Intake/Exhaust Cones, Transitions, Reducers - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 1 Post By Rushzer0
  • 1 Post By qnzthg89
Old May 23rd, 2012, 09:23 AM   #1
Sorry dont know where to put this, but looking for Aluminum fabrication parts so I can make my intake and exhaust both from Aluminum. Yes Aluminum. Got to save weight somewhere.
Currently looking for a 3" to 4" cone and a 2.5 to 3" cone. I found and bought a 3-4 but it was cast and steel. So heavy
Also what do you guys think about muffler sizes and locations where they will fit. Currently looking at the Vibrant 3" Aluminum race muffler(Part # 12900). It has a 5" Outer Diameter and is 14" long tip to tip.
Next time i get my car on my friends lift im going to take some measurements to start mapping out total materials needed and what angles. Im going to pay closer attention to angles, because i missed that while making my CAI and well.. I have a shorty 4".
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old May 23rd, 2012, 09:43 AM   #2
I'd suggest contacting ASP. http://advancedstreetperformance.com/ They specialize in aluminum exhaust systems and I'm sure they could hook you up with what you need. Their customer service is also very good.
Atlas.46 likes this.
Rushzer0 is offline   Reply With Quote Quick reply to this message
Old May 24th, 2012, 02:15 AM   #3
Thanks. They even have the 3 bolt flange in aluminum. I have to contact them about getting some cones. Maybe get a couple of them and try different intake setups.
With cubano making the 2.5 to 3.5 exhaust , I'm debating going straight to that. But I don't have the tl-s cams, and the bigger tb and mag manifold
Old May 24th, 2012, 09:37 AM   #4
Verociousmotorsports.com
Old May 24th, 2012, 08:41 PM   #5
I bought a steal 1 from them I couldn't find any aluminum
04 Accord 6-6 Coupe
Old May 26th, 2012, 10:16 PM   #6
TrakCord
AccordingLO's Avatar
i dont have TL-S cams....i have stock J30A4 cams
Goin back to the Track!
AccordingLO is offline   Reply With Quote Quick reply to this message
Old May 28th, 2012, 01:07 AM   #7
i thought you did.
04 Accord 6-6 Coupe
Old May 28th, 2012, 08:30 AM   #8
I <3 My J30A4
qnzthg89's Avatar
Cubano has no internal work done. Showing the community that you dont need too go into this motor to achieve high hp. Big ups to him for that.
Sonnick likes this.
Old May 29th, 2012, 07:06 AM   #9
Sonnick's Avatar
Jiga has the TL-s cams, not Paul.
I hope Paul sees power from the '2535' setup, but I think once we have the large intake/3.7 TB/manifold combination/ported runners and full exhaust, that the head will start being the bottleneck. Paul, you have stock runners right? You should look into getting them ported and possibly the TL manifold outlets as well
Old May 29th, 2012, 08:43 AM   #10
What do the TL manifold outlets do/cost?
chipperf is offline   Reply With Quote Quick reply to this message
Old May 30th, 2012, 09:58 AM   #11
TrakCord
stock runners yup...after i figure out what the exhaust is doing ill dip into the engine, but maybe not even. the most ill do is TL-S cams then maybe bore out the T/B. Also do some experimenting again with the 4" intake length/megaphone etc...
