Cannn you do this - Honda Accord Forum : V6 Performance Accord Forums
Old April 30th, 2011, 08:35 PM   #1
Cannn you do this
Yo I just wanted to know is it possible to put a Cl type s block to our j30 heads with out any crazy modifications
workinprogress is offline   Reply With Quote Quick reply to this message
Old April 30th, 2011, 09:40 PM   #2
TrakCord
AccordingLO's Avatar
yes it is possible however you need to change the crank position sensor and trigger wheel for the J30a4 over to the J32a2 block...also you must verify the valve diameters are identical otherwise you will bend the valves for sure..everything else will bolt up perfectly no problem, i would verify all the sensors are the same just to be on the safe side...if you look in the 6th gen accord forum there is information regarding the valve diameters
AccordingLO is offline   Reply With Quote Quick reply to this message
Old April 30th, 2011, 09:48 PM   #3
TrakCord
ok just found the post in the 6th gen forum...the j30a4 has a 1mm smaller diameter intake valve soooo....idk for sure but i think you can use the J32A2 block/pistons becuz the relief cuts on the pistons are for 36mm valve as opposed to the J30a4 block/pistons that have 35mm relief cuts
J30A1 '98-02 AV6: 34mm/29mm (intake/exhaust)
J30A4 '03+ AV6: 35mm/30mm
J32A1 '01-03' TL/CL: 34mm/30mm
J32A2 '01-03 TL-S/CL-S: 36mm/30mm
J32A4 '04+ TL: 35mm/30mm
J35A1 '99-01 Odyssey: 34mm/29mm
J35A4 '02-04 Odyssey: 35mm/30mm
