UR Pulley? - Honda Accord Forum : V6 Performance Accord Forums
Old April 3rd, 2011, 05:54 PM   #1
videogamegod03's Avatar
UR Pulley?
Unorthodox Racing
WHat is the difference between underdrive and stock diameter? WHich one is better and do i need to buy anything with it? Is this upgrade worth it?
videogamegod03 is offline   Reply With Quote Quick reply to this message
Old April 3rd, 2011, 05:58 PM   #2
NC Fresh
if you decide to get one(underdrive v6) i still have mine... BN... pm if interested.
iakona08 is offline   Reply With Quote Quick reply to this message
Old April 3rd, 2011, 06:35 PM   #3
Honda Rookie
pbook4g5's Avatar
The underdrive pulley will underdrive your accessories by 5% (I think). It's a smaller pulley, so it will need a smaller belt. Underdriving your accessories will result in less parasitic drag on the motor, hypothetically freeing up more power from the motor.
However, most of the power from the UR pulleys come from their weight, and not the diameter of the pulley.
I've had the UR underdrive pulley on my car for about two and a half years (approx. 75k miles) and I've had no issues.
Old April 3rd, 2011, 08:35 PM   #4
Archangel72's Avatar
I had the under drive version, and to me it was a mod worth doing. By the way its difficult to determine tone when writting something, so I am letting you know I am saying this in the nicest way possible. I did a quick search of your question and came up with 5 pages in the 7th gen section alone, 9 threads with the words UR pulley in it all containing info to anser your question. My opinion is go with the under drive.
Old April 12th, 2011, 11:37 AM   #5
ER MER GERD!!!!
DMunny's Avatar
I have the stock size UR crank pulley and you can feel the difference. Throtle responce is the biggest difference to me. Good investment. The install was quick too.
DMunny is offline   Reply With Quote Quick reply to this message
Old April 14th, 2011, 09:49 AM   #6
Tee-Ooh-Double-Dee
Accordian's Avatar
I've had the UR underdrive pulley on for about 40k miles with no issues. Much better revving and the car seems to pull harder in 1st and 2nd than with the stock pulley. Definitely worth it IMO.
Old April 14th, 2011, 05:15 PM   #7
sirchadwick's Avatar
15% Underdrive of accessories.
You will notice the engine is NOT as smooth as what it was.
At car shows, I would balance a cigarette on the engine. Now it is "much" harder to do after having this pulley on the car.
sirchadwick is offline   Reply With Quote Quick reply to this message
Old April 14th, 2011, 06:51 PM   #8
wht_on_blk
blk_on_blk's Avatar
Will it affect the electronics? sorry if this is a noob question but i have a 1000 watt rms system and just wondering if i can still run that stuff with the under drive pully
blk_on_blk is offline   Reply With Quote Quick reply to this message
Old April 14th, 2011, 07:12 PM   #9
A Registered User, I am
TKHOI87's Avatar
Most likely not gonna happen with your 1k watt system.
TKHOI87 is offline   Reply With Quote Quick reply to this message
Old April 14th, 2011, 07:51 PM   #10
This is my thinking, its hard to dyno prove this mod because due to the weight reduction it should be easier to get that crank in motion. Once the its spinning at full speed the pulley has little effect, but who really wants to dyno in first or second?
To the OP I would just get the standard size if you have a sound system.
Old April 15th, 2011, 06:51 AM   #11
wht_on_blk
blk_on_blk's Avatar
Thanks for the info! im really looking into this mod
Old April 28th, 2011, 08:13 PM   #12
I am strongly considering this mod. Is there really a significant difference between the under drive and stock diameter regarding results?
phil04 is offline   Reply With Quote Quick reply to this message
Old April 29th, 2011, 12:52 AM   #13
TKHOI87's Avatar
^stop post whoring and use the search button man. Not to sound like a douche but most of your questions have been already answered in one way or another on this extensive forum.
Old April 29th, 2011, 01:20 PM   #14
I have read the entire "performance" section, which is only 2 pages long. The best answer I found was that it is mainly a weight issue but under driving does offer an advantage. I am just wondering how significant that advantage is. Regarding the numerous posts... I have many questions and input I would like to present, and finally had some free time last night to being taking part. Also, I want to post my j-pipe install but have to post a certain number of times first so I am trying to get there.
Old April 29th, 2011, 01:39 PM   #15
Theres a search tab up top so you can access threads in the archives, or scroll to the bottom and theres an archive tab. If you have any unanswered questions and not enough posts, just pm a moderator, they will lead you in the right direction if they don't have the answer. You will not regret getting this mod underdrive or not, the difference is marginal.
Old May 1st, 2011, 01:52 PM   #16
I did not realize there was an archive. I will check that out. Thanks.
Old May 1st, 2011, 01:56 PM   #17
there an archive? wtf? I been here for 4 years now and I never knew that.
Old May 1st, 2011, 02:08 PM   #18
NC Fresh
I have a BNIB UR UNDERDRIVE PULLEY AND BELT FS!!! PM ME!!!
Old May 1st, 2011, 02:21 PM   #19
Honda Rookie
pbook4g5's Avatar
Where do you think all the threads go? lol
“Success is 99 percent failure.”
- Soichiro Honda
Old May 1st, 2011, 02:36 PM   #20
I can't pm anyone until my post count gets higher. This is frustrating.
Old May 1st, 2011, 03:18 PM   #21
NC Fresh
phil you interested sir?
Old May 1st, 2011, 07:11 PM   #22
pm a price. I should be able to pm after this post. Finally hit 15.
Old May 11th, 2011, 11:53 PM   #23
Iakona, did you sell your pulley to Phil? I'm interested if it's still available.
rsabboud is offline   Reply With Quote Quick reply to this message
Old May 12th, 2011, 01:27 PM   #24
haha...
elliott is offline   Reply With Quote Quick reply to this message
Old May 12th, 2011, 04:24 PM   #25
v6indodarknight's Avatar
i would get the standard size... but i can't on my 8.5gen... due to the fact that they don't have the stock size for the i4... sigh...
hope nothing happen to my engine... LOL... jk jk...
should be fine either way
&mpt=[CACHEBUSTER]">
click on picture to see my profile
"Not slammed anymore"
v6indodarknight is offline   Reply With Quote Quick reply to this message
Old May 12th, 2011, 07:24 PM   #26
NC Fresh
still for sale $180 shipped. pm me
Old May 13th, 2011, 06:07 PM   #27
Ouch!
Old May 20th, 2011, 11:24 PM   #28
I would stay away from under drive if you have a S/C or after market amp/sub system.
AckTL05 is offline   Reply With Quote Quick reply to this message
