j35 - Honda Accord Forum : V6 Performance Accord Forums
Old September 1st, 2009, 10:23 AM   #1
3.0UALLKNOW's Avatar
j35
i know alot of you are swapping the 3.0 for the new 3.5 Im seriously intrested in doing this swap but was wondering how easy does the 3.5 drop in the engine bay? is there alot of modification s that u must do? help me please. thanks
3.0UALLKNOW is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 10:25 AM   #2
Honda Rookie
pbook4g5's Avatar
I'm pretty sure it fits in almost seamlessly. Paul (NVA-AV6) would be the guy who would know for sure though.
“Success is 99 percent failure.”
- Soichiro Honda
Old September 1st, 2009, 10:30 AM   #3
M90SC Boosting 13PSI
NVA-AV6's Avatar
The 3.5 is a direct drop when built right, the problem is a 3.5 that is compatible with the 7th gen ecu and our trannys. Search you will find all the info on here.
Old September 1st, 2009, 10:32 AM   #4
-Gene
phunctional's Avatar
what about j37 lol that would be nuts
phunctional is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 10:40 AM   #5
NVA-AV6's Avatar
^Can be built, but have to bore the block 1mm over so you lose boost capability or re-sleeve the block for the 90mm pistions which is not cheap. My J36 builds use J37 crank and rods. Oh and the J37 block will not bolt up to our tranny's, nor will the new AV6 3.5L bolt up.
Old September 1st, 2009, 12:17 PM   #6
-Gene
damn.. fkin awesome.. one day i will have a pimped out coupe.. one day..
Old September 1st, 2009, 12:35 PM   #7
well my cars automatic and i wanted to get the new 3.5 with 6 speed transmission. But id still have a problem with the ecu? a new engine and tranny would be really expensive right?
Old September 1st, 2009, 12:46 PM   #8
NVA-AV6's Avatar
^To do a J36/6sp swap into your car would run about $8K from me.
Old September 1st, 2009, 02:15 PM   #9
Paul do you think the J35a3 from MDX 03+ will be direct swap on 6speed tranny and engine bay?
do you think I still need engine harness and ECU from TL-s 00+ to run the engine?or I can use from MDX.Thanks bro
6thaccord98 is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 04:40 PM   #10
NVA-AV6's Avatar
A3 is a no go, the bolt pattern is different, the only compatable 89mm bore block for a 7th gen that I have personally used is the 04-06 J32A3 block, I have also heard the J35A6 from newer oddys "may" be a fit. I just don't like the newer oddy engines since the use FRM sleeves and all cast parts.
Old September 1st, 2009, 05:58 PM   #11
drzchulo147's Avatar
Send a message via AIM to drzchulo147
would we need the j32a3 ecu too?
drzchulo147 is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 06:58 PM   #12
NVA-AV6's Avatar
^No, the stock J30A4/5 ecu will run the J32A3 with no issues, now a J36 you will want to add a FIC, external FPR, and RDX injectors.
Old September 1st, 2009, 07:54 PM   #13
so only engine from 01-02 MDX and 02-04 oddy can fit on 6speed and our engine bay right paul,
Paul do you think is possible if we use crank and con rod from J37(07 TL-s) on J32a2 or not.
Old September 1st, 2009, 07:58 PM   #14
NVA-AV6's Avatar
6th gens are a different ball game, yes the J37 crank and rods can be made to fit, but requires a bit of extra work to the crank snout....
Old September 1st, 2009, 08:07 PM   #15
07' V6 Auto Sedan
dnlgao's Avatar
Send a message via AIM to dnlgao Send a message via MSN to dnlgao
You should change your name to "HondaV6EnginebuildGOD"
dnlgao is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 10:44 PM   #16
lol Paul you the man! I love learning new stuff from you.
Old September 3rd, 2009, 12:42 AM   #17
-Gene
hey would a J37A4 be possible and be able to keep the AWD? lol im sure thats a pretty enormous question. and how much u think it is approximately to re sleeve the block?
Old September 3rd, 2009, 12:48 AM   #18
-Maninder
AWD isn't going to happen.
Old September 3rd, 2009, 12:56 AM   #19
-Gene
awwww haha and the dream dies
Old September 3rd, 2009, 09:12 PM   #20
I really hope your kidding. Anything is possible as long as you have the money to make it possible lol
Old September 3rd, 2009, 09:38 PM   #21
-Maninder
lol. I meant it isn't going to happen realistically. Might as well buy an AWD car instead, since it might even cost the same. Who knows..
Accord AWD swap hasn't happened yet though..
I don't see the point of it anyways.
Old September 4th, 2009, 10:37 AM   #22
-Gene
yeah true i was kinda just talking about an infinite budget for fun purposes but man an awd coupe would be amazing haha
Old September 7th, 2009, 09:29 PM   #23
King Aztec
1. You could, but the cost wouldn't really be a worth it; a Comptech supercharger kit would probably be a better option.
2. Paul should be my new best friend.
3. An Accord with SH-AWD would be awesome, but costly enough to the point of pointlessness. Might as well try the fugly new TL SH.
Average is offline   Reply With Quote Quick reply to this message
Old September 7th, 2009, 10:01 PM   #24
gflip456's Avatar
awd coupe = gtr
gflip456 is offline   Reply With Quote Quick reply to this message
