pre cat delete and cel now help - Honda Accord Forum : V6 Performance Accord Forums
Old December 11th, 2009, 01:54 AM   #1
hi all.
hi all. got a 06 acura tl with s/c had the pro cat, now I have the pre-cat deletes on. About 30-60 miles of driving I got a cel code P0139 02 circuit slow response (bank 1, sensor 2). I have the O2 simulators in the car. Any input guy? so this code is related to the o2 sensor in the bank of the engine?
thanks
v6mmc is offline   Reply With Quote Quick reply to this message
Old December 11th, 2009, 05:07 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
Your rear O2 sim is not funtioning properly and the ECU is B****** about it.
Old December 11th, 2009, 08:42 AM   #3
Bobby Lane Racing
nighthawk04v6's Avatar
^what he said what kind of 02 sim you using
Old December 11th, 2009, 01:42 PM   #4
the O2 simulators I have on the car are the one which come with the pre-cat deletes from richie. any advice what to do? should I replace the o2 simulator?
Old December 11th, 2009, 02:22 PM   #5
Honda Tech
Matt04V6EX's Avatar
hahaha thats awesome that actually made me laugh out loud
Old December 11th, 2009, 02:33 PM   #6
NVA-AV6's Avatar
Make sure the O2 sensor is re-connected, if it is then it is probably bad.
Old December 11th, 2009, 08:05 PM   #7
ok thanks for the help...
Old February 12th, 2010, 12:42 AM   #8
frumaroll
six6's Avatar
woo sorry for the old thread bump but im having the same issue. And it started right after i installed my precat deletes. Any ideas to what it could be? could it be that i didn't tighten the 02 sensor enough? i did notice a white corrosion on the 02 sensor when i took it out of the stock cat
Old February 12th, 2010, 03:37 AM   #9
NVA-AV6's Avatar
You may have knocked crap into the sensor, check for leaks in the system, if you can't find any, replace the sensor.
Old February 12th, 2010, 10:37 AM   #10
frumaroll
six6's Avatar
i dont think there are any leaks, i do get the precat delete hissing sound under acceleration but i was told that was normal, especially since i have no resonators.
Can i use one of the cheap o2 sensors online? or does it have to be oem
Old February 12th, 2010, 10:50 AM   #11
NVA-AV6's Avatar
Just be sure to use eaither Denso or NTK sensors, never use Bosch or others.
Old February 12th, 2010, 10:54 AM   #12
frumaroll
six6's Avatar
sweet, and cleaning my current o2 sensor is pointless?
also which sensor is the bank 1 sensor 2? is that in the rear precat on the bottom?
Old February 12th, 2010, 10:57 AM   #13
NVA-AV6's Avatar
Cleaning doesn't really work and can actually f it up more, yes it is the rear secondary.
Old February 12th, 2010, 11:33 AM   #14
frumaroll
six6's Avatar
sweet ill check it out, ill just tighten it and we'll see what happens from there on. does this effect the car in any way other than have a glowing CEL?
Old February 12th, 2010, 12:18 PM   #15
NVA-AV6's Avatar
Emmissions failure
