5500k fuel/cut......no check engine light??? - Honda Accord Forum : V6 Performance Accord Forums
Old September 17th, 2009, 09:04 PM   #1
Boomdiada
Swift's Avatar
Send a message via AIM to Swift
hey guys, i talked with NA-AV6 about this and need to know what the hell is going on....
turboed 6spd 3.0L...went to tune with an FIC on a dyno at about 2-3 psi(crap kit and probably boost leak)..anyways the car gets "done"....hard to start....have to hold key and giving throttle does not help. Then while driving it hestitates and stumbles at certain RPMs. And then...no matter what the boost if any...it hits a cut off at 5500.
I scanned it for codes and only a EGR code which isnt the cause in my eyes, and no check engine light? Yet i heard its running in limp mode?
I just need a clue what to look for, i am curious to think if the MAP sensor is bad? it was showing 3psi just on idle which i know was wrong....
thanks for any info.
92' acura legend 5sd coupe Type-S*High compression 3.5 spec-R motor, custom pullies, custom intake, custom exhaust, custom chip, short shifter, injen intake, spec2 clutch, EBC redstuffs, etc etc
94' auto coupe for build up
Swift is offline   Reply With Quote Quick reply to this message
Old September 17th, 2009, 09:21 PM   #2
hmmm what next?
shonda1989's Avatar
unplug the FIC and see what happens.
Old September 17th, 2009, 09:24 PM   #3
M90SC Boosting 13PSI
NVA-AV6's Avatar
Sounds like a bad tune/fic installation....
Old September 17th, 2009, 09:48 PM   #4
chiefy's Avatar
hmmm what kit/turbo u have?.. i cant get past 2-3psi also changing turbo very soon
spool or be schooled!
Old September 17th, 2009, 10:25 PM   #5
drzchulo147's Avatar
Send a message via AIM to drzchulo147
i know this sounds stupid but check the engine oil level. I had a similar problem.
drzchulo147 is offline   Reply With Quote Quick reply to this message
Old September 18th, 2009, 01:13 AM   #6
J30 LSD
flylow2cre8's Avatar
think its time to get a new turbo? take it off and then trouble shoot with OE equipped.
Old September 18th, 2009, 08:51 AM   #7
chiefy's Avatar
i got a master power T61 turbo .70 will post pics
Old September 18th, 2009, 08:57 AM   #8
Bobby Lane Racing
nighthawk04v6's Avatar
First things first, unplug any electronic devices that you have installed for engine management and plug it back to stock form.
Fire it up. It should fire up and idle just fine. If not than you have just eliminated the aftermarket engine management as the culprit.
Also how can you not have a CEL and say there is an EGR code? If there is a EGR code your CEL will be on.
Old September 18th, 2009, 12:42 PM   #9
night_crawler's Avatar
I had the same problem in my boosted J30. At 5500 it hit fuel cut, the car shut off and had to stop to start it. This only happened when I boosted more than 9 psi. I'm pretty sure it's crappy FIC intallation, or maxed out fuel rails, or both. The plugs were fine. I'm planning to start fresh next summer and re-do the entire wiring. Hopefully you will sort this out soon.
night_crawler is offline   Reply With Quote Quick reply to this message
Old September 18th, 2009, 09:22 PM   #10
Boomdiada
Swift's Avatar
thanks guys for all the quick answers, i am just up to my eyes trying to diagnose my own car, and i am a mechanic full time and didnt want to go into this blind.
I checked oil. thats fine..
i will unplug FIC and see if she idles fine.
The egr code i think was a history code...not a current code.
Old September 18th, 2009, 09:52 PM   #11
chiefy's Avatar
i also thought it was my emanage and after unplug and test it wasnt so has to be the turbo itself!!! hope all works out for u!
Old September 21st, 2009, 11:33 AM   #12
Boomdiada
Swift's Avatar
alright,
its NOT the FIC..
its NOT the MAP sensor(since i disconnected piping and sensor at one point)
HOWEVER,
I realized he has a "jet" performance ECU and he had it only done a few months ago....and i am pretty sure that its a scam for the most part because of how complicated the ECU is, and thinking they f-d up the rev limiter...
any other opinions? i am still scratching my head on this
Old September 21st, 2009, 12:04 PM   #13
NVA-AV6's Avatar
Sounds like the ECU has been screwed with and is screwing up the data, time for a new/used ECU.
