tsx brakes? - Honda Accord Forum : V6 Performance Accord Forums
Old January 11th, 2010, 07:41 PM   #1
Smile tsx brakes?
Just a quick question.. Are v6 mt and tsx rotors the same? And if so are the fronts and rears the same?
MarkGrif_04 is offline   Reply With Quote Quick reply to this message
Old January 11th, 2010, 08:14 PM   #2
Yes, they are. And from reading the TSX boards, the OEM pads/rotors warp just as quickly.
Jon2002 is offline   Reply With Quote Quick reply to this message
Old January 11th, 2010, 08:20 PM   #3
yes they are. and So are the hybrid. You can get some C-tek rotors for 25 on amazon a side. I have them with akabono pads. Stops really really good
Old January 11th, 2010, 08:29 PM   #4
i was thinking about getting these EBC black zinc brakes they look good and i think would look sweet on my black coupe
Fronts:
http://cgi.ebay.com/ebaymotors/EBC-B...Q5fAccessories
Rears:
What do you guys think?
Old January 11th, 2010, 09:09 PM   #5
less surface area = less braking power. But yes they look sexy. make sure the front are 11.8in not 11.1in. Also all the black on the where it touch the pad will wear down once you bed them in. Only the hub will stay black
Old January 11th, 2010, 09:18 PM   #6
alright i thought that they were mage of black zinc and the black wouldnt wear down. and i understand the less breaking power but when you warp OE rotors it makes no since to put OE back on
Old January 11th, 2010, 09:25 PM   #7
my OE centric didn't warp. Its the pad that f up the rotors not the rotor itself. The OEM pads leave deposit. That why I switch to ceramic akabono ProAct
http://www.amazon.com/Centric-Parts-...tive&carId=022
Old January 11th, 2010, 09:39 PM   #8
are the pads the same as well?
Old January 11th, 2010, 09:49 PM   #9
the Akebono ProAct are really great. No random reside crap like oem. very very low dust and 0 noise even on cold days. I got the front for 50 vs 80 for hawks HPS. Bites really well. I can do 80-0 stops without the front end brakes freaking out on me. Cost me 100 bucks for pads and rotor since when I bought them I used prime to get free 2day shipping off amazon.
Old January 11th, 2010, 09:55 PM   #10
are tsx brake pads and accord brake pads the same size?
Old January 11th, 2010, 10:27 PM   #11
just get the accord pad. It should say on the list. But make sure you get the v6 6mt one.
Old January 11th, 2010, 10:53 PM   #12
Czechopino
vasekvi's Avatar
Bedding in your pads properly is one of the most important things to do to prevent brake pedal vibration. Here is a video of me bedding my pads in.
http://www.youtube.com/watch?v=kd_PtFJW3_g
The video follows the instructions I got on this site here.
http://www.zeckhausen.com/bedding_in_brakes.htm
Old January 11th, 2010, 11:41 PM   #13
Listen to the man that some good stuff right here. I did the same thing on quiet open road. BBQ brake smell FTW
Old January 26th, 2010, 09:00 PM   #14
cool
What do you guys think?[/QUOTE]
Cool looking rotors! As far as brake performance and reliablity goes, I would go with the Hawk HPS brake pads front and rear. You will not be disappointed! I just put hawk hps pads on new OEM rotors yesterday and they feel SO much better than factory in terms of fade and responsiveness.
If you want more stopping power and do not mind changing the pads often and cleaning the brake dust off of your wheels, than go with the Hawk hp+. They have more bite to them, but of course at the cost of longevity and brake dust.
And an FYI, when you are doing brake work, Make SURE that the pins that hold the caliper move back and forth freely. (I am saying this because one of mine was frozen and I had to drive it out and re grease with dillectric grease). I do not know if this is common on our cars or if it was just mine, but I figured I would give you the heads up before you start your project.
fickel8 is offline   Reply With Quote Quick reply to this message
Old January 26th, 2010, 09:08 PM   #15
Thank you for the info
[QUOTE=vasekvi;1738983]Bedding in your pads properly is one of the most important things to do to prevent brake pedal vibration. Here is a video of me bedding my pads in.
Thanks for the helpful post! I knew there was a brake bedding procedure, but not sure of the proper means to do it. I just installed brakes, so it looks like a good excuse to have a little fun tonight
Old June 16th, 2010, 12:01 PM   #16
Honda Accord Cpe Stealth
Send a message via AIM to StealthNShadow
Since no one answer the question I was curious.......does the brake pads for our Honda Accords the same as for a TSX......I am caught between doing the 6speed upgrade with a set of tsx rotors I might be getting or a full tsx rotor and caliper change.....since I am trying to determine brake pad size.....Akebono brake pads say they fit both TSX and our Accord but HAWK HPS seems to have different part numbers for each of their respective front brake pads so I am confused anyone really know?
StealthNShadow is offline   Reply With Quote Quick reply to this message
Old June 16th, 2010, 01:18 PM   #17
okay here the deal. TSX = v6 mt = hybrid calipers and rotors. I have swap from a regular v6 to a hybrid calipers. The regular v6 has 11.1 rotors while the tsx/hybrid/6mt has 11.8. So you can't just change the brackets either because the rotors are thicker. I tired going that cheap route also. Bit me in the ass. So if you are going to do it swap out the calipers and brackets.
Also the rear i am not sure, but I think they are the same because they both look small ass hell to be rear rotors. compared to the fronts.
Old June 17th, 2010, 11:26 AM   #18
OKay I can understand that but are the pads the same for an accord 6spd or auto and the Tsx if you use TSX calipers?
Old June 17th, 2010, 01:04 PM   #19
accord 6spd and auto v6 the same part number on akebono. try to cross reference it.
