Buddy Club E-Throttle booster - Honda Accord Forum : V6 Performance Accord Forums
Old December 4th, 2009, 09:04 AM   #1
Bobby Lane Racing
nighthawk04v6's Avatar
We had the chance to install one in a Honda Fit where the owner(a man in his 50's) was complaining about how laggy the throttle response was, especially after shifting gears. Now he can chirp tires with the honda Fit and says that the throttle response feels just like a cable driven throttle body. Here's a lil video we put together. Next will be in an accord
http://www.youtube.com/watch?v=76cSPNokFsA
Old December 4th, 2009, 09:30 AM   #2
Supercharged 07AV6
7thgencordcoupe's Avatar
I had seen this a couple times and didnt know if it was worth it
7thgencordcoupe is offline   Reply With Quote Quick reply to this message
Old December 4th, 2009, 04:52 PM   #3
StreetRacer4Eva's Avatar
Please Please Please make this work. We have been going back and forth with these things since our cars first came out!
StreetRacer4Eva is offline   Reply With Quote Quick reply to this message
Old December 4th, 2009, 05:21 PM   #4
I would love to see this work for our cars.
Old December 4th, 2009, 05:59 PM   #5
buy it and put it on ur car.
Old December 4th, 2009, 06:01 PM   #6
*S.L.O-CREW*
very interesting. i would like to see this one.
dyang89 is offline   Reply With Quote Quick reply to this message
Old December 5th, 2009, 06:19 PM   #7
gofaster012's Avatar
I hope it works too!! I have a thread going about this asking the same thing as everyone else. I am going to get the e-throttle booster soon so I hope it's not a waste of money!!
gofaster012 is offline   Reply With Quote Quick reply to this message
Old December 5th, 2009, 06:33 PM   #8
03coupe6speed's Avatar
Send a message via AIM to 03coupe6speed
subscribed. I would love to see this work on our cars...esp the V6!
03coupe6speed is offline   Reply With Quote Quick reply to this message
Old December 6th, 2009, 08:20 PM   #9
Supercharged 07AV6
Im def up for buying it any reason why it wouldent work with our cars? im assuming not
Old December 6th, 2009, 08:59 PM   #10
Bobby Lane Racing
ill try it in my car
Old December 6th, 2009, 10:32 PM   #11
J35 6Spd
so all this does is advance the throttle by the increment you set? how does it reduce lag in the DBW system though? if the car is idling at normal rpm... if you jam on the pedal there would still be lag but the RPM would just end up revving higher than without the booster.... right? enlighten me kiet.
is this also the same item that is supposed to allow the throttle body to open completely under WOT?
Old December 6th, 2009, 10:42 PM   #12
Bobby Lane Racing
the drive by wire system is mainly focusing on voltage/resistance determined by how you apply your pedal. by allowing you to control that resistance, you than can adjust based on pedal feel how much voltage is applied. this system allows you to advance the voltage applied based on your pedal feel that fits your need at that time.
I believe blitz makes a better product that does the same thing but more digitalized. however i'll have to test that out too..
Old December 6th, 2009, 10:50 PM   #13
Please keep us posted. Thanks for looking into this.
Old December 6th, 2009, 10:51 PM   #14
UCRk24accord's Avatar
So is the purpose of Drive by wire is to better fuel sufficiency?
UCRk24accord is offline   Reply With Quote Quick reply to this message
Old December 6th, 2009, 10:59 PM   #15
J35 6Spd
so the e-booster actually reduces the detected resistance by boosting the voltage...
can you program different resistance levels based on pedal pressure? i.e. for light pedal pressure, only a small shift in resistance to maintain some lag + throttle smoothness, but under high pedal pressure boost the voltage so there is essentially no lag? or can you only program a single resistance setting for it to follow?
Old December 6th, 2009, 11:09 PM   #16
Czechopino
vasekvi's Avatar
It accomplishes quite a few things focusing around precise control of the throttle opening. It integrates into the TCS and VSA systems to close throttle opening without having to resort too much to retarding ignition timing when traction is lost. Also it helps emissions especially in manual models by holding the throttle open longer between shifts and it helps rev match on upshifts too.
I have an auto so I am going on what I have heard about various honda models with dbw throttle.
My SSM Sedan Mod Thread
Old December 6th, 2009, 11:49 PM   #17
No I gotta look into this for my friend's fit. Awesome.
Old December 7th, 2009, 03:22 PM   #18
got LSD J36TT??
tenzingsherpa's Avatar
I wonder would this be better than the sprint booster? i mean this has an adjustable throttle control so i can control the fuel economy, and lag. hmmm i say someone should test both and see which one is better. IMO i think this buddy club e-throttle boster is better than sprint booster.
tenzingsherpa is offline   Reply With Quote Quick reply to this message
Old December 8th, 2009, 01:20 PM   #19
Supercharged 07AV6
Is the e throttle booster a plug & play dea?? I read up on the blitz which resets itself everytime the car is turned off so but i havent been able to gain any further info on the buddy club version (which IMO looks like its alot better quality than the blitz)
Old December 8th, 2009, 07:17 PM   #20
rajin929's Avatar
the lag felt by the DBW is definately one of the pet peeves I have about my car!
rajin929 is offline   Reply With Quote Quick reply to this message
Old December 8th, 2009, 08:46 PM   #21
hmmm what next?
shonda1989's Avatar
omg if this works i am puting this in my dads 7th gen i hate his DBW it is soooooo slllllooooooowwwwwww my J30a1 feels more lively.
Old December 8th, 2009, 09:21 PM   #22
no its not for the gen7 yet. You need that one ecu box that comes with that unit. That why it cost soo much.
Old December 10th, 2009, 03:46 PM   #23
loveracing831's Avatar
great vid. man i'm looking forward to this if it comes out for our cars
06 Accord
loveracing831 is offline   Reply With Quote Quick reply to this message
Old December 11th, 2009, 02:31 PM   #24
H22 VTEC's Avatar
Id love to see this done for our cars..hate the lag with the DBW
H22 VTEC is offline   Reply With Quote Quick reply to this message
Old December 12th, 2009, 04:08 PM   #25
I <3 My J30A4
qnzthg89's Avatar
Any new updates on this?
Old December 12th, 2009, 06:40 PM   #26
Bobby Lane Racing
not yet on an accord. but like I said, I don't see why it can't happen. We did it on a fit and it worked flawlessly.
Old December 12th, 2009, 06:49 PM   #27
I know thien has something like this on his car. He said its pretty good. Its not the buddy club but something like it.
Old December 13th, 2009, 11:01 PM   #28
ChilliBang's Avatar
So tell me why this won't work in our cars? Or has no one tried yet?
ChilliBang is offline   Reply With Quote Quick reply to this message
Old December 16th, 2009, 01:26 AM   #29
ChilliBang's Avatar
nevermind, I did some research and do not want!
Old December 16th, 2009, 02:25 AM   #30
Supercharged 07AV6
What did you find out about it....
