Big Mouth for the 7th Gen - Honda Accord Forum : V6 Performance Accord Forums
Old August 9th, 2009, 01:56 PM   #1
M90SC Boosting 13PSI
NVA-AV6's Avatar
Well, as you guys know I have been building larger displacement ported out engines for our cars which have been providing nice numbers all the way up to 5500 RPM and then would just level out. With all the porting and displacement increases and cams the engines just don't seem to be able to get enough air to continue making power above 5500RPM bue to the restrictions at the throttle body, well I think I found a solution for people staying NA. How about a 80MM throttle body, yes that should flow enough, but one problem the damn DBW system, well I got a solution for that too.
This is going on WorldOn1Finger's J33 soon so we should have some new data soon to see what gains it makes, but butt dyno even on the stock J30A4 in my car says something is there. Alot of boring was done to the intake to open it up to 80MM as well and had to add (weld) to the neck in a couple spots where the metal was paper thin or even cut completely thru. Now that it has been tested and the cable conversion system is working properly and the ECU is happy with it I need to finish port matching the throttle body and send it off to Brett.
Next for this will be a upgrade for the 6th gen AV6/2nd gen CL-TL.
Old August 9th, 2009, 02:06 PM   #2
xXxCLS bOoStEdXxX
slowaccord's Avatar
your a madman!
Old August 9th, 2009, 02:07 PM   #3
xXxCLS bOoStEdXxX
slowaccord's Avatar
keep up the good work
Old August 9th, 2009, 03:54 PM   #4
Go Big Red
TheMajor13's Avatar
amazing innovation once again. great job.
TheMajor13 is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 04:11 PM   #5
v6xjinbo's Avatar
Send a message via AIM to v6xjinbo
wow seriously your awesome.
v6xjinbo is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 04:19 PM   #6
Pure Intellegence
AmericanDream is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 04:58 PM   #7
chiefy's Avatar
u my friend tru car god!
spool or be schooled!
Old August 9th, 2009, 05:12 PM   #8
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Sweet Fancy Moses = 80MM!!!!!!!
Old August 9th, 2009, 05:20 PM   #9
H22 VTEC's Avatar
WOW!
H22 VTEC is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 05:25 PM   #10
i need u in cali....
Old August 9th, 2009, 05:37 PM   #11
k24/k20 Turbo coming soon
telele's Avatar
Send a message via AIM to telele
I heard this thing in person today talk about air lol.
telele is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 05:45 PM   #12
b20vem1
CG_TypeR's Avatar
this guy is pure genius madman!
CG_TypeR is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 06:55 PM   #13
Adventure is out there!
littletruong's Avatar
wow looks like you might have solved the problem since the newer magnesium manifolds were a no go.
Old August 9th, 2009, 07:07 PM   #14
FAILLLLLLLL
whiteV6penguin's Avatar
whats the largest bore ppl have gotten before this?
whats the cfm difference?
whiteV6penguin is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 08:07 PM   #15
NVA-AV6's Avatar
Largest bore before this was 67mm bore out of the stock TB. As far as CFM, I need to get a air flow meter, anyone got an extra $1K laying around, LOL.
Old August 9th, 2009, 08:09 PM   #16
NVA-AV6's Avatar
Even with the newer intake it still did not address the throttle body which is no bigger than what we currently have with stock.
Old August 9th, 2009, 08:31 PM   #17
- Leo
03_AV6's Avatar
Is that just a universal throttle body you used? And i was just wondering how you went about eliminating the TPS sensor to go to DBC. Just some resistors or is there more to it?
Old August 9th, 2009, 08:42 PM   #18
that is sexy!!! care to bore out my tsx im? and tb? Paul you have some Swt Swt ideas man. Keep them flowing.
Old August 9th, 2009, 08:42 PM   #19
frumaroll
six6's Avatar
how much gains can be expected on a NA stock j30a4
Old August 9th, 2009, 08:53 PM   #20
NVA-AV6's Avatar
The stock TB is driving the cable, so both are in sync and the TPS in the stock TB is still providing good feedback to the ECU. And the TB itself is for a LS
Old August 9th, 2009, 08:55 PM   #21
NVA-AV6's Avatar
You can only bore a stock TB so far, in our case the stock TB maxes out at only 67mm, thats only 2mm larger than stock.
Old August 9th, 2009, 08:58 PM   #22
hmmm what next?
shonda1989's Avatar
i am liking the 80mm lets me know things
Old August 9th, 2009, 08:58 PM   #23
NVA-AV6's Avatar
Not a whole lot on a stock engine, now one that has been ported and tl-s camed, I can't see why it would not help.
Old August 9th, 2009, 09:19 PM   #24
i haz vtec
zany's Avatar
it does sound pretty mean
zany is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 09:31 PM   #25
yeah I looked at maxbore and its 100 for 60->65mm for the tb only another 65 for the manifold to port match
Old August 9th, 2009, 10:06 PM   #26
Maxbore is actually 150 for our thorttle boddies. Once you contact the guy he will tell you its 150 just to bore out the throttle body. It would go from 65-67mm thats it.
Old August 9th, 2009, 10:19 PM   #27
wow very nice work paul,lets us know about the diff gian,I'm interest if we can do it on J32/J35.
6thaccord98 is offline   Reply With Quote Quick reply to this message
Old August 9th, 2009, 10:52 PM   #28
hmmm what next?
shonda1989's Avatar
^ i dont see why it wouldnt?? paul i am intrested in knowing more about how you went from DBW to cable please fill us in...
Old August 9th, 2009, 11:21 PM   #29
NVA-AV6's Avatar
Yes, but there are different challenges, like the kneck to the intake is much smaller diameter and will need to be welded up to increase the diameter before boring and the IAC and TPS need to be delt with, I have Ideas, but have not actually built one yet.
Old August 9th, 2009, 11:22 PM   #30
NVA-AV6's Avatar
Unfortunatly there are too many eyes that come thru the forms to give up all the details, but the stock TB can be ut back to stock with no issues.....
