What else? - Honda Accord Forum : V6 Performance Accord Forums
Old April 17th, 2011, 12:24 PM   #1
corpia's Avatar
What else?
Besides intake, exhaust and a j-pipe, what other performance upgrades are most of you guys doing? What gives you the most power? Any input is great thanks!
corpia is offline   Reply With Quote Quick reply to this message
Old April 17th, 2011, 01:10 PM   #2
A Registered User, I am
TKHOI87's Avatar
v3 PCDs give noticeable power. tls RSB. mdx spacer.
TKHOI87 is offline   Reply With Quote Quick reply to this message
Old April 17th, 2011, 01:17 PM   #3
Please search. We have sooooo many threads about this already. We even have a small questions thread. Best place to start is in the performance area. You will find almost all of your answers there.
Old April 17th, 2011, 06:29 PM   #4
Maverick_Supersonic
DjKing07AV6's Avatar
What is a TL-S RSB???
DjKing07AV6 is offline   Reply With Quote Quick reply to this message
Old April 17th, 2011, 08:34 PM   #5
It is a rear sway bar from the tl type s. 20mm diamater vs the stock average 14mm bar. Makes the car handle flatter around corners but you have to be careful not to put the 20mm on without any front bar mods because it may make the rear end come out. There are a bunch of threads on the bars and the differences between them.
Old April 17th, 2011, 11:47 PM   #6
Maverick_Supersonic
Oh ok. i know what the purpose of it is. I'm just didn't know that was the acronym for it. LoL
Old April 18th, 2011, 07:19 AM   #7
DAT Dewd from Dallas MANG
yo dawg...
if you want POWER get a turbo or a supercharger....
for just some pep...the usual bolt ons will work...but for serious POWER you need a turbo or a supercharger...
Paul...a.k.a NVA-AV6
can help you with BOTH forced induction options....
call the man....tell him either your HP goal or your Budget Goal....he will give you the right solution accordingly...
Old April 18th, 2011, 08:41 AM   #8
Archangel72's Avatar
^Don't forget a big fat stroker kit. =)
Old April 18th, 2011, 09:13 AM   #9
to be honest I am kinda of iffy about the stroker motor setups...I think that more money should be spent on aftermarket pistons and rods and then you have a good stroker motor that you can really beat on later....
CP pistons...
Pauter RODS....
I wonder if ACL or somebody could make a bearing set...
edit: I got a used block...j32a3...i wonder if j35a8 heads would fit on it...if so then I am in to make it a stroker motor!!!!
Old April 18th, 2011, 09:30 AM   #10
Bobby Lane Racing
nighthawk04v6's Avatar
CP pistons...
Pauter RODS....
I would get the J35a8 complete long block, get a new clutch case housing for the transmission so your 6 speed bolts onto the j35a8 bellhousing
The crank in the J35a8 is zero to none. It's the perfect stroke for a fast revving, well balanced engine that has either 89mm/90mm bore. Max bore on a J series is 90mm, and thus why you do not want to go with bigger stroke than 90mm. Bigger will make more torque, but when it comes to assembly balancing, you can't get any closer. Engine balancing = horse power.
Contact ACL,they should have them.
Old April 18th, 2011, 10:27 AM   #11
I honestly don't know, besides the cams and springs, what other benifits would the j5a8 heads have over the j32a3? And would it be cheaper to buy and install the cams/springs versus buying the hole head assembly?
Well you've certainly proven that the J35a8 long block is a proven method, but you got a killer deal on it how much would it run on average to buy the long block and new clutch housing vs oem stroker or aftermarket internals?
Old April 18th, 2011, 05:08 PM   #12
sirchadwick's Avatar
I would just get a different car...
For all those mods and time spent, it would have to be a serious hobby for you.
sirchadwick is offline   Reply With Quote Quick reply to this message
Old April 18th, 2011, 05:09 PM   #13
+1
Did the change, and my car has a tight arse feel to it.
Old April 28th, 2011, 08:11 PM   #14
I can't wait to do the sway bar mod. For the front do you have to support the motor and all in order to do the swap?
phil04 is offline   Reply With Quote Quick reply to this message
Old April 29th, 2011, 10:15 AM   #15
I "only" did the rear.
