Richie's Pre cat delete gasket issues - Honda Accord Forum : V6 Performance Accord Forums
Old July 15th, 2011, 04:35 PM   #1
Greg
Send a message via AIM to nellynel8512
Hey jw if anyone has had issues with the gaskets on the PCD's, had PCD'd for about 1 year/5,000 miles and just this last week i noticed exhaust smell in my cab and a little different pitch than the normal rasp, when I brought it to midas they said both front and back gaskets were leaking/bad. Then i almost had to laugh when they told me it would be $50 for the set and $590 for labor so i grabbed the gaskets from acura for 20 bux. Sorry for the novel but just wondering if anyone else has experienced this.
nellynel8512 is offline   Reply With Quote Quick reply to this message
Old July 15th, 2011, 04:38 PM   #2
Greg
edit:that's the gaskets between block and the cat deletes, not the deletes and the j-pipe
Old July 15th, 2011, 05:37 PM   #3
1greek4u's Avatar
Call Rich he'll probably send you new ones for free lol. I've used his gaskets for pre-cat deletes, 4 different J-pipes, and test pipes and never had any issues.
Now that I think about it the gaskets provided for the manifold are Honda parts so I really think that shop was trying to pull a fast one; replacing those would be like 30 min worth of labor. Good luck
1greek4u is offline   Reply With Quote Quick reply to this message
Old July 16th, 2011, 08:52 AM   #4
Im starting to notice the rasp sound from the precats (not the back of the exhaust) to be a lot louder nowadays. Wondering if they are the precat gaskets that are leaking... All the bolts on the whole exhaust are tight. So either i got a cracked precat/jpipe or the gaskets on mine are gone too. Let me know if they made a difference on yours. I have about 30,000-35,000 miles on mine.
AnothaAznGuy is offline   Reply With Quote Quick reply to this message
Old July 17th, 2011, 03:23 PM   #5
1greek4u's Avatar
If it's leaking it's not gonna sound raspy it's gonna sound like a lawn mower haha
Old July 17th, 2011, 04:26 PM   #6
Greg
agree on lawn mower sound
Old July 17th, 2011, 05:24 PM   #7
Bobby Lane Racing
nighthawk04v6's Avatar
the gasket from the head to the PCD is honda OEM. they are metal gaskets and they don't fail. Check your PCD for cracks. I literally cracked a set of V2's after 2 track events.
Old July 17th, 2011, 10:17 PM   #8
Greg
it must be that then i didn't think the non-cardboardy type gaskets could go bad...****
Old July 18th, 2011, 02:45 PM   #9
That might be it. Im on my third set of precats since last April. Well im on my third rear precat and 2nd front precat. All of the above cracked when i was running a stock catback. No problems since i put on the Tsudo catback.
I would say its sounding more like one of my precat is cracked. Its been getting worse since friday.
Nellynel8512, what kind of exhaust are you running?
From my experience, the first rear precat had a crack at the top weld (not at the flange). The second rear precat (which Richie reinforced the top welds) cracked at the top flange. The front precat cracked at the top weld also. Take a look around those areas for a crack.
My check engine light came on when the precats cracked at the top welds. That would make sense since the crack was between the two O2 sensors. My check engine light did not come on when it cracked at the flange. The sound was just getting worse and worse. I installed the Tsudo catback in october and have not had any problems yet.. until now maybe?? its too hot outside to check hahaha.
Old July 18th, 2011, 05:00 PM   #10
Greg
yah my CEL is on as well, and that would make sense, i have richie's v3 j pipe and magnaflow cat back
Old July 18th, 2011, 05:01 PM   #11
Greg
I have the nrg dampner in hand , maybe i will install with new precats to prevent major rocking
Old July 18th, 2011, 06:16 PM   #12
aaah yes get that CEL checked. Most likely 02 sensor on the precats. The NRG damper should help a little. I installed an ingall torque damper after last precat cracked and now have XLR8 75a engine mounts. it should help minimize the stress put on the precats.
Old July 18th, 2011, 07:02 PM   #13
1greek4u's Avatar
When you install the PCD's make sure you bolt the J-pipe up before you tighten the head bolts. This should help minimize the stress that the exhaust itself is putting on them.
Old July 18th, 2011, 09:33 PM   #14
Greg
yeah i did originally but i'm hoping i can convince rich to ship to Australia ><
Old July 19th, 2011, 01:21 PM   #15
is the check engine light on forever once you put on the pre cat deletes?
BadBowtie03 is offline   Reply With Quote Quick reply to this message
Old July 19th, 2011, 01:44 PM   #16
24th Gear
Accordguy04's Avatar
It shouldn't be, they come with the sims to take care of that...
Accordguy04 is offline   Reply With Quote Quick reply to this message
Old July 19th, 2011, 04:22 PM   #17
no, the precats come with the O2 defouler.
2006 Honda Accord V6 6spd Sedan
K&N Cold Air Intake
Ingalls Torque Damper
RV6 V2 Precat Deletes
RV6 V3 Jpipe
Tsudo Evo 2 Exhaust
Old July 19th, 2011, 04:50 PM   #18
oh ok cool thanks
Old July 19th, 2011, 07:27 PM   #19
SK8 OR DIE
invsblduck's Avatar
I have the HFPCs (not the PCDs) Rich made for the 3g/7g this summer.
The welds are really, really beautiful.
But I'm wondering what I can expect from those, especially after I put a Smalser J36 in. The HFPCs scare me after reading what happened to Paul's otherwise-stock J30A4 when he was testing the M90 blower: the front precat failed and blew the whole motor when material got sucked back into the front bank of cylinders.
Anyone else running those HFPCs Rich made when he did the 4g/8g PCDs?
I'm pretty sure I'll core out the honeycomb on mine and convert them to PCDs when I get the J36 swap. I can't stand the thought of risking a custom J36!
invsblduck is offline   Reply With Quote Quick reply to this message
