7th Gen FIRST EVER: Apexi Smart Accel Controller - Honda Accord Forum : V6 Performance Accord Forums
Like Tree14Likes
Old February 11th, 2012, 01:41 PM   #1
James
jconnway's Avatar
Some time ago, I happened across a video for the Weapon R I-Throttle controller being installed in an 8th gen Accord. Although the unit was not designed for use with the Accord, someone noticed that the plug was the same as the one in a harness Weapon R offered, so they tried it and it worked.
I did a ton of research on drive by wire controllers. There are many different brands, but each one does the same thing, with varying degrees of precision. For a brief period of time, Buddy Club had offered a controller designed for the 7th gen Accord. I searched high and low, across the entire country and eventually overseas (via my internet obviously) but I could not find a single remaining example of this now long discontinued product. In fact, I cannot find anyone who even has one installed.
My searching led me to a company I have a long history with. Apexi has provided me with a unique tuning ability on my Accord through their Neo Air Fuel Computer. So I called up my buddies there and they told me about their product, the Apexi Smart Accel Controller.
I was intrigued. One was sent out to me, with some wiring diagrams and a harness designed for an 8th generation Accord. I set to work; the first ever 7th gen implementation of this unit (that myself or Apexi knows of anyway).
The first problem is the location of the DBW plug. Unlike in the 8th gen accords, where the plug is simply above the gas pedal, in 7th gens it is in the engine bay, on the left side. Very far away from the driver.
I apologize for not taking pictures of the modification process to the harness. I was in the zone and didn't want to lose momentum. It entailed re-pinning and splicing and almost an hour of cross referencing and double checking. I didn't want to fry my ECU by sending power, signal or ground to the wrong point and I had 12 of them to re arrange.
This is how I plugged in the harness.
The box on my engine is the brain. I wrapped it in carbon fiber to make it more esthetically pleasing. The harness shown below is quite secure.
Using my strut tower bar, I tucked the wiring behind it and zip tied it.
After running the wire for the controller through the firewall, I made the final connections and secured the brain. You can see one of my 3 runs of 0 gauge tucked in there.
This is the tiny control module.
I was going to, and probably still will wire the controller to the panel that is dangling. Unfortunately all three slots are occupied at the moment with the fog light switch and my volt meter. The switch on the lower part of the center console is for the volt meter.
Without extending the harness, I was limited in my mounting options. I will extend it and eventually mount the controller somewhere near the shifter.
For now, this positioning will suffice. It is secure and allows me to see the unit while driving.
So far, no thrown codes or negative issues. Out of the 7 driving modes, I will most likely leave it in hi throttle the entire time. A nice bonus with the unit is that it can be turned off.
So what do you think?
2007 Accord K24 Sedan - Modded Suspension, Engine, Exterior, Electronics
Old February 11th, 2012, 01:59 PM   #2
make sure you do the reverse grounding. You don't want Hi when your backing up. lol
Old February 11th, 2012, 03:00 PM   #3
inspire1318's Avatar
sounds like a lot of work lol any noticeable differences?
inspire1318 is offline   Reply With Quote Quick reply to this message
Old February 11th, 2012, 03:41 PM   #4
✔ Verified Member
otsb708's Avatar
All the rewiring would make my head hurt...
Sent from my iPhone 4[S].
Old February 11th, 2012, 04:12 PM   #5
James
jconnway's Avatar
Yes, I am going to do that tomorrow. It is pretty scary to blip the throttle and shoot backwards in reverse.
Major differences. I have heard people preach about how you need to "feel it" to believe it. That's true. You really have to drive the car with this thing and see the difference yourself. It makes it feel faster even though it isn't really. It may take a few tenths off or something just because it makes the tb open faster. But the most major difference is how hard it pulls around town.
It is no doubt a lot of work. I think it was worth it though.
Old February 11th, 2012, 08:05 PM   #6
Slammed & Stunning
MatthewYu's Avatar
Any chance this will work with the J30?
Also how much?
Seems like a lot of work.
Old February 11th, 2012, 08:25 PM   #7
^ it is a lot of work matt. I used to have one. and then it died..
Old February 12th, 2012, 12:16 AM   #8
James
jconnway's Avatar
Also how much?
It will work with the j30, in fact I know exactly what wires you need to modify to get it to work. It won't be cheap, I think these cost about 250 with the harness you need. BUT it is by far the single most noticeable mod I've ever done and I have everything.
no wait, the one you had was like some strange prototype from another company right? not knockin just sayin
and as far as the amount of work, yeah, it took me about 4 hours and thats after about a week of planning what had to be done. but thats 4 hours from the time i opened the box to the time I test drove it.
Old February 12th, 2012, 09:32 AM   #9
Bobby Lane Racing
nighthawk04v6's Avatar
It's PNP besides wiring in the reverse signal which you can take right off the tranny switch. What rewiring are you talking about at the ECU? My friends at apexi sent me one of these a while ago to play with and that's all I had to do.
