Hondata Flashpro J33 Dyno Tuning Results! - Honda Accord Forum : V6 Performance Accord Forums
Like Tree16Likes
Old May 27th, 2014, 10:38 AM   #1
J33 w/TL LSD 6 Speed
05AV6's Avatar
For those of you who don't know me I've been a long time member here and had Paul (NVA-AV6) Build a J33 for me as well as swap me to manual from automatic. I finally got around to getting Hondata installed and tuned this past weekend. Driveability is drastically better and the powerband is super smooth. Mods, numbers and graphs below!
Baseline Peak WHP: 250.6
Baseline Peak WTQ: 224.8
Tuned Peak WHP: 273.1
Tuned Peak WTQ: 234.3
-2005 Acura Tl 6 Speed (From Tl-Sport) w/LSD
-Ported/polished J30 heads.
-07 TL type S Cams
-Milled MDX Spacer
-Ported 6-speed Intake Manifold
-Acura MDX Crank and Rods
-Shaved heads to bump compression to 11:0-1
-Acura MDX rod bearings
-J30 block and pistons
-Custom pre-cat deletes
-Rv6-J Pipe
-Magnaflow high flow 3rd cat
-Greddy Evo Exhaust
-Injen CAI
-S2k Mugen Thermostat
-07 TL Type S ECU tuned via Evans Tuning using Hondata Flashpro.
-UR Underdrive Pulley
-AEM UEGO Wideband Sensor
-AEM Water/Coolant Temp Sensor
Sonnick and Scottwax like this.
Old May 27th, 2014, 10:59 AM   #2
WOW! thats a SOLID TUNE! GREAT JOB, MAN!
Old May 27th, 2014, 11:15 AM   #3
Sonnick's Avatar
Wow, those gain are ridiculous Kev! Car must feel like an absolute beast! Can't wait til we go to Island
Old May 27th, 2014, 12:03 PM   #4
Sleeper
NvrDwn's Avatar
Who tuned that!? That's by far the best gains from hondata that I've seen. What dyno? No offense but I would have expected more pretune. Reason I say this is I'd think there is a sold 40-50whp over a stock j30 in mods, and you have a j33.
Old May 27th, 2014, 12:08 PM   #5
Jeff Evans. Arguably, one of the best tuners in the country,
Old May 27th, 2014, 12:08 PM   #6
05AV6's Avatar
Jeff Evans at Evans Tuning in Mt Bethel, PA.
I was running a 3.2 TL Base map prior to the tune, so the car was definitely not as efficient as it should've been but I agree the gains were very impressive. The car drives completely different as well, must more responsive and substantially faster especially above 3500 RPM. The dyno was a Dyno Pack.
Sonnick and pa1nt13aller like this.
Old May 27th, 2014, 12:15 PM   #7
Sonnick's Avatar
Still can't get over those crazy gains. 23whp is unreal! Your car needed a tune BADLY, Kev haha. Ported heads with 11:1 CR/TL-s cams, etc. Maybe I missed it, which injectors are you running?
Old May 27th, 2014, 12:37 PM   #8
05AV6's Avatar
Stock Accord/TL, Jeff said I need more octane not more fuel.
Sonnick likes this.
Old May 27th, 2014, 12:39 PM   #9
are you running 91, 92, or 93?
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old May 27th, 2014, 01:22 PM   #10
The Jester
Water inj time.
Old May 27th, 2014, 02:50 PM   #11
I <3 My J30A4
qnzthg89's Avatar
Look at you Kevin!!! Those are some nice fvckn gains bro! Congrats.
Sonnick likes this.
Old May 27th, 2014, 04:00 PM   #12
05AV6's Avatar
93 Only. Not really any place to get 100 octane/race gas around here so that's out.
Old May 27th, 2014, 04:17 PM   #13
I hope u arent using stock tb.....
Old May 27th, 2014, 04:34 PM   #14
Thats some impressive gains. But somethings confusing me u said u swap from manu to auto but i thought lsd was only on manual tl's
2004av6 is offline   Reply With Quote Quick reply to this message
Old May 27th, 2014, 04:58 PM   #15
05AV6's Avatar
I listed them backwards, I'm an MT.
Yes I am running a stock TB for a whole slew of reasons which I am not getting into again. I could go larger in the future but for now I'll keep it as is.
