issue with rear MDX camshaft - Honda Accord Forum : V6 Performance Accord Forums
Like Tree10Likes
Old May 26th, 2014, 01:47 PM   #1
So after rechecking my TL-S cylinder head I notice that the MDX camshaft does not sit flush in the journal and the sprocket rubs against the bolts sometimes.
I was wondering if anyone had this issue while doing the MDX camshaft?
The front camshaft banks fit no problem. It could be an isolated issue with my camshaft, unless it happen to someone else.
[URL=http://s101.photobucket.com/user/thisaznboi88/media/IMAG1029_zps1xwtmvxh.jpg.html]
Old May 26th, 2014, 07:27 PM   #2
I took everything apart and tried to reinstall it..same issue.
Also talked to my friend and he doesn't have any issue with his Mdx camshaft.. weird
Old May 26th, 2014, 08:07 PM   #3
accord325's Avatar
Sorry to hear this. Is the cam fully seated to one side ? The first photos also looks like the rocker is angle and not the cam, may be the photo. Did you try flipping or reversing how they are installed ?
Old May 26th, 2014, 08:43 PM   #4
Its not reversed I checked. Also swap the camshaft and the other one doesn't fit. The front camshaft fits like a glove.
Its hitting something metal, so it can't be the camshaft seals either.
being 1/8in off causes the sprocket to rub against the bolts behind it.
There no play in the camshaft either.
I swap the camshaft arm and it look like it help, but now I need to make sure the vtec mechanism is facing the right direction.
using a *HONDA manual*
Old May 26th, 2014, 10:06 PM   #5
Sleeper
NvrDwn's Avatar
Does your stock cam fit? If so, has anyone else with the tls heads put in mdx cams? If not maybe there is something different between the two that allows it to work on one and not the other?
PCDS, Custom 3" exhaust, 3" HFC, 4" CAI, Polished ZDX TB, P&P Intake Manifold, P&P Runners, deleted butterfly valve, UDP, deleted a/c and p/s, 160lbs lighter, and smaller tires.
1/8th mile 9.06 @ 82.31
8's here I come.
Old May 26th, 2014, 10:17 PM   #6
I don't have stock camshaft anymore. Either there is a clearance issue because of the design or my camshaft is F'd. Luke I said it's just the rear . The front doesn't have any issue
Old May 28th, 2014, 06:01 PM   #7
The Jester
I'll have to see if I still have my stock cams around or if I tossed them. Pretty sure I did...
Anyone willing to loan him a set of stockers to see if it's a head or cam issue?
Old May 28th, 2014, 06:33 PM   #8
accord325's Avatar
I have a complete set of J30A5 heads, let me see what I can do.
Old May 28th, 2014, 06:52 PM   #9
i have a set of stock camshafts under my desk in a box.
Old May 28th, 2014, 08:43 PM   #10
thanks for the help guys . I knew I could always count on all of you
Old May 28th, 2014, 08:57 PM   #11
accord325's Avatar
I slammed my finger between the head (the full weight of head) and my generator trying to get it out of the storage location. My finger is fuc$ed up. The heads are still assembled too, hopefully Zach can get you the specs. Sorry
Old May 28th, 2014, 09:02 PM   #12
Damn sorry about your finger bro, ;( feel better. Ice it and elavate it
Old May 28th, 2014, 09:25 PM   #13
Take a shot and forget about it. My choice of forget it shots is Everclear 190 proof.
oraclem19 likes this.
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old May 28th, 2014, 09:39 PM   #14
Ever clear hurt on the way down man. Lol
Old May 28th, 2014, 10:31 PM   #15
accord325's Avatar
No worries, had to log on on my phone so I could type. Couldn't bend it for about 30min, feeling coming back, lol.
...and I'm a Rum guy (Sailor Jerry) Everclear is like straight shine my pops makes!! LMAO. **** hurts more then my finger
thisaznboi88 likes this.
Old May 28th, 2014, 10:32 PM   #16
The Jester
Not as bad as that finger probably does. Smashed my hand quite a few times moving the heads around for porting and storage, those edges are sharp.
70-30 of rum and coke will do it for me, guess my 21 is showing since it isn't scotch or brandy or something.
Old May 28th, 2014, 10:54 PM   #17
Coke and henny on a good night. XX cuz I don't always drink beer,b it when I do I would like to finish it.lol
I am going to measure the bearings, looking at the camshaft again it looks like those area never touch the journsls. They have different wear patterns.
Note to self never buy used camshaft again
Old May 28th, 2014, 11:40 PM   #18
25/25/50 Everclear/Jack Daniels/Cherry Dr.Pepper....
190 proof isnt sold in PA, so i pick it up when im in NJ or MD... MD is pulling it and calling it a date rape drug...
Old May 29th, 2014, 01:56 AM   #19
The Jester
... It isn't?
Two conscious shots later and I wake up in bed next to a girl I have never met. And I hold my liquor well.
Going to need to try that mix though.
Also i'm still wondering how in the hell you even damage a camshaft. I can't imagine they would bend without snapping, and they should have the damn part numbers printed on there. Oil should prevent any excessive amount of wear on any part.
Old May 29th, 2014, 02:03 AM   #20
Originally Posted by oraclem19 View Post
... It isn't?
That mix is dangerous and its one that i came up with in college. My room mate started the mixing of Everclear and Jack. Sh!t we started pre mixing bottles and labeling them EverJack. But i was the one to find the mix that taste pretty good but sneaks up on you fast. 2 or 3 pints of that mix and your feeling great or done. Especially if you have been drinking already.
Back to camshafts. Which one is which? Just got distracted watching the new xmen movie.
04 Accord 6-6 Coupe
Old May 29th, 2014, 09:38 AM   #21
accord325's Avatar
^ Can u measure both ? He is having issues with the rear cam, if you can figure out which one that is
Old May 29th, 2014, 09:47 AM   #22
Sleeper
NvrDwn's Avatar
Random fact. I live in the moonshine capital of the world, and my wife's great grandfather was one of the original outlaw moonshiners.. Lol
accord325 likes this.
Old May 29th, 2014, 10:34 AM   #23
bozos_si's Avatar
did you get your cams? I have some I can send you too. I dont know which one is which but I can send both.
Old May 29th, 2014, 12:31 PM   #24
Didn't get it yet.
Old May 29th, 2014, 03:01 PM   #25
Woke up late after watching another movie last night... Will take some measurements tonight. Need to look for a tape measure...LOL
Old May 29th, 2014, 04:12 PM   #26
The Jester
If you guys have these on hand go ahead and ship them out, I haven't seen mine in like a month, but I also don't REMEMBER tssing them out... does not always mean that I didn't.
Old May 29th, 2014, 05:01 PM   #27
Wait Ken do you need another set of oem cams?
Old May 29th, 2014, 06:15 PM   #28
The Jester
^ At least for testing, make sure it is indeed his cams and not the block, or confusion on install.
Old May 29th, 2014, 06:46 PM   #29
I just need specs maybe later I will Need OEM camshaft for a get fit. Hopefully its me being stupid and the camshaft is not warp
Old May 29th, 2014, 08:45 PM   #30
bozos_si's Avatar
Let me know. I have had a set on ebay forever. LOL... If you need them I can send them.
Atlas.46 likes this.
