Accord v6 6sp (NOS)??? - Honda Accord Forum : V6 Performance Accord Forums
Old March 23rd, 2011, 03:36 AM   #1
emtdiaz's Avatar
I was wondering if anyone knew how our cars would handle nitrous. I have an 04 Accord v6 6spd with just SRI, test pip and 2.5" pipe from testpipe to mufflers. I have been told to run wet shot instead of dry shot. im trying to learn more of it. any info would be great and how many shot would be descent? Thanks.
emtdiaz is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2011, 08:08 AM   #2
Here is an excellent thread from acurazine, its meant for the tl, but it should answer every question you have.
Inaccurate's Nitrous Methanol Injection System (NMI) - AcuraZine Community
jdwilson4 is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2011, 01:20 PM   #3
emtdiaz's Avatar
Thank you.
Sent from my ADR6400L using Tapatalk
Old March 23rd, 2011, 06:57 PM   #4
v66spd's Avatar
ive been running a zex setup for a year now started at a 55hp shot, then 65, then stopped at 75hp due to u need to add fuel after that.ive never had any issues at all.i use it at the track only tho.but no detnation, knocking or anything.tell u the truth runs really good with nitrous.
v66spd is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2011, 07:03 PM   #5
I <3 My J30A4
qnzthg89's Avatar
worldon1finger on you hit him up he knows his shyt about nitrous... im thinking of running nitrous as well
Old March 23rd, 2011, 10:44 PM   #6
emtdiaz's Avatar
Really :-) that's what I wanted to hear do you think you can make a list of the complete components I would need for a 55-65 shot please or what you are running? What kind of mods do you have other than nitrous and is it wet shot?
Old March 23rd, 2011, 10:46 PM   #7
emtdiaz's Avatar
Another question. Do you guys know what size injectors we have and fuel pump? Thanks
Old March 24th, 2011, 10:25 AM   #8
Sonnick's Avatar
What ET/trap are you doing at the track? Do you have before/after runs?
Instagram = j30_allmotor
Old March 24th, 2011, 09:33 PM   #9
landspec's Avatar
Maybe you can help me, I have a 2007 accord sedan w/ 6 spd m/t. I need to find a turbo for this car. Any help is appreciated.
landspec is offline   Reply With Quote Quick reply to this message
Old March 24th, 2011, 11:04 PM   #10
got LSD J36TT??
tenzingsherpa's Avatar
^^ no thread jacking. i sent you a pm with ur answer.
tenzingsherpa is offline   Reply With Quote Quick reply to this message
Old March 31st, 2011, 11:41 PM   #11
our injectors are 270cc and i dunno about the pump size, but if honda kept the same pumps they have had for years it is around 180.
a walboro 255 would be a good idea, but you don't need to upgrade injectors. a wet shot brings its own fuel. just jet it for whatever size hit you want and go. i have found that the NOS (brand) jet sizes tend to be on the rich side which is good because unless you have a way to pull timing you will need the extra fuel to best avoid detonation. (2 degrees per 50hp of nitrous is the general starting point)
I would look into ditching the factory headbolts in favor of some ARP studs if you are looking at any decent sized hit (100+)
I know ARP does not offer any j series kits, but our bolts are the same size as 8 of the 10 bolts used in a h23, so i do not see why 2 h23 kits would not work.
i had a 160 direct port setup on my built turbo civic and it was a blast! while it lasted haha
[ame]http://www.youtube.com/watch?v=ikXLdn6luxI[/ame]
scott0 is offline   Reply With Quote Quick reply to this message
Old April 1st, 2011, 09:45 PM   #12
hmmm what next?
shonda1989's Avatar
please get a wet kit if you do this
Old April 2nd, 2011, 04:41 AM   #13
^^ I don't know anything about nitrous. Sorry I can't help. I'm a N/A guy.
Old April 2nd, 2011, 07:51 AM   #14
-Allin-
LongBeachKid562's Avatar
Whatever you decide to do, don't buy a dry kit. 75 shot is about the highest you can run. If you want your nitrous to be more consistent, I would recommend getting a window switch so it'll only spray at a certain RPM.
LongBeachKid562 is offline   Reply With Quote Quick reply to this message
Old April 4th, 2011, 11:09 AM   #15
I have never sprayed a honda but I have sprayed everything else.