Old May 27th, 2014, 06:15 PM   #16
Damn, look who's back from the dead lol. Congrats bro. Nice numbers. You should come by next month.
BTW are those base numbers from the AEM setup or with the Hondata TL 3.2 base map?
Old May 27th, 2014, 10:07 PM   #17
05AV6's Avatar
Hey Rich!! I always lurk I've just been super quiet with my wedding coming up next weekend. I'll try to get to the meet, but I get back from my honeymoon the night before so it'll be a last minute call!
The before numbers were the TL basemap.
I had a few dyno runs on the AEM FIC on a dyna pack under similar temp/humidity circumstances at wired in NJ with the same mods last fall and I only pulled 247 WHP and 222 WTQ which means the Hondata basemap was a better starting point.
Old May 27th, 2014, 10:08 PM   #18
accord325's Avatar
Nice numbers. Haven't read your issues with your TB but your car is set up for great numbers, just needs more air coming in.
Old May 27th, 2014, 10:21 PM   #19
05AV6's Avatar
Probably could lick up and additional 10 WHP with more air coming in. Jeff actually had the car run over 280 WHP but had to back it off as he was starting to get a slight ping so he backed it down a little to keep reliability and safety in mind
Sonnick and simione like this.
Old May 28th, 2014, 05:47 PM   #20
The Jester
At this point adding a $100-200 water and/or methanol kit to raise effective octane level, or a $100 Maxbore to get some minor air in there without all of the usual issues with a ZDX size TB or larger.
Just IMO, best bang for buck at this point to get closer to 300. Not counting retune. Impressive tuning gains as is.
Old May 28th, 2014, 06:36 PM   #21
Great results. Curious if upgraded intake parts would get you to 300hp or if the Frankenstein J33 has the same properties as the J36 regardless of air.
Old May 28th, 2014, 06:40 PM   #22
accord325's Avatar
He should be able to tune to the ZDX TB, hell my stock 3.0 ECU figured out my DTB IM. After my first calibration the tuner had throttle bucking/jerkiness worked out, and my Idle settled down.
Point A to B
NA.... Till I Spray
Old May 28th, 2014, 07:05 PM   #23
enjoying j36 luv
stillloco's Avatar
nice # kevin and enjoy your up coming wedding. hope to link up with you guys as soon as im back on the road again.
05AV6 and Sonnick like this.
stillloco is offline   Reply With Quote Quick reply to this message
Old May 28th, 2014, 10:36 PM   #24
The Jester
I thought there was still an air leak code and some idle issues even after tune?
In that case, ZDX or bust. As long as the bucking can be taken care of with Hondata, it's a worthwhile upgrade.
Wonder if his MDX spacer is ported as well, if the IM and runners are ported, the mdx should be as well. Thermal spacers on one, or both, sides may help some with ping and getting the intake temps lower if you don't go water.
Old May 28th, 2014, 11:01 PM   #25
accord325's Avatar
^ my 3.0 ECU had the DTB IM running perfect. Perfect idle, no bucking, no surging, no CEL. I put Flash pro and TL ECU on and it went crazy. My tuner made two calibrations and it was good again.
Old May 28th, 2014, 11:03 PM   #26
I get buckling in first gear. Makes me look like a jack ass in the paking stucture
Sonnick and accord325 like this.
Old May 28th, 2014, 11:15 PM   #27
accord325's Avatar
LMFAO, I hate that **** and felt like an idiot when it would happen.
Old May 29th, 2014, 01:49 AM   #28
The Jester
The only time it isn't bad to be an auto.
Heads up, messing around inside the TB gears to raise sensitivity and idle can cause bucking.
Old May 29th, 2014, 02:09 AM   #29
im running the ported runners, stock intake manifold with butterflies deleted, and zdx tb. Im not having any problems....
3 Day weekend this weekend. So im getting another set of coil packs, new spark plugs and a tune if everything goes right. It will be interesting to see how my numbers compare to yours. Since we have the same head builds, ported runners,and similar other things. Minus MDX spacer, intake manifold, tb. And me having a bigger CAI and exhaust.
Sonnick and jiga21 like this.
Old May 29th, 2014, 09:10 AM   #30
05AV6's Avatar
Do you have anything done to the bottom end of the motor? That def makes a world of difference.
