Would it work? (Weight reduction) - Honda Accord Forum : V6 Performance Accord Forums
Old March 27th, 2011, 10:33 PM   #1
triplep's Avatar
Hey,
Just have a quick question to the people that are trying to reduce the weight in their vehicles. Do you know, if the TL front sub frame and maybe the rear would fit into our Accords?
The reason I ask is that I believe ours are made from steel, while the TL sub frames are made from aluminium. I was wondering if anyone knew how much weight would be saved and even if this was possible?
The TL sub frame is a bit more then the Accord one (1100$ vs 600$) but I was wondering if this might be a viable solution, since from what I have been able to read on the site, the TL j32a is a straight drop and play application, so wouldn't the front sub frame also fit perhaps?
triplep is offline   Reply With Quote Quick reply to this message
Old March 28th, 2011, 08:30 AM   #2
TrakCord
AccordingLO's Avatar
i cant justify to spend 1100 buks for 20 lbs or so weight reduction but i do think it is possible
AccordingLO is offline   Reply With Quote Quick reply to this message
Old March 28th, 2011, 06:32 PM   #3
^^ ad I think Thats just for the front sub frame. Def wouldn't e worth it.
Ramz86 is offline   Reply With Quote Quick reply to this message
Old March 28th, 2011, 06:39 PM   #4
A Registered User, I am
TKHOI87's Avatar
+1
lose 20 pounds and you can save $1100. (not implying anything offensive)
TKHOI87 is offline   Reply With Quote Quick reply to this message
Old March 28th, 2011, 06:53 PM   #5
sirchadwick's Avatar
+2
Just drive around with a 1/4 tank of gas.
Like you really enjoy filling the whole tank for $70.
Paying $1100 for this is complete insanity.
sirchadwick is offline   Reply With Quote Quick reply to this message
Old March 28th, 2011, 08:03 PM   #6
Czechopino
vasekvi's Avatar
For this type of money I am pretty sure that much more weight can be saved elsewhere. How much is a CF hood and trunk lid and fenders? How much are lightweight seats? How about lightweight wheels?
My SSM Sedan Mod Thread
Old March 28th, 2011, 10:15 PM   #7
triplep's Avatar
fair enough, I do realize that there are other options, I was just inquiring if it would be at all possible to do if someone wanted to do it.
As well, I thought that maybe the weight difference was a little more then the 20 lbs.
I was just thinking in terms of cost/lb, if you look at it per lb, it works out to 55$ a pound... Now a carbon fibre hood with shipping, would set me back at least close to 400-500$, I don't know how much weight you would shed by going to a carbon fibre hood etc. but lets say 10 lbs, so you are still looking at 40-50$/lb. Hence I was curious as to the actual weight difference between the two parts.
Old March 29th, 2011, 09:24 AM   #8
TrakCord
i was guessing how much the subframe from a TL weighs...i actually have no idea...but i guess im not to far off according to this article...it says 23lbs lighter than the previous generation TL...idk how this compares to the 7th gen accord though...
Acura Media Newsroom - Technical - 2006 Acura TL Chassis
Old March 29th, 2011, 09:55 AM   #9
Bobby Lane Racing
nighthawk04v6's Avatar
The next TL I do clutch service for I will weigh it.
Old March 29th, 2011, 10:03 AM   #10
triplep's Avatar
That would be great, and cubano, I know it was an estimate etc, I just don't think people realize how much it costs them per unit to reduce weight. I mean like some said there are other ways, I mean you could rip out all your interior and lose the weight for free. Or get light weight rims, which I think would end up costing more per pound saved then the subframe.
Nighthawk any idea what the accord sub frame weighs?
Old March 29th, 2011, 10:28 AM   #11
Bobby Lane Racing
no idea. never scaled it.
Old March 29th, 2011, 01:03 PM   #12
How much would a used one go for from the wrecking yard?
If you also bought the j32 or tranny with it?
07 AV6-6 SDN (>100K)...rock chips, dings, and rattles!
Old March 29th, 2011, 01:14 PM   #13
TrakCord
ye 20 lbs isnt worth it at all...if it were 50lbs i would say maybe...but they state in the article that it reduces vibration throughout and increases chassis rigidity...so unless that was the case its hard to justify 1100 buks even 700 or 800 buks is rediculous
Goin back to the Track!
Old March 29th, 2011, 02:24 PM   #14
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Brand new, personally I would not spend that amount.
Now, if you could buy it used and cheaper, I would definitely do it. It would be less weight AND an increase in chassis rigidity(if true). 2 bangs for 1 buck.
