Did they fix CM stage 3?? - Honda Accord Forum : V6 Performance Accord Forums
Old September 13th, 2009, 12:08 AM   #1
ahhhz's Avatar
Question Did they fix CM stage 3??
just bought one, i'm lookin for anybody with recent experience on whether or not i need special mods... I know Doc had major issues a couple years back.... Does anyone know for sure if this kit works as is?? mahalo nui
Booooos
ahhhz is offline   Reply With Quote Quick reply to this message
Old September 15th, 2009, 02:21 PM   #2
It should work yeah that's what I've read but then again what do I know =p
JennyXoXo is offline   Reply With Quote Quick reply to this message
Old September 15th, 2009, 06:49 PM   #3
ahhhz's Avatar
that's a great question
Old September 16th, 2009, 05:49 PM   #4
i was looking into getting my clutch changed out as well since i was boosted at one point.
but from what i read, the clutchmaster fx300 (stage 3) clutch kit does work. pressure plate and clutch will work fine but it's your flywheel that becomes an issue. if you order their lightened flywheel then you're good to go....but if you decide to reuse your stock flywheel, you will have to send it back to clutchmaster so they can notch out a teeth so it will work with their kit.
somebody correct me if i'm wrong...
XplicitAzian is offline   Reply With Quote Quick reply to this message
Old September 19th, 2009, 09:04 AM   #5
Correction: To make sure you have no issues at all, Send them your OEM flywheel or find another used one so they can install the ring gear from your OEM flywheel onto their lightweight flywheel. Half the guys on the acura side were unhappy with the starter/flywheel grinding issues because the number of teeth that were already on the lightweight flywheel compared to the OEM flywheel was off by one tooth.
Better safe than sorry.
Other than that, the cheaper alternative is using the OEM Pressure Plate and flywheel with P2R's high performance friction disc/wheel for the Acura CL-S/TL. So far, on their J32 powered hatch, it's been putting down 500+whp and been holding up good for a long time now. I went to see it in person not long ago. I'll be trying this setup on my car to confirm its validity
Other than that, you have SPEC's Stage 3+ and 4 setups that run between $699 to $899; and with those you can use your OEM flywheel as well.
If you think about it:
OEM Pressure Plate + P2R Disc + Flywheel = $401 before taxes/shipping
SPEC Stage 4 Clutch kit = $699 before shipping
.... Clutchmasters, any kit after stage one = $1,500 before shipping .... seriously.
If you want, Let me know, I'll go ahead and post pics/info once purchase my setup in the next two weeks.
shiem is offline   Reply With Quote Quick reply to this message
Old September 19th, 2009, 11:40 AM   #6
346hp/300tq @ 4psi
04accordcpe's Avatar
hey, this guy does his searching very well
however, there is a 4th option. Clutchmaster stage 1,2,3,4, WITHOUT the lighten flywheel. only thing is you have to send them your flywheel to have notched in a triangle to accommodate there PP. this was actually my first kit and worked well. cost me only 600 bucks
Old September 19th, 2009, 02:04 PM   #7
J35 6Spd
how well did the stock flywheel work for you then? was there a big difference when u switched to the aluminum wheel?
Old September 19th, 2009, 02:19 PM   #8
So If I wanted to upgrade to a stage 3 clutchmaster clutch without the light weight flywheel it would only cost me 600 + install cost? Thats all I need?
ethanemc505 is offline   Reply With Quote Quick reply to this message
Old September 19th, 2009, 04:23 PM   #9
ahhhz's Avatar
Anyone know about the CM stage 2? same flywheel problem? what about the feel of it compared to 3
Old September 21st, 2009, 03:14 AM   #10
346hp/300tq @ 4psi
well you gotta figure the CM flywheel weighs approx 22lbs or so lighter than the oem one, so ya i definetly felt the difference kai it really helped out the low end and revs much faster now. its really a nice mod if you can afford it.
thats what i paid for it, but that was over 2 years ago. stage 3 is good, if you dont mind a bit of chatter when taking off, but you dont feel it if you give it a little more gas.
doesnt matter what stage you go with. if you opt for the LWFW, your going to get the same one stage 1 through 4. go back to CM with your new and old flywheel, so they can transfer the ring gear on to the new one. the PP and disc problem is solved already so no worries there. just be glad you found out about this now, than later. otherwise, you'd be paying for double the labor which isnt cheap depending on where you go. luckily my guy doesnt charge anywhere near what other shops charge for this type of work.
