) had this idea here
I would like to get some interest/discussion going again about it
jdwilson4 is offline   Reply With Quote Quick reply to this message
Old August 4th, 2009, 04:30 PM   #2
teamrev's Avatar
great idea for turbo or sc cars
teamrev is offline   Reply With Quote Quick reply to this message
