6mt conversion - Help finding parts - Honda Accord Forum : V6 Performance Accord Forums
Old November 18th, 2011, 01:56 PM   #1
Am converting from 2033 auto sedan to TL 6mt, but am having a hard time finding the following used parts:
1) v6 coupe - interior wiring harness
2) TL-S mt - tranny mounts
3) v6 coupe - shifter cable and linkages
Don't want to buy this stuff new, so any help would be appreciated.
holdfast is offline   Reply With Quote Quick reply to this message
Old November 19th, 2011, 07:54 AM   #2
DAT Dewd from Dallas MANG
shifter cables and bushings are easy to find used...I really would buy the inside harness and engine mounts new...thats what I did...
Do you have everything else?
M/t starter?
flywheel?
flywheel bolts?
clutch?
ecu?
intake manifold?
engine bay harness for a m/t model?
pedal cluster?
slave cylinder?
Old November 27th, 2011, 03:21 PM   #3
I have all the other parts. Just that I am in Canada and they are asking about $2000 Canadian for the parts I listed in the post.
Know any web sites in the US that I can order these parts at a better price?
Old December 6th, 2011, 04:51 PM   #4
traildevil's Avatar
If at all possible can you let us all know what you had to purchase entirely to do this 6 spd swap? and how much you spent total ?
traildevil is offline   Reply With Quote Quick reply to this message
Old December 6th, 2011, 08:34 PM   #5
rollaboy_95's Avatar
Are the accord mt tranny mounts the same as the tl-s? Bc i have the lower tranny mounts from my 06 accord 6speed that i replaced thinking mine were bad but werent.
rollaboy_95 is offline   Reply With Quote Quick reply to this message
Old December 20th, 2011, 10:43 PM   #6
I'll be switching from 6spd to auto hopefully this summer when I pull my motor out.
Toddy is offline   Reply With Quote Quick reply to this message
Old December 21st, 2011, 12:51 AM   #7
FollowingNFront's Avatar
You want to switch from 6 speed to auto?
FollowingNFront is offline   Reply With Quote Quick reply to this message
Old December 27th, 2011, 11:43 PM   #8
ya, tired of shifting in traffic, probably will wind up keeping it 6 spd though.
Old December 28th, 2011, 11:39 PM   #9
How many miles on the 6spd?
CL SLeePeR is offline   Reply With Quote Quick reply to this message
Old December 29th, 2011, 10:21 AM   #10
purplerims's Avatar
Wat trannys fit our 3.0 motor?
gainesville raceway 1/4mile 15.534 at 92 mph(pcd's and sri)automatic...
purplerims is offline   Reply With Quote Quick reply to this message
Old December 29th, 2011, 03:37 PM   #11
03 AV6 Coupe
hondav6's Avatar
TL 6MT
CL-S 6MT
TL Auto
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old December 29th, 2011, 07:20 PM   #12
purplerims's Avatar
So the cl type s tranny bolts right up? does everything else for the 6mt accord bolt up to the clay tranny
Old January 4th, 2012, 08:47 PM   #13
Sense this about 6mt parts does any know if the six speed civic clutch and pressure plate work with this tranny and further more would that make for a better stag 2 clutch set up
top scrt is offline   Reply With Quote Quick reply to this message
Old January 12th, 2012, 03:59 PM   #14
wouldnt it be better and sell it and buy a real 6 speed car? the TL 6 speeds are pretty cheap
Old January 12th, 2012, 04:20 PM   #15
I think I remember reading that the CLS-6 tranny needed to be modified to work...swapping/reversing the shift levers or something.
07 AV6-6 SDN (>100K)...rock chips, dings, and rattles!
