TL Cam Specs? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree4Likes
  • 2 Post By AccordingLO
  • 1 Post By AccordingLO
Old March 26th, 2012, 04:14 PM   #1
TL Cam Specs?
Anyone has these on hand? Trying to find the difference between the accord and the TL cams everyone swaps. Also want to see how they compare to Bisi's.
Im talking duration and lift.
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old March 26th, 2012, 04:15 PM   #2
reason im asking is because im thinking of regrinds and got a extra set of oem accord cams.
Old March 26th, 2012, 04:34 PM   #3
SSM_AV6-6
NHB_AV6-6's Avatar
Yeah it depends on your goals. The Bisi cams are quite expensive, but I'm pretty sure they'll yield better results. NVA-AV6 measured the TL-S cams, and they are a bit larger in lift than the AV6 cam, can't remember the duration.
What I'd really like to know, is are the 8th gen AV6 cams the same as the TL-S? Somebody mentioned that the part numbers are nearly identical, but the Accord cams are considerably cheaper than the TL-S.
Old March 27th, 2012, 12:53 PM   #4
TrakCord
AccordingLO's Avatar
^^ That was me
Sonnick and Atlas.46 like this.
AccordingLO is offline   Reply With Quote Quick reply to this message
Old March 27th, 2012, 12:56 PM   #5
Cubano are you using the 08 Accord cams?
Old March 27th, 2012, 12:57 PM   #6
TrakCord
nope stock J30a4 cams, OEM power baby!! Jiga is a cheater! lmao j/k
Atlas.46 likes this.
Goin back to the Track!
Old March 27th, 2012, 12:59 PM   #7
LMAO
04 Accord 6-6 Coupe
Old March 28th, 2012, 07:38 AM   #8
Sonnick's Avatar
LOL. TL-s cams are OEM as well
I believe the TL-s cams have a .3mm higher lift according to a post by thisaznboi from Paul, but the duration I'm not sure.
Old March 28th, 2012, 08:05 AM   #9
Sonnick's Avatar
I just wanted to make a correction. Paul you had started a thread about the comparison between the RL and TL-s cams. NVA-V6 had chimed in and said we can't use the 09 TL cams because of VCM. Well, the 09 TL does NOT have VCM. It does, however, have VTEC on both the intake and exhaust side. If the rocker assembly from the 09 TL fit, does anyone know if the cams would then work?
Old March 28th, 2012, 11:29 AM   #10
TrakCord
no idea but im sure the casting on the head would have to be different all together to accept the new rocker assembly, but dont quote me on that, but boy would that be some shiz if it workd, i think the power would be amazing!!
A good start would to check the part number on the accord heads just the cylinder heads and cross reference them with the 09 TL 3.7, hmmmmm ima get started on that and see where it takes me...
Old March 28th, 2012, 11:32 AM   #11
if it fits how will you control it?
Old March 28th, 2012, 11:35 AM   #12
SFL AV6
jiga21's Avatar
I'm about to say fk the tls cams, since day 1 I haven't felt jack from em
Old March 28th, 2012, 12:47 PM   #13
TrakCord
i think it is still controlled with the same solenoid. Its oil pressure that actually activates the VTEC system.
Sonnick likes this.
Old March 31st, 2012, 09:10 AM   #14
Archangel72's Avatar
Thats kinda been the case, some people say they felt a difference some people say they dont. I can only imagine that there has to be a suttle difference if they're hollow with higher lift. Does it sound any different when vtec kicks in?
Old March 31st, 2012, 11:00 AM   #15
SFL AV6
jiga21's Avatar
I think the people who changed just the tls cams and then drove felt difference. But people whom did more than just cams at 1 time it's hard to tell man. Vtec does sound more aggressive yes, but then again I can't honestly say its the cams.
Only real difference if 1 day someone stock or at most intake n catback exhaust dyno's before & after tls cams. Car also won't be too loud to hear vtec engagement difference either
