turbo j30... - Honda Accord Forum : V6 Performance Accord Forums
Old September 2nd, 2009, 04:19 PM   #1
^ 037 aka LEO
turbo j30...
stock...how many pounds can i go without running a piggyback? i have something put together for "spool up" testing purposes, i want to start the car without one. will the car even start up? let me know if i shouldnt even try starting the car.
*i know i sound like a noob asking, but this is for my own r&d...thanks
- Z*Ro<3>sV"N - is offline   Reply With Quote Quick reply to this message
Old September 2nd, 2009, 05:25 PM   #2
SC J32A3 Accord
Car will start and run fine as long as you don't mess with the fuel system or anything mechanical to keep it from running normally.
When you say "spool up" do you mean actual boost or just mock ups? I wouldn't add any boost without a piggyback. Because when the ECU sees boost, ~>2.90v on the MAP sensor, it's going to immediately throw a CEL. Not to mention you also running the risk of blowing your engine if it goes too lean at high RPM.
SleekAV6 is offline   Reply With Quote Quick reply to this message
Old September 2nd, 2009, 06:53 PM   #3
^ 037 aka LEO
I see...ill just do a mock up then just to see if I can spool up the turbine quick enough with the setup I have.
Old September 2nd, 2009, 07:12 PM   #4
chiefy's Avatar
i ran my turbo at 5psi no ecu for 6months.
spool or be schooled!
Old September 2nd, 2009, 07:20 PM   #5
^ 037 aka LEO
Then what happened after the 6th month? Cel? Blown engine? I'm only asking cus how do superchargers boost without piggybacks?
Old September 3rd, 2009, 12:04 AM   #6
turbomanx's Avatar
i'm run 7psi no piggyback just an one way map blocker 3500 miles.
some guys would say i'm not smart but its works.Looking in to an fi/c
right now to do it right!
turbomanx is offline   Reply With Quote Quick reply to this message
Old September 3rd, 2009, 05:18 PM   #7
SC J32A3 Accord
Are you guys using FMUs or something else to increase fuel with boost without a piggyback? Because I can't see how you guys ran boost without any fuel or timing correction, when I zero out my Emanage, I hear pinging under acceleration right away.
Old September 3rd, 2009, 06:52 PM   #8
346hp/300tq @ 4psi
04accordcpe's Avatar
You can drive it for as long as you want with the stock ecu only. As long as you cruise and stay in vacuum the whole time I did this for several weeks while I was waiting to get my PnP harness repaired.
Old September 3rd, 2009, 10:55 PM   #9
wow 346hp on 300TQ at 4psi that's awesome number dude,may I know all your boost setup dude? I'm really interested with your number.thanks
6thaccord98 is offline   Reply With Quote Quick reply to this message
