misshifted to 9k. - Honda Accord Forum : V6 Performance Accord Forums
Like Tree6Likes
  • 1 Post By Sonnick
  • 1 Post By six6
  • 1 Post By qaz393
  • 1 Post By 3.0UALLKNOW
  • 2 Post By qaz393
Old May 30th, 2014, 08:02 AM   #1
misshifted to 9k.
So i missed 5th and shifted to 3rd.
Engine still runs strong but there is a louder ticking noise.
I was planing on putting RL cams in. Do u think only some valves are bent. I can get j32a3 for around 500.
Im thinking of doing a head swap with new cams in as that would be a bit easier. What do u guys think?
Old May 30th, 2014, 10:39 AM   #2
Picked up a j32a3 for 500 canadian with approx 90k miles.
Does anyone know if i just straigh swap heads will the compression increase?
Old May 30th, 2014, 10:41 AM   #3
Just get a new block head swap will not inxrea compression you will need to mill it if you want increase cr. Your motor is gone once it's start clicking
Old May 30th, 2014, 10:50 AM   #4
Any facts to back up that bent valves = done motor?
Im just trying to get the car running and time to build a bottom end with that j32
Old May 30th, 2014, 11:48 AM   #5
Sonnick's Avatar
My motor ticks pretty loud......
RED_COUPE likes this.
Old May 30th, 2014, 11:53 AM   #6
Sleeper
NvrDwn's Avatar
There is no facts until you tear it down to see what was hurt. If metal got in the engine, get a used engine.
PCDS, Custom 3" exhaust, 3" HFC, 4" CAI, Polished ZDX TB, P&P Intake Manifold, P&P Runners, deleted butterfly valve, UDP, deleted a/c and p/s, 160lbs lighter, and smaller tires.
1/8th mile 9.06 @ 82.31
8's here I come.
Old May 30th, 2014, 12:04 PM   #7
frumaroll
six6's Avatar
I did the 3 to 2 shift on my 05 accord. Ended result was bent valves and missfires
3.0UALLKNOW likes this.
Old May 30th, 2014, 12:07 PM   #8
If you have bent valves, you'll have slightly lower than normal compression that will worsen the more you rev and drive the car, as well as misfire codes that will start popping up on idle.
You can do compression tests and wait for codes to show, but you most likely bent all of your exhaust valves.
Swap the J32A3 heads, do a valve adjustment, and you will be good to go.
Kenny AV6-6 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2014, 12:10 PM   #9
Mattyu broke a rocker when he misshifted ended up getting a new top end. At the very least you will need to take the head off and fix it. But the cost and labor is as much as that j32a3 motor
Old May 30th, 2014, 12:19 PM   #10
SFL AV6
jiga21's Avatar
If that was me op & you only hearing noise ? Before thinking about buying new head or motor just Dyno that bish...powerband will show if everything is ok
Old May 30th, 2014, 12:51 PM   #11
accord325's Avatar
You can have my engine
Old May 30th, 2014, 01:22 PM   #12
Ya the valves were quieter before mis shifting. My engine is coming on monday. The second camshaft is on backorder in canada. I guess once it comes in do the head swap asap.
On a side note i did my pcd yesterday and found one cat was melted. I did have a timing issue before i got the car with the timing belt skipping.
Old May 30th, 2014, 01:44 PM   #13
3.0UALLKNOW's Avatar
did that bent valves had like 5 misfires. Finally the car started shutting off in neutral. just got a new block and called it day
3.0UALLKNOW is offline   Reply With Quote Quick reply to this message
Old May 30th, 2014, 01:52 PM   #14
Damn. Mine still doesnt have any misfire code
Old May 30th, 2014, 09:22 PM   #15
maybe a valve adjustment?
Old May 31st, 2014, 12:29 AM   #16
Dont think its just a valve adjustment. Was quiet before i overrevved.
So in closing, im grabbing a tl head to bolt on for now. Probably will port and polish the head and maybe intake runner before i drop my RL cams into them.
Does anyone know if the 86 bore size will matter to the head which fits 86mm?? Also can i use a 86mm headgasket?
Sonnick and 3.0UALLKNOW like this.
Old May 31st, 2014, 12:58 AM   #17
Tl head the same size as the accord u less you are using a type-s. Use the gasket that matches the head. TLS use a different gasket. I have a TLS head in my closet.
Old May 31st, 2014, 08:39 PM   #18
The Jester
Clicking isn't always bad, however if it is after a missed shift it usually means a myriad of bent valves. Mine sounds like a damn Harley right now, however that's due to bad valve timing on one of the back valves I believe.
Plus having a car that sounds like a Harley at idle is probably as close as I will get to having a heavy cammed car on the road sound.
Old June 10th, 2014, 09:02 PM   #19
I dissassembled a tl and a rl block. The head gasket is the same. Is it confirmed okay to run the 89mm rl gaslet on a 86mm bore block?
Old June 10th, 2014, 09:31 PM   #20
they are the same dome size on the head side, but look at the coolant jacket hole. The RL are much larger then the J32.
Old June 10th, 2014, 09:53 PM   #21
Okay so rl head on j30a4 = rl hg and rl head on j32a3 is rl head gasket as well?
Old June 10th, 2014, 10:09 PM   #22
I'd your using the RL head on any block use the RL head gasket or else it will leak. Plan and simple
