wont shut off - Honda Accord Forum : V6 Performance Accord Forums
Old July 19th, 2011, 06:11 AM   #1
wont shut off
hey guys what could be the problem if im on a flat strait road, no hills or any of that and i let go of my clutch real fast but the car doesnt shut off, btw i drive a 03 coupe 6spd.
thanks in advance for an advise
driveacccord is offline   Reply With Quote Quick reply to this message
Old July 19th, 2011, 04:24 PM   #2
Uhm. . .. the car isn't supposed to shut off LOL.
Roca Fella Brya is offline   Reply With Quote Quick reply to this message
Old July 19th, 2011, 04:55 PM   #3
LoL! True ^
Rushzer0 is offline   Reply With Quote Quick reply to this message
Old July 19th, 2011, 11:03 PM   #4
Do you mean you go to stall the car and it doesnt stall?? If so what do your RPM's do when you have the clutch out?
Old July 19th, 2011, 11:43 PM   #5
v6xjinbo's Avatar
Send a message via AIM to v6xjinbo
in high speed even though you let go of your clutch really fast,it will not shut off. Dont worry too much bro.
v6xjinbo is offline   Reply With Quote Quick reply to this message
Old July 20th, 2011, 10:02 AM   #6
TylerT's Avatar
Send a message via AIM to TylerT
... should this guy even be driving manual?
TylerT is offline   Reply With Quote Quick reply to this message
Old July 20th, 2011, 10:13 PM   #7
for the guys that didnt get wat i was sayin can $uck it easy
Jake, when u just pop the clutch in a stand still witout applyin any gas u can so call "kill it" i cant "kill" mines no more, even on an up hill it just sits there. the rpms stay the same as if were in neutral between 500 and 1000 rpms.
by the way "dudes" dont be comin onto my threads if u aint got non good to say or arent able to help me out, get to kickin rocks.
Old July 20th, 2011, 10:30 PM   #8
Does it idle high when your in neutral?
Old July 21st, 2011, 03:32 AM   #9
i wouldnt say high exactly, does it idel more than usual, yea. its usually around 700 but at times its at 1100....sometimes its idels really low down to like 300 and it feels like its gonna die.
Old July 21st, 2011, 05:33 AM   #10
Hmmmm will it not stall in every gear? Try cleaning the throttle plate or maybe adjust the idle...it might be set too high
Old July 21st, 2011, 07:19 AM   #11
hate doing motor mounts
Supasnipa360's Avatar
^ +1. Theres a chance at about 1100 (normal for coldstart) you could keep it alive. Other than that make sure your clutch isnt worn.
Supasnipa360 is offline   Reply With Quote Quick reply to this message
Old July 21st, 2011, 05:26 PM   #12
it just doesnt wanna stall in 1st and 2nd, i recently had my 2nd gear replaced because it went out completely.
ive also been told that taking the clutch or flywheel (not sure which) out and kinda sanding/fileing it down would help?
the clutch in there now has about 1000 miles on it and its from exedy stage one.
Old July 21st, 2011, 05:41 PM   #13
I <3 My J30A4
qnzthg89's Avatar
What your talking about is your flywheel.
Old July 22nd, 2011, 01:26 AM   #14
Sounds like a problem with the clutch. Might be slipping if there is grease or something on the flywheel or pressure plate. Where did you have the clutch put it? When did it start doing this? Does it shift alright?
Old July 22nd, 2011, 07:16 AM   #15
Honda enthusiast
michaellowrider's Avatar
Did this start happening after that exedy clutch was installed? Are you trying to stall with the parking brake on? Parking brake will help you tell if its slipping and not properly installed(motor will continue to run after put into gear and clutch released)My guess is the installer made a mistake because a new clutch should def. stall the car. The shop that installed it should be held accountable if indeed there is a clutch problem. Good luck with everything driveaccord.
I love my honda like i love my _____. I'll smoke your v-8 like i smoke _________. Back up boy and show some respect, my honda accord's got a six cylinder v-tec.
Old July 23rd, 2011, 12:01 AM   #16
i originally bought the clutch on ebay and got it put in by a local honda dealership and everything was great its felt alot better than the oem clutch, however when i got my 2nd gear fixed by a guy who works at AAMCO Transmissions its started feeling "light" i guess u could say, when honda put it the clutch in it was great and i could feel where the friction point was but now i can release the clutch at any point and itll shift really smooth like im drivin an automatic.
Old July 24th, 2011, 06:31 AM   #17
Honda enthusiast
Based on that info my best hypothesis is that the aamco guy caused the issue, incorrectly reinstalled the clutch or failed to adjust the clutch etc. It couldnt hurt to go to aamco and explain the issue and remind them you're a good(paying) customer and hopefully they will diagnose and fix the issue they caused at no additional cost.
Old July 24th, 2011, 10:05 AM   #18
^^^ +1 thats the smart thing to do
Old July 24th, 2011, 01:47 PM   #19
Czechopino
vasekvi's Avatar
you could have prefaced your thread by saying you had a concern that your clutch wasnt holding and thus avoid the unwanted comments..
My SSM Sedan Mod Thread
Old July 24th, 2011, 08:36 PM   #20
yea i think i will go back to aamco, thanks for the help guys