Old March 30th, 2011, 12:12 PM   #15
TrakCord
i wonder if an auto subframe would work? that would make it much easier to find and less demand
Old March 30th, 2011, 12:17 PM   #16
TrakCord
i am gonna check the website for new and used prices
Old March 30th, 2011, 02:52 PM   #17
triplep's Avatar
Sounds good I don't think you will find it for less then 1100 new. So the comparison between the 3g tl subframe was that against the 2g cl? Or what were they comparing it too? Like I mentioned I know the 7g accord has a steel subframe and the 3g tl is aluminum. I would think that the piece is fairly big so the difference between thew two metals could be more the 20 lbs. - guess the only real way to figure it out would be to actaully weigh both pieces.
Old March 30th, 2011, 03:19 PM   #18
Bobby Lane Racing
im sure you can find plenty at the local junk yards
Old March 30th, 2011, 03:42 PM   #19
3.56thgen's Avatar
don't believe it know it that's alot of money (but if you got it like that do it...the car is heavy because of the airbags, noise dampaning material, extra seats well you might as well just get another car and strip it down that's the best way to do it...but if you can take the noise on a daily bases then strip that thing down
3.56thgen is offline   Reply With Quote Quick reply to this message
Old March 31st, 2011, 09:45 AM   #20
TrakCord
i dont know if i would trust a subframe from the junkyard...those cars have been in major accidents and twisted the entire chassis so the subframe could be tweaked...the design of the aluminum subframe is to be super rigid and is a major part of the stiffness and structure of the front end which means it does not tolerate flex well and any stress could cause fractures not able to be seen by the eye...or the whole frame could be bent and you will never know until you go to mount it...its either all or nothin in this case you either spend 1100 or dont...
Old April 2nd, 2011, 11:48 PM   #21
triplep's Avatar
just a quick thought,
couldn't I just call one of those online places that sells both honda and acura parts, and just ask them how much the shipping weight is for both pieces?
I think that should give us a good idea as to how much each piece weighs...
Old April 4th, 2011, 08:11 AM   #22
TrakCord
that would give you the weight difference i think but not the actual weight because of the box weight and packing material etc..but please let us know of your findings that is a good idea
Old April 4th, 2011, 02:00 PM   #23
DAT Dewd from Dallas MANG
yo...
the best idea in the thread so far...good idea!!!
Old April 4th, 2011, 02:36 PM   #24
I believe gas is 6.3lbs per gallon
teezy is offline   Reply With Quote Quick reply to this message
Old April 6th, 2011, 07:50 AM   #25
triplep's Avatar
well, it turns out it is being harder then I thought to find out the shipping weight of these two parts, hopefully I will have some numbers today! Once I tell them I am calling from Canada they just say they won't ship such a heavy part.
Anyways, for anyone interested in giving it a go, and see what prices they can get here are the part numbers, I have added the weights that I was told:
05 Accord v6 6 speed sub frame is 50200-SDB-A01 (72 LBS)
06 TL sub frame is 50200-SEP-A03 (14 LBS)
So you are looking at saving almost 60lbs........ plus added rigidity and reduced vibration. It would also seem that all accord v6's use the same sub frame, and for the most part, all TL's use the same sub frame from 05-06.
Old April 6th, 2011, 12:21 PM   #26
yo...
HOLY BATMAN...that is a huge wieght difference!!!
72-14=58 lbs savd in weight....that's almost like getting rid of both seats!! (I think both seats are 90-100 lbs)
GOOD FIND!!
Old April 6th, 2011, 12:38 PM   #27
triplep's Avatar
Yeah that is what I found for shipping weights, however, I would still double check them with both weights.
As well, I would assume the accord v6 auto sub frame is even heavier yet...
Old April 7th, 2011, 08:16 AM   #28
TrakCord
wow nice find i dint think it was such a big difference...i am in shock!
Old April 7th, 2011, 10:30 AM   #29
Saiken
Send a message via AIM to DrachenV6
This is a great idea. I had no idea that the Tl's had aluminum subframes, but I think there are two important facts to consider:
1. The steel subframe is weight located at the lowest point of the car so it will act to lower the center of gravity. Lowering subframe weight will elevate the center of gravity. It would be better to have weight reduction higher up on the car, but that is probably something for the manufacturers to consider.
2. Density of aluminum = 2.7g/ cubic centimeter
Density of steel = approx 8.05 g/cubic centimeter
A steel subframe that weighs in at 100lbs would only weigh 33lbs if made from Aluminum
Have you guys looked into the toyota FT-86 that is supposed to be released later this year? It looks promising in the weight distribution/handling category. Itll be my next car when I finish school.
DrachenV6 is offline   Reply With Quote Quick reply to this message
Old April 7th, 2011, 11:48 AM   #30
Does anyone know if the TL subframe actually bolts up to the Accord?
