3.7 TL throttle body - Honda Accord Forum : V6 Performance Accord Forums
Like Tree7Likes
Old May 24th, 2012, 04:29 AM   #1
Sonnick's Avatar
Hayyyyyyyy. So I spoke with the guy that got me my TB and he said he can get more. If you guys want one, let me know and I will inform him. I will then either ask for your contact info or give you his.
I don't see any reason why the price would be different, but I paid $387 shipped. He said they are slightly used, but he makes sure they all work before he sends them out and cleans them as well.
I am on the way to the airport now and won't be back until Monday so I hope no one is in too big of a rush ha. If you guys want one, you can either let me know here or PM me, your choice. That's all for now
Instagram = j30_allmotor
Old May 24th, 2012, 06:46 AM   #2
How much was the manifold? What will the bore size be on the TB once it is bored out?
Old May 28th, 2012, 10:55 PM   #3
Sonnick's Avatar
The manifold was ~$385 shipped. Once bored the TB is 82mm at the intake and 72mm at the manifold. Although George at Maxbore said he tapered the inlet to 75mm. I'll check once I get it.
Old May 29th, 2012, 03:19 AM   #4
I'm really interested to see how the end result is of this. When do you plan on installing this?
Old May 29th, 2012, 06:57 AM   #5
Sonnick's Avatar
Well, my buddy has since decided he is going to build a wall (for his stereo) in his Tahoe instead of having it done by someone else. I'm probably gonna help him a bit with that and him with my manifold. I'm still hoping to have it installed in the next couple weeks as long as he isn't too busy with his stereo. Although I think he's going on vacation in 3 weeks, so I doubt he'd start it before then (it's gonna take awhile). Gonna be so sick when it's done! Looking for 160+ DBs to music
Old May 29th, 2012, 07:13 AM   #6
Nice. If you need any help with the manifold I can gladly help you. I've taken these off many times.
Old May 29th, 2012, 10:11 AM   #7
its pretty easy.
<- installed milled mdx spacer.
Old May 29th, 2012, 06:53 PM   #8
jbm
jbm's Avatar
if you ever need a hand. Im a PM away buddy....not to far either. ;-)
neOgenisis
tsx im, custom cai, obx header, test pipe, o2 sim, 2.5" custom exhaust, tl-s 20mm rsb. ralco underdrive pulleys & 75lbs of weigh reduction
comming soon: Custom cams
jbm is offline   Reply With Quote Quick reply to this message
Old May 30th, 2012, 06:55 AM   #9
Sonnick's Avatar
Thanks guys, I appreciate the offers! I spoke to my buddy yesterday and he's still in the process of ordering the subs/wire/batteries so we will have time to do it But I can't thank you guys enough for the offers
Old May 30th, 2012, 09:18 AM   #10
Originally Posted by Atlas.46 View Post
its pretty easy.
Thoughts on the MDX spacer?
chipperf is offline   Reply With Quote Quick reply to this message
Old May 31st, 2012, 01:21 AM   #11
What's the advantage of installing this throttle body? Would this work for a 3G 3.2 Base TL?
ArthurL is offline   Reply With Quote Quick reply to this message
Old May 31st, 2012, 06:48 AM   #12
Sonnick's Avatar
^ It's much larger on both the intake side and manifold side. It's 80mm (intake side) and 70mm on the manifold side as compared to I believe 64mm straight through for us (not sure if there is a taper). But it's a big difference. Bigger TB means more air and with our ECU's favoring the rich side, more power
Yes it will work for you, but unless you get the 3.7 TL manifold, you will need the P2R adapter. I will have dyno results, but it will be from stock ported manifold/stock TB/stock runners to:
3.7 TL manifold
3.7 TL bored TB (82mm/72mm)
Ported runners (thanks to thisaznboi)
Old May 31st, 2012, 06:58 AM   #13
Damn it I wish we had a bolt on option for the 1st gen J's. I'm going to be ordering the 3.7 mani soon though.
Old May 31st, 2012, 08:04 AM   #14
Sonnick's Avatar
^ Paul can make you a 80mm TB since you aren't DBW. He can also port the stock manifold to 80mm, or possibly port the 3.7 to 80 as well.
To be honest, the 'exiting ports' to the runners are the same size on the 3.7 manifold as our stock one as far as I know. The real difference seems to be the manifold neck being 76mm (from what I measured) and possibly runner length.
Old May 31st, 2012, 10:57 AM   #15
lose peak hp, but gain more torque from 3-6k.
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old June 3rd, 2012, 10:58 AM   #16
I'm interested sonnick, could u contact him for me.
Sonnick likes this.
Av6Fan is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2012, 05:01 PM   #17
Sonnick's Avatar
I'll talk to him tomorrow and keep you updated. Like I said they are slightly used, but look at my pics it's immaculate.
Old June 3rd, 2012, 05:33 PM   #18
Duck617's Avatar
I am also interested in both im/tb
Sonnick likes this.
Duck617 is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2012, 08:06 PM   #19
Yea I would like both if possible.
Old June 4th, 2012, 07:12 AM   #20
Sonnick's Avatar
I PM'd him on 8th Civic. He doesn't get the manifolds, only the throttle bodies. I ordered my manifold through a dealer.
Old June 4th, 2012, 07:40 AM   #21
Duck617's Avatar
how much did you pay for the mani, i will do the same. i really want this for my build, i am trying to hurt feelings with that thing
Old June 4th, 2012, 09:20 AM   #22
Sonnick's Avatar
Lol. The top cover and manifold were under just 400. I bought the EGR pipe as well which was like $45.
Old June 4th, 2012, 01:43 PM   #23
Sonnick's Avatar
PM's sent to those who expressed interest.
chuloav6 likes this.
Old June 6th, 2012, 12:21 PM   #24
whats an erg pipe for?
dingaling is offline   Reply With Quote Quick reply to this message
Old June 6th, 2012, 12:29 PM   #25
SSM_AV6-6
NHB_AV6-6's Avatar
Exhaust gas recirculation. Has something to do with relieving pressure in the crankcase by letting extra air escape back into the intake. I think the theory is that freely allowing it to escape causes vacuum which isnt good for the engine.
Old June 6th, 2012, 03:09 PM   #26
Mutha F ur Post Counts
A8TunedK24's Avatar
Send a message via AIM to A8TunedK24
Are the runners different on the 3.7? I've never looked at them but they should be larger then our runners. When I had my tl they didn't seem that much different although I never took them out. When I take on this project I want to do everything right the first time. With everything bored out, port n polished and tapered to specs with the 4in custom Cold air as well. Then hurt some peoples feelings on the flyway
DjKing07AV6 likes this.
A8TunedK24 is offline   Reply With Quote Quick reply to this message
Old June 6th, 2012, 05:07 PM   #27
Sonnick's Avatar
Lol. The runners are the same I believe. Considering my ported runners are 44mm and the stock ports on the manifold are 42mm, I'm going to assume they are the same 42mm stock.
Old June 11th, 2012, 07:42 AM   #28
Sonnick's Avatar
Anyone gotten their 3.7 TB yet? Or spoken to him?
Old June 11th, 2012, 08:20 AM   #29
Sonnick... does someone make an adapter plate to use the 3.7 TB on the stock maifold/3.5 mag manifold???
Old June 11th, 2012, 08:59 AM   #30
Sonnick's Avatar
^ Yes, P2R.
http://www.v6performance.net/forums/...e-accords.html
