Concerns I am currently facing with my 05 AV6 6MT... - Honda Accord Forum : V6 Performance Accord Forums
Old April 6th, 2012, 06:09 PM   #1
J30 LSD
flylow2cre8's Avatar
Hello fellow enthusiats.
I don't know where to start as far as describing what I think may be a bad throttle sensor. I have noticed this for some time now and seems to happen more often than usual now-a-days.
Symptoms are evident after up shifting from a stop. From what I gathered, normal operation allows the throttle to hold for a second at the current engine speed once you shift into the next gear. Then, it the engine speed should drop about 500 rpms.
What I have been experiencing is a larger drop in engine speeds. Its more like 1000 rpms drops and the symptom effects the rest of the gears that way.
Because the engine drops speed quicker it doesn't help when engaging the clutch and thus jerks the car around due to unmatched tranny speeds.
Anyone knows what I am going thru here? Could it have anything to do with the trottle control? Thanks for the help
Old April 6th, 2012, 10:33 PM   #2
TrakCord
AccordingLO's Avatar
well considering no one has bothered to respond i think i will agree that it could be throttle control, try to find a friend or someone local to you that is on the forum or w.e. to do a throttle body swap and takes notes from there. I just did that test with Jiga and it showed a different reaction from my UNbored throttle body to his bored throttle body when we changed back and forth between the two on his car
AccordingLO is offline   Reply With Quote Quick reply to this message
Old April 6th, 2012, 11:39 PM   #3
SSM_AV6-6
NHB_AV6-6's Avatar
^^^ did it fix his CEL?
Old April 7th, 2012, 07:52 PM   #4
TrakCord
nope but at least we learned a bit...basically what i understood from him is driveability was better with the UNbored 09 TL throttle body than the bored one
