drain radiator fluid for aem install? - Honda Accord Forum : V6 Performance Accord Forums
Old January 12th, 2004, 06:20 PM   #1
Hey i've installed intakes before and never drained the radiator fluid. Do you have to on our cars?
DoctaJ412 is offline   Reply With Quote Quick reply to this message
Old January 12th, 2004, 06:39 PM   #2
Senior Moderhater
abram2001's Avatar
nope
I have never heard anyone draining out coolant just for a basic intake
Old January 12th, 2004, 10:58 PM   #3
I ran the AEM cai in my coupe. You do have to re-route a coolant hose during the install, but just top off the coolant for any that spills during the install. You do not have to drain the radiatior.
mlvswoll is offline   Reply With Quote Quick reply to this message
Old January 13th, 2004, 06:40 AM   #4
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
No, don't need to drain it. I put a towel under the coolant hose you have to re-route, because it does leak out when you disconnect it.... just a small amount though.
Old June 17th, 2004, 12:29 PM   #5
i just ordered the aem CAI recently... anyways to get to the point you HAVE to re-route the coolant hose?
raff is offline   Reply With Quote Quick reply to this message
Old June 17th, 2004, 01:40 PM   #6
03LXV6Guy's Avatar
Yes. You're replacing 2 hard metal lines that are side-by-side & connected to each other...... 1 is a coolant line, and 1 is a breather line. The metal coolant line is bypassed using a tubing connector. The breather line is replaced by a new hose included with the cai.
Disclaimer - All the above info valid for an Injen cai on a sedan. Others are probably the same, but don't know for a fact.
Old June 17th, 2004, 08:37 PM   #7
I've got the AEM and it's the same...
dboy619 is offline   Reply With Quote Quick reply to this message
Old June 17th, 2004, 11:38 PM   #8
Member
AV6on19s's Avatar
Send a message via AIM to AV6on19s
I drained mine and put it back in, but thats because it was latter in the night and I didnt have any extra to top it off!
2003 Honda Accord EX V6 6MT (SOLD)
2003 Honda Accord EX V6 AT (Sedan) (SOLD)
AV6on19s is offline   Reply With Quote Quick reply to this message
Old June 18th, 2004, 12:52 AM   #9
does it really come out enough that u gotta top it off?
Old June 18th, 2004, 06:40 AM   #10
03LXV6Guy's Avatar
Not on mine. It was probably only on ounce or two.
Hint - If you want to cut down on spillage, you can pinch off the coolant lines with vise grips or some other type of locking pliers.
Old June 18th, 2004, 09:44 AM   #11
hahah that's a frickin awesome hint! i woulda never thought of that. thanks
Old June 18th, 2004, 10:25 AM   #12
03LXV6Guy's Avatar
Yea, there are specific clamping pliers that are made just for that purpose...... clamping shut small coolant lines and vacuum hoses, for maintenance and/or trouble-shooting uses. I just use my small needle nose vise grips, with just enough pressure to close the line; not so much pressure that you risk damaging the line or hose though.
Old June 20th, 2004, 06:33 AM   #13
no, i installed my riends v2 2 days ago an i didnt read that part until after i was doe lol nothing happened dont waste your time
it did drip little but its not even noticible
jpizzle is offline   Reply With Quote Quick reply to this message
Old June 20th, 2004, 06:47 AM   #14
no i installed my riends v2 2 days ago an i didnt read that part until after i was doe lol nothing happened dont waste your time
Old June 22nd, 2004, 10:46 AM   #15
Did not need to drain the radiator. Engine was cool for about 15 minutes. Very little about 2 oz of lost fluid. Just use a towel when taking the hoses off.
lotsill is offline   Reply With Quote Quick reply to this message
Old June 22nd, 2004, 08:49 PM   #16
i installed it today and i took off the stock coolant hose (put a towel under there) and it started to pour out and wouldn't stop so i put the stock one back on and i had to switch to the new one really quickly. i just topped it off with some green coolant and all was good. otherwise it wasn't that hard of an install. luckily i finished rite before it started to rain
Old June 23rd, 2004, 12:05 AM   #17
with the new intake is it what you expected to get both sound and performance wise? and about the V2, why doesnt it have a by-pass i get the whole reason behind its whole "it doest let it perform at its best" ordeal but what about HydROLOCKIN? wouldnt it make it more vulnerable to it? i wanna get one but with no type of protection, im goin with an INJEN! until proven otherwise (i hope)
04DCspeedV6 is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2004, 01:17 AM   #18
Member
AV6on19s's Avatar
Injen is just as suceptilble (cant spell) to hydrolock as the AEM is. I wouldnt worry about it, our intake is on the left side, not right and its pretty well covered from the bottom. Im not the least bit worried...
Old June 23rd, 2004, 08:52 AM   #19
the intake is alright. i wasn't really looking for performance but i can tell u that i can't feel a difference in power at all. and sound wise i wanted it to be a little louder but otherwise it sounds good as sh!t. it has a nice growl starting from about 3k rpm and u can definately hear the vtec switchover now. for you to hydrolock your filter has to be completely submerged under water and you have to be at WOT. and if a little water gets thru the filter it's ok cuz it usually evaporates before it even gets to the throttle body. i have a friend that has a CAI on his prelude. the prelude is humping the ground (it's dropped a lot) and he goes to school in atlanta, georgia where when it rains they have a lot of places with high water. all u gotta do is let off the gas, drop ur car into neutral and coast thru the puddle and u'll be fine.