Dont be afraid of a dry shot as long as the injectors and pump can supply enough fuel. The vac. setup that comes on dry kits has a fuel jet in it that you can change to increase fuel pressure. With a good wide band you can see whats going on.
With that said I personally would run a wet kit. All wet kit no matter who makes it is usually setup rich. Its so you have some for of safety!! Dont misunderstand that though. Nitrous comes down to having enough fuel to supply for nitrous and enough timing removed so you dont dentonate.
I would suggest:
a good wide band AEM quality!! WOT {11.7-12:00} no more then a foot from motor and pre cats.
will need copper core plugs
255lph pump
window switch!!
if you gonna spray much over 75 shot a retard box
bottle warmer
nitrous gauge!! {and its not full and empty.. its pressure}
From all the power adders I have played with nitrous is the more relible one I have seen on the street and personal use.
But like anything else if not used right!! BOOM!!
teezy is offline   Reply With Quote Quick reply to this message
Old April 4th, 2011, 05:54 PM   #16
-Allin-
BTW I think they discontinued window switches. They came up with this new electronic adapter to were it sprays a certain amount of jet on different gears...
Old April 4th, 2011, 06:41 PM   #17
I <3 My J30A4
qnzthg89's Avatar
ooopss i think it was morepower4me who does? Sorry.
Old April 4th, 2011, 07:19 PM   #18
Archangel72's Avatar
^yup, thats who i thought of, but thought I was mistaken.
Old April 5th, 2011, 07:19 PM   #19
v66spd's Avatar
well last year i was running 14.6 with an intake, vafac2 controller,and decent tires.i also had a slipping clutch.but anyways when i added nitrous with a 75shot i was running 13.6 was my time in 1/4 mile.keep in mind not so good traction and really bad clutch after running nitrous.so this past winter i port and polished intake and runners, new spec stage 2+ clutch set up, and drag radials.i just hit my 500 miles today for brake in.i will run no nitrous this thurday at the track just to still play it safe.but ill keep you up on update with times.there is no need for any fuel upgrades as long as you dont go above 75shot. the car loves that amount so i will never probley go past that.
Old April 5th, 2011, 10:12 PM   #20
emtdiaz's Avatar
Dang. Thanks everyone for their input. I am going nitrous for sure now and im going to start at a 55 shot since im new to this still.
Sent from my SCH-I500 using Tapatalk
Old April 8th, 2011, 01:21 PM   #21
Keep it Clean
OG2DaMaxxx's Avatar
Really looking forward to see the results of v66spd Run's..
Let us know..
OG2DaMaxxx is offline   Reply With Quote Quick reply to this message
Old April 11th, 2011, 09:16 AM   #22
v66spd's Avatar
went to track thursday. got one run in due to people breaking stuff.but ran a 13.6. outside temp was bout 65, so not hooking at all on street tires spinning through third.clutch is amazing grabs really well. going to try to get drag radials before next thursday. and hopefully hook up better.but ran good i feel like..
Old April 12th, 2011, 02:22 PM   #23
Keep it Clean
OG2DaMaxxx's Avatar
Great info keep it up and keep us informed ..
Old April 15th, 2011, 06:06 AM   #24
v66spd's Avatar
had a set of drag radials up front last night at the track running 13.4 and 13.5.still having slight traction issues. but its front wheel drive wut can do.
Old April 19th, 2011, 12:51 PM   #25
Keep it Clean
OG2DaMaxxx's Avatar
When will you be going to the track with the NOS????
Old April 19th, 2011, 01:50 PM   #26
Sonnick's Avatar
What was your trap? That's a better indication of how much power you are making.
Old April 19th, 2011, 08:09 PM   #27
TrakCord
AccordingLO's Avatar
idk if you have taken out the chek valve from the clutch slave cylinder but you better or say bye bye to ur stage 2 clutch
Goin back to the Track!
AccordingLO is offline   Reply With Quote Quick reply to this message
Old April 20th, 2011, 09:53 AM   #28
v66spd's Avatar
way ahead of you. did that before i installed my clutch.thanks tho
Old April 20th, 2011, 10:49 AM   #29
Sonnick's Avatar
Damn1t what was your trap!?!?!?!
Old April 20th, 2011, 04:18 PM   #30
Keep it Clean
OG2DaMaxxx's Avatar
I know that the question is not dirrected to me but what do you mean by trap?
