Is this a cheap kit? - Honda Accord Forum : V6 Performance Accord Forums
Old August 27th, 2009, 12:37 PM   #1
Send a message via AIM to Potential
http://www.nitrousdirect.com/nitrous...roduct_id=1788
What do you guys think about this NX kit? Its honestly exactly what im looking for but the price seems to good to be true. $400.00 for the entire kit with a 10lb bottle? What do you guys think?
Also are there any hidden costs with this as far as like a new fuel pump or anything like that? Would I be able to buy this kit, Install it and be ready to go or are there other things I would need to buy?
Edit: After reading more I would probably need to buy the purge kit, a bottle heater and a TPS. But the overall base of the kit is it a cheap setup?
Potential is offline   Reply With Quote Quick reply to this message
Old August 28th, 2009, 02:46 AM   #2
xodus's Avatar
well technically it is a full kit ready to go... but you have to look for saftey of your motor... like a wide open throttle switch , and a rpm switch. But besides you mention the tps get a rpm switch with a gear lock out so it will only spray at wot , at a certain rpm and only the gears you want. You can get away with a 50 shot wet safely.. 75 max... but as for the kit, nx is ok, i guess the cheaper way out, but you can search craigslist and get a used for for about 175-200 full kit, sometimes new for 250 being nx , or nos.. i wouldnt go with zex though.
xodus is offline   Reply With Quote Quick reply to this message
