Custom Camshafts - Honda Accord Forum : V6 Performance Accord Forums
Old December 15th, 2009, 10:25 PM   #1
durka dirk's Avatar
Question Custom Camshafts
So im a noob to the 7th gen j30, I was looking for some cams found none. I read that tl-s cams are popular. so what im looking for is if a custom grind on on a j30 is worth the money and if anyone has done such a thing. Need the input befor i blow the money
durka dirk is offline   Reply With Quote Quick reply to this message
Old December 15th, 2009, 11:48 PM   #2
J30 LSD
flylow2cre8's Avatar
What I understand is the tl-s cams have a higher lobe and duration profile comapared to the j30a4. I would take that into consideration.
Old December 16th, 2009, 09:31 AM   #3
cunning linguist
MorePower4me's Avatar
The small gains you'd see over the TL-S (at stock 3.0L displacement) would probably not warrant the huge outlay of cash for a one-off set of cams. At least IMHO.
If you were doing a 'balls to the wall' 3.6 build, perhaps. On that front, LT is going for 750hp+ and still using the TL-S cams. Granted he's not NA, but that they will support that level of power is promising.
With the renewed interest in the J-series platform with all the swaps, I am hoping we'll see more aftermarket support... but who knows.
-Brian-
07 V6 Auto Sedan-> 10 CR-V
Mod'd Z06 - Sold for move
Old December 16th, 2009, 09:41 AM   #4
frumaroll
six6's Avatar
im still waiting for a dota cam and "j pro" problem is, not much interest in the new gen accords modding compared to the 7th gens
Old December 16th, 2009, 10:56 AM   #5
M90SC Boosting 13PSI
NVA-AV6's Avatar
I am talking to Blue Print racing about the market viability to produce J series parts, although it has made getting trannys and other parts harder the civic and teg J swaps will help with market demand and influence.
Old December 16th, 2009, 10:22 PM   #6
durka dirk's Avatar
thats good to know on all. the plan is when i get back from afganistan to boost it im looking for 450ish at the ground. i found a place in phoenix that can do the work. the shop hold the record for the fastest all motor and boosted honda's in the state. hopin all goes good.
Old December 17th, 2009, 03:56 PM   #7
rayray24's Avatar
Blueprintracing!!! good My friend has a sponsorship from them
Iam going with a custom cam from web and custom gears(no triggers tho)
rayray24 is offline   Reply With Quote Quick reply to this message
Old September 26th, 2010, 09:25 AM   #8
yea custom cams would be great but these j swaps seem to get no love from the aftermarket community hopefully blueprint decides to do something to help us out
antikswagga is offline   Reply With Quote Quick reply to this message
Old September 26th, 2010, 04:32 PM   #9
TrakCord
AccordingLO's Avatar
IMO there is a limit on how aggressive a cam can be for the j30 engine becuz of the cylinder head design. the cams are slid into the head and the cam journals are casted into the head as opposed to bolted on like the honda four cylinders....so this means if a cam is made too aggressive you will be unable to slide it in through the journals and it will not fit in the head!
AccordingLO is offline   Reply With Quote Quick reply to this message
Old September 27th, 2010, 08:13 AM   #10
durka dirk's Avatar
i didnt know that learned me well you did
