Reaching 30K on 05 ACCORD ! - Honda Accord Forum : V6 Performance Accord Forums
Old August 15th, 2009, 02:02 AM   #1
Planning on doing maintenance like plugs and filter.
Do you think NGK VPOWER is good?
Any ideas as to what to look at?
Battery is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 02:10 AM   #2
TylerT's Avatar
Send a message via AIM to TylerT
Changing sparkplugs after 30,000 miles?
You shouldn't be doing that until at least 60,000.
TylerT is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 02:21 AM   #3
iVTECaddict's Avatar
NGK VPOWER is not good. Comes stock with NGK Iridium. But yeah, you don't need new plugs at 30k, the engine's barely broken in.
Drain and refill the ATF if you have auto. Air and cabin filters maybe? Seafoam?
iVTECaddict is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 02:23 AM   #4
chiefy's Avatar
NGK Iridium
spool or be schooled!
Old August 15th, 2009, 12:08 PM   #5
Wheelgap = sleeper mod
mbr311's Avatar
You don't need to change the plugs 30k miles. Honda doesn't even recommend changing them until 105k miles IIRC.
Old August 15th, 2009, 03:27 PM   #6
Check your accessory belt for cracks or wear.
nadracer is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 03:42 PM   #7
ncv6coupe's Avatar
Check your Brake fluid, brake pads, cv boots and check your ball joints. Maybe replace your oxygen sensors also, my first went bad at 20k.
ncv6coupe is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 03:58 PM   #8
03 AV6 Coupe
hondav6's Avatar
i have never had a 02 sensor go bad and i have 65,000. The only thing you need to do at 30k is tranny fluid, A/C Filter if needed(easy to check), Engine Air Filter(if needed)and oil changes need to be done every 3000 miles. Spark plugs every 105k like MBR311 said.
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old August 15th, 2009, 05:35 PM   #9
30K is very early to be changing spark plugs, im at almost 70K and there is still no need for me to change my spark plugs.
AmericanDream is offline   Reply With Quote Quick reply to this message
Old May 29th, 2010, 08:14 PM   #10
Re: Reaching 30K on 05 ACCORD !
Yes I think NGK VPOWER is better than the other brand. And I am pretty sure that it will increase your horse power and its performance.
tiresmokindad is offline   Reply With Quote Quick reply to this message
Old May 29th, 2010, 09:45 PM   #11
gflip456's Avatar
wow very low mileage for an 05..wish mine was dat low!..i got mine in 05 brand spankin new and now have 83k..but yah save da money!, no need to change spark plugs.
gflip456 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2010, 11:43 PM   #12
paperboy42190's Avatar
i have a 2006 accord with over 104k miles
Nighthawk Black Pearl 2007 Acura TL Type-S
paperboy42190 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2010, 12:04 AM   #13
wow, you drive like no where.
i got a 07 and just cracked 90k today
akajjang9 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2010, 01:51 AM   #14
Honda Rookie
pbook4g5's Avatar
I have 140k on my car... and its an 03. I changed spark plugs at 100k. Did the timing belt shortly before that. Haven't really had to do much else....
Old June 2nd, 2010, 03:29 AM   #15
i'm not sure why, but for some reason I'm not feeling the engine idle as smoothe as before..
i'll change the air filter. could it be ****ty 10% enthanol gas?
after inspecting everything, it seems fine. maybe i'll change oil.
Old June 2nd, 2010, 12:04 PM   #16
cmriv's Avatar
Send a message via AIM to cmriv
Wht year is your car todd???
V6p=v 6 performance
not v6politics!!!!!
cmriv is offline   Reply With Quote Quick reply to this message
Old June 8th, 2010, 10:46 AM   #17
I hear that. 85k last time I looked......... MPG still about the same as when new. (That would be 27-28 summer). Factory indicates plug change at 105k - - along with timing belt, valve clearance check et al......)
This is a good automobile: performance and economy.
ez....
ezshift5 is offline   Reply With Quote Quick reply to this message
Old June 8th, 2010, 10:55 AM   #18
JayDawg's Avatar
I have 50,000 on my 05.
JayDawg is offline   Reply With Quote Quick reply to this message
Old June 8th, 2010, 11:02 AM   #19
Honda Accord Cpe Stealth
Send a message via AIM to StealthNShadow
I will one up you.....I have 48k on my 03. LOL
StealthNShadow is offline   Reply With Quote Quick reply to this message
Old June 8th, 2010, 07:09 PM   #20
got LSD J36TT??
tenzingsherpa's Avatar
^^ just for ****z and giggles i have 650 miles on my 2003 accord v6 . I BEAT U ALL!! lol jk
LSD 6-SPEED,Forged & Sleeved J36 MOTOR
(SNAILS ARE IN!!!, Smalser TWIN TURBO build UNDERWAY)
Like me at--->
Sponsors:
Mishimoto
Power Rev Racing
Racinx.com
Airtekk
Advanced Keys
tenzingsherpa is offline   Reply With Quote Quick reply to this message
Old June 8th, 2010, 07:20 PM   #21
gflip456's Avatar
^lol..no way pics or bs..body and motor only have 650 miles!!
Old June 8th, 2010, 09:20 PM   #22
got LSD J36TT??
^^ yeah just my motor (entire motor) has 650 miles. my body and tranny both have 60,000 miles
Like me at--->
Sponsors:
Mishimoto
Power Rev Racing
Racinx.com
Airtekk
Advanced Keys
Old June 27th, 2010, 06:06 PM   #23
Is the cabin filter hard to change? Its by the glove compartment?
Old June 27th, 2010, 07:16 PM   #24
yea lol right behind it
Old October 10th, 2010, 12:36 AM   #25
The manual suggests two diff't types of OEM plugs. Which one should I go with?
Old October 10th, 2010, 04:57 AM   #26
Bliyun's Avatar
mix and match!
jay kay
Bliyun is offline   Reply With Quote Quick reply to this message
Old October 11th, 2010, 11:25 AM   #27
03 AV6 Coupe
hondav6's Avatar
It is a very easy do it your self! There is a video on youtube. Here it is
This should be a sticky!
[ame]http://www.youtube.com/watch?v=axqD4kSORG4[/ame]
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old October 15th, 2010, 08:37 PM   #28
sirchadwick's Avatar
OK...
1999 - Honda Accord - 18,872
2004 - Honda Accord - 50,121
2006 - Acura TL - 2,032
2007 - Honda Accord - 12,171
There you go....
sirchadwick is offline   Reply With Quote Quick reply to this message
Old October 29th, 2010, 05:55 AM   #29
Tommy
tommastie's Avatar
that is such low miles on an 04
tommastie is offline   Reply With Quote Quick reply to this message
Old October 29th, 2010, 11:16 AM   #30
v6indodarknight's Avatar
dude... u only got 30k mi for 5 yrs... daimmmmm....
with me... 25k mi per yr...
&mpt=[CACHEBUSTER]">
click on picture to see my profile
"Not slammed anymore"
v6indodarknight is offline   Reply With Quote Quick reply to this message