Old September 21st, 2009, 03:37 AM   #11
M90SC Boosting 13PSI
NVA-AV6's Avatar
Any update from
on the ring gear issue? Have they found a new supplier yet? I know you were talking to Hose about it.
Old September 21st, 2009, 03:52 AM   #12
346hp/300tq @ 4psi
Originally Posted by NVA-AV6 View Post
Any update from
no deal
instead doing a little research himself to try and find a supplier that has the right size and teeth count, he now discloses that the kit will make a starter noise, unless you send in a stock ring gear to replace it with =/
Old September 21st, 2009, 04:56 AM   #13
NVA-AV6's Avatar
^Boo, that is weak sauce......
Old September 21st, 2009, 11:50 PM   #14
Can clutchmasters resurface my stock flywheel? Now I have to send in both the stock flywheel to "have notched in a triangle to accommodate there PP" as well as the stock ring gear...correct?
Old September 23rd, 2009, 08:23 PM   #15
ahhhz's Avatar
project import said they can install the stock ring gears on the new flywheel so i won't have to send it in. they're SMART
Old September 24th, 2009, 12:29 AM   #16
346hp/300tq @ 4psi
hey man, what ever floats your boat. the only reason i said take it to CM for the work, cause the whole ring gear deal is their own fault and will do it FOR FREE. oh and you dont have to send it in since your local. you can simply drive there yourself and wait while they do it for you. only takes a half hour or so =/
lol, its not rocket science bro project imports and any other reputable shop would be more than capable of doing the job. you just need to grind off the welds, turn the LWFW to take away about a 1/4 inch of material so it can fit the stock ring gear (since the inside diameter is smaller than the CM one) and viola! job done.
just be glad i was here to warn people about this problem, otherwise you'd have to take it back out and fix this problem like everyone else that bought the kit,
your welcome
Old September 24th, 2009, 01:11 AM   #17
ahhhz's Avatar
your welcome
are you being serious?
well, anyway... to me downtime is the most inconvenient part about these upgrades so i'd rather have PI do it for $50 than have to find a ride to CM and wait for them to do it.
Booooos
Old September 24th, 2009, 03:48 AM   #18
346hp/300tq @ 4psi
serious about what?
just giving you the heads up and try to save you a little money, but if you want to pay to have it done, then cool..
anyways, i already told you what the problem was in the other thread to check the ring gear to make sure its the right one or you might have to take it out again. then you asked what should i do then Stevo405 told you the exact same thing in more detail and still, you decide to open your own thread about it =/ and FYI, Doc didnt have the full kit, only PP and disc - FW.
so, fix the ring gear and you will be good you will love the kit
Old September 24th, 2009, 04:10 AM   #19
Accord_V6_400m's Avatar
Any update from
no deal
Fine ill go back to Aasco and check them out in person again this Friday
So the stock FW has 122 teeth and the AL FW has 123? Just need the refresher course so I can count the ones at the shop and tell them they're screwing up.
Old September 24th, 2009, 05:08 AM   #20
NVA-AV6's Avatar
^Reverss that, the ASSCO has 122(same as older mopar apps) and the stock is 123. Also the ASSCO one is 1/4" smaller in diameter than our stock one.
Old September 24th, 2009, 12:22 PM   #21
346hp/300tq @ 4psi
roger that.
ASSCO is the culprit here. talk to them nick and ask why is it so hard to get the right size gear on these damn flywheels =/
Old September 24th, 2009, 12:35 PM   #22
Damn I'm ready for an upgrade with all this talk.
Old September 25th, 2009, 04:03 AM   #23
roger that.
Yeah will do, so Aasco has 122 and is 1/4" smaller, weird since they told me last time they had a stock unit on hand, he just couldn't find it at the time.
