engine cylinder miss fire HELP - Honda Accord Forum : V6 Performance Accord Forums
Old February 9th, 2012, 03:09 PM   #1
hc_416's Avatar
Exclamation engine cylinder miss fire HELP
Hey guys as the title says I am having a problem with cylinder miss fires on all banks. I have had this problem since I have owned the car (2008) I will now start with a brief history of what I have done to find the problem. First I brought it to Honda, and they told me to replace the fuel rails for a 1000 dollars. They also stated they checked the spark plugs, coils, and intake gaskets. I could not afford that so I just drove with the check engine light on. It eventually went off and I went on my way. It then came on again so I brought it to a friend that had a garage. He said other than a rough idle the car runs fine. He also said because the car has so many miles (220000) he would not recommend taking the engine apart. So I just drove and it went away. The next time it came it did not go off. So I did some research and found that a leaky intake manifold can cause this problem. So I then took off the intake manifold, cleaned and applied new gaskets. It was fine for 40 miles, then I sat in a parking lot idleing for 10 sec and it came back up with the same codes. Now I am at a loss for words. As of right now the car drives fine. The only problem I have is a rough idle that would even denote a problem. My next phase is going to be check the coils and plugs again then, then try to get the fuel compression. Any advice would be helpful, I have struggled with this problem for four years and have no clue what to do. Thanks in advance.
hc_416 is offline   Reply With Quote Quick reply to this message
Old February 9th, 2012, 06:13 PM   #2
You need to do a valve adjustment to start, that can cause a misfire on all cyl's. Possibly a bad coil also. Im a tech for honda and see this all the time on oddy's and accords with higher mileage.
bigmatt is offline   Reply With Quote Quick reply to this message
Old February 10th, 2012, 02:12 AM   #3
hc_416's Avatar
What would be the recommend way to test the coil, dont have much money so I have to do as much as i can my self.
Old February 10th, 2012, 05:39 PM   #4
an ohm meter and check for continuity, should be able to find it on google
Old February 11th, 2012, 07:38 PM   #5
v66spd's Avatar
Check and make sure ur egr valve and passages are cleaned
v66spd is offline   Reply With Quote Quick reply to this message
Old February 18th, 2012, 10:33 AM   #6
any luck with your car? Im still thinking you have a dead coil
