How Much Tweaking? TL Exhaust - Honda Accord Forum : V6 Performance Accord Forums
Old January 15th, 2012, 09:45 PM   #1
Although Ive searched, everyone seems to think when the question comes up people want to put stock TL exhaust on accord. I know its like 95% the same, but I want to know if its worth the trouble to modify this:
Tsudo 2004-2008 Acura TL Axle Cat back Exhaust Muffler | eBay
to work on my 04 accord v6. $480 is very reasonable for mandrel bent 2.5 stainless, and from what I have read it is well liked. However the one for the accord has the two large cannons which I despise. I could get that and put different mufflers on, but I figured it may be better to get this and modify it since it has the mufflers I like. Any help is greatly appreciated!
dandaman15 is offline   Reply With Quote Quick reply to this message
Old January 16th, 2012, 01:08 PM   #2
James
jconnway's Avatar
seems reasonable. I'm not too sure though I have an i4 *shrugs*
Old January 16th, 2012, 01:35 PM   #3
BLK HWAK
minhokim86's Avatar
Tl's are bit shorter.
need some modification on y pipe also.
i put greddy evo2 from tl and it didnt cost a lot to modify.
minhokim86 is offline   Reply With Quote Quick reply to this message
Old January 17th, 2012, 11:04 AM   #4
purplerims's Avatar
do you have a coupe or a sedan
purplerims is offline   Reply With Quote Quick reply to this message
Old January 17th, 2012, 12:37 PM   #5
I have a coupe. Thanks for the input so far guys too.
Old January 17th, 2012, 12:51 PM   #6
Picture Perfect
Milan's Avatar
In for this.
Old January 18th, 2012, 07:48 AM   #7
I didnt say I was going to do it, I was asking what needed to be done, ha! However I got quoted so much for a custom 2.5in, that if I buy this plus $100 to properly make it fit, it is still cheaper. Ill do more research before I decide to go ahead.
Old January 18th, 2012, 07:57 AM   #8
Sonnick's Avatar
The Accord coupe is about 2" shorter than the TL. I'm guessing you would have to modify (lengthen) the midpipe ever so slightly.
New car Review: 2004 Honda Accord Coupe EX
2004 Acura TL - Specs
Old January 18th, 2012, 09:27 AM   #9
James
jconnway's Avatar
What about for a sedan, just curious though, still rocking the i4
Old January 18th, 2012, 10:15 AM   #10
purplerims's Avatar
My custom 3 inch exhaust was 80 bucks plus mufflers... So 330 total
Old January 18th, 2012, 10:18 AM   #11
Picture Perfect
Milan's Avatar
But it was probably made with crush bends and cheap mild aluminized or mild steel.
Old January 18th, 2012, 10:27 AM   #12
I want stainless steel and mandrel bends. I know it can be done cheaper but its around 750 for what I want. Im thinking I will just get the exhaust with the evo2 style mufflers and have the exhaust shop to cut off the mufflers and straight pipe it with 3.5in tips. Maybe I would add another resonator or flowmaster 10 series to it under the car if that was too loud.
Old January 18th, 2012, 01:37 PM   #13
Sonnick's Avatar
I wouldn't recommend Flowmaster. Ironically, they don't flow very well and drone quite a bit. I'd go with Magnaflow, Vibrant, or Aero if you wanted to rid of any resonance. The 'universal' Magnaflows are straight through as are the Vibrants. The AR25 or 30 is supposedly very good as well from Aero Turbine.
Old January 18th, 2012, 02:02 PM   #14
purplerims's Avatar
yes with crush bends but there isnt anywhere remotely near here with mandrel bender I also got yo bring my own mufflers wich I got a magnaflow 30'in reso and a flowmaster hush power turndown muffler and it sounds good
gainesville raceway 1/4mile 15.534 at 92 mph(pcd's and sri)automatic...