Old February 12th, 2012, 11:34 AM   #10
James
jconnway's Avatar
I'm talking about the DBW harness. It is not PNP at all, they don't make a harness for 7th gens... only 8th gens and in order to make it work it required re-pinning. But instead of doing that I cut/spliced to not ruin the fragile connectors. Yes the plugs are the same, but if you do not re wire, it will not work. It can't... on the 08 harness, signal and power are reversed on the male side and power and ground are reversed on the female side...
plus the controller harness has to be extended. and anyway, this is far to complicated for it to ever be PNP... on the 8th gen yeah it takes 30 seconds. But if you got one to work on your accord... without changing the wires... this was all necessary?
Edit: I see where I said I didn't want to fry my ECU; I simply meant I didn't want to send some strange signal through the DBW computer and throw a code... I meant it in a more hypothetical way, this actually has nothing to do with ECU, my bad.
Old February 12th, 2012, 12:43 PM   #11
My issue with the prototype was extending the wiring and running that bastard through the firing wall. I also hate having it always blocking my OBDII port. But that was it. The different was there until it died. lol
I wish the still made the buddy club one. That one was super easy
Old February 12th, 2012, 01:41 PM   #12
this site still has them forsale...
Buddy Club E-Throttle Booster: Accord 03-07 [BuddyClub-04-ETB-F207B] - $348.00 : THROWDOWN PERFORMANCE, EBC Brakes | P2R | BC Racing | Techna-Fit | Unorthodox Racing | Megan Racing
Old February 12th, 2012, 02:34 PM   #13
James
jconnway's Avatar
^^ They don't actually have them lol. I tried every site.
And this one doesn't take up the OBDII port
Old February 12th, 2012, 02:57 PM   #14
Bobby Lane Racing
I am a direct contact with APEX'i, they're actually a couple blocks from my shop. I used a PNP harness for a TL, which works for the 7th gen, because the TB, and DBW systems are identical.
Old February 12th, 2012, 03:03 PM   #15
James
jconnway's Avatar
The 09+ harness for the TL is the same as what the v6 accord? or both... That seems... why would Apexi tell me the only way to implement it would be through modification then
Old February 12th, 2012, 03:13 PM   #16
✔ Verified Member
otsb708's Avatar
Maybe there is a difference between the V6 and 4cyl?
Old February 12th, 2012, 03:33 PM   #17
What was your experience using it? Are you still using it?
07 AV6-6 SDN (>100K)...rock chips, dings, and rattles!
Old February 12th, 2012, 03:39 PM   #18
James
jconnway's Avatar
Nope, according to my wiring diagrams, they are the same.
Reference voltage is power, obviously ground is ground and sensor output is Signal.
Old February 12th, 2012, 03:44 PM   #19
✔ Verified Member
otsb708's Avatar
Old February 12th, 2012, 05:32 PM   #20
James
jconnway's Avatar
well whatever lol I still got it to work and I think its a very cool product.
Old February 12th, 2012, 06:28 PM   #21
*S.L.O-CREW*
LOL. for making urself more work, but congrats on making it work.
dyang89 is offline   Reply With Quote Quick reply to this message
Old February 12th, 2012, 07:47 PM   #22
So is this for the 04-08 TLs or the 09+ TLs? Which one did you use?
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old February 13th, 2012, 09:50 AM   #23
James
jconnway's Avatar
^^ I wanna know as well, I would buy the harness... I don't doubt my work but it just makes more sense to have one that is pre-designed to be compatible. Or at least ends up that way.
This seems much like the 8th gens being able to use the Weapon R that is for the civic.
Old February 20th, 2012, 12:50 PM   #24
Bobby Lane Racing
It works. On the red mode, the throttle is extremely responsive. All the modes work. I'll be making a video if it on youtube when I get the chance.
I'll stop by Apex'i sometime this week and I'll work with them on making the PNP harness for the 7th gen. They already have the harness. It just needs a little bit of reconfiguration. You should not have to hack anything in your factory harness.
Old February 20th, 2012, 12:55 PM   #25
✔ Verified Member
otsb708's Avatar
That would be fantastic!
Old February 20th, 2012, 09:42 PM   #26
James
jconnway's Avatar
If your harness from the TL is plug and play, I'd be very unhappy with Apex'i for not letting me know. I had to reconfigure the entire harness... But not the factory one, I think you got that part confused.
My throttle is extremely responsive on red. If I have the unit on, it is on red. Other than that there is really no reason to use a throttle controller... its basically balls to the wall or not at all.
Old February 20th, 2012, 11:39 PM   #27
Bobby Lane Racing
why did you cut the wires up? you can unpin and repin.
Old February 21st, 2012, 10:20 AM   #28
@nighthawk04v6: Any chance you could ask Apex'i about a groupbuy for this & the PnP harness?
Old February 21st, 2012, 10:28 AM   #29
Bobby Lane Racing
If there is enough interest, I can put a group buy together. Let's wait till I get videos up about how it works first. Than get a list of interested people going. I'm direct with Apex'i so I can put a harness together that is PNP and distribute it.
Old February 21st, 2012, 10:34 AM   #30
✔ Verified Member
otsb708's Avatar
Interested.
1. OTSB708
