3.0L V6 Timing Belt Kit - Honda Accord Forum : V6 Performance Accord Forums
Old December 17th, 2009, 11:34 PM   #1
I feel da need 4 6-speeds
flyvtec's Avatar
Shopping around for a timing belt kit and found these:
http://www.autopartswarehouse.com/sk...%26+Drivetrain
Is the price good? I have 112K miles on my 04 and it's time to replace my timing belt.
Thanks in advance.
- Sal
Old December 18th, 2009, 04:52 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
About the same I get OE parts for.....
Old December 18th, 2009, 07:21 AM   #3
v66spd's Avatar
thats true.dont be putting something like a aftermarket timing belt on ur car.to much to risk
v66spd is offline   Reply With Quote Quick reply to this message
Old December 19th, 2009, 08:54 AM   #4
Send a message via AIM to badboy58
Go with Honda parts!
badboy58 is offline   Reply With Quote Quick reply to this message
Old December 19th, 2009, 10:13 AM   #5
flyvtec's Avatar
Cool. Thx for the feedback.
Old January 1st, 2010, 12:57 PM   #6
I just did mine last weekend and it was a good days worth of work. Make sure that you order the honda crank pulley tool, we had trouble with the strap method. Other then that, it was all pretty straight forward.
Old January 1st, 2010, 04:06 PM   #7
You can always use the old backyard method of holding the crank from turning. Remove spark plug or plugs. Find TDC on compression stroke for any cylinder. Turn engine forwards about 1/4 turn, then feed about 8-10 inches of small rope, nylon line or what ever into cylinder. Make sure you leave enough out of the cylinder so you don't loose it. Slowly turn the engine backwards until the rope is compressed between piston & cylinder head and the engine stops turning, this will hold the crank in place. Loosen the bolt. Reverse the process to tighten the bolt. Remember when tightening the bolt you must turn the engine backward before you insert the rope.
Tim
never stock is offline   Reply With Quote Quick reply to this message
Old January 1st, 2010, 09:22 PM   #8
J30 LSD
flylow2cre8's Avatar
Can I order a crank pulley tool online?
Old January 1st, 2010, 10:23 PM   #9
NVA-AV6's Avatar
Tim
Guys, DO NOT do this with the J engines, or any honda engine for that matter, the amount of tourqe often needed to break the bolt free can exceed 800-1000ft lbs, using this method with this engine design will destroy the rod bearing, bend the rod, or even the wrist pin or piston, these engines are not built to take that kind of abuse like a old chevy 350 would.
How's that hope and change working for you???
Old January 1st, 2010, 11:05 PM   #10
bka SouthBay7thGen
Drags2Riches's Avatar
i bought my timing belt kit at DCH Honda on Ebay...parts + labor $500 OTD
Drags2Riches is offline   Reply With Quote Quick reply to this message
Old January 2nd, 2010, 09:34 AM   #11
I just took mine to the dealer. $679 including labor.
Gatrhumpy1 is offline   Reply With Quote Quick reply to this message
Old January 2nd, 2010, 09:57 AM   #12
Yes you can...http://www.amazon.com/Powerbuilt-648...2447859&sr=8-1
