Home made Hondata harness :P - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By thisaznboi88
Old May 31st, 2014, 11:58 AM   #1
I like to thank Zach (atlas.46) for hooking it up with the boomslang harness. The boomslang harness is a lot more fragile than the AEM harness when it comes to the pin snapping between the wires and the connector in the rear.
To depin I used a sewing needle and pressed it in to the top hole.
end results
I also have some extra wiring that has the pin on them if people need it to swap their OEM OBD2 connector. The hondata one just plain sucks. It like a weak little girl
Painted the ECU since the ECU cover was really scratched up and I had extra wrinkle black paint.
simione likes this.
Old May 31st, 2014, 12:05 PM   #2
I can Haz cranberry orange cookie? J/k. Props! How long did it take you ?
Old May 31st, 2014, 12:17 PM   #3
Took a month of research and comparing notes with people on acurazine and Zach. 3 hours to depin all the pins cuz I couldn't figure it out. 2 hours to play match and insert.
I wasn't sure if Zach did the whole harness or not. So I took it all part.
I still don't know where the a.c pressure line thingy goes lol. Its a mystery on my notes and on Zach's also
And yes you can have a cookie. ;p and thanks again for the injector harness for the rdx
My next task is to replace my obd2 connector data thingy. The hondata hi-lo wires still keep backing out even after I super glued it.can't believe that POS wire was 50 bucks. It only 2 dollars in wire, 15 cent in pins, and maybe 5-10 bucks for that green connector thingy that no one can buy.
Old May 31st, 2014, 12:27 PM   #4
holy crap! Nice work! Hell of a lot cheaper than buying the Hondata harness! Crazy to think that I was one of the first ones to have had hondata, and I never had issues with the obd connector. I don't think Sonnick has, either. You're welcome!
Old May 31st, 2014, 01:05 PM   #5
pa1nt13aller's Avatar
now reward yourself with that cookie
Old May 31st, 2014, 05:36 PM   #6
alright honda is stupid or something. They made the OBD2 connector a non-replacable item. Need to buy the whole engine harness just to replace the port. WTF!
Old May 31st, 2014, 06:03 PM   #7
alright honda is stupid or something. They made the obd2 connector a non-replacable item. Need to buy the whole engine harness just to replace the port. Wtf!
junkyard!
Old May 31st, 2014, 06:06 PM   #8
^ yay!! Need to find a pick and pull. Probably make a drive out yo Ohio
Old June 2nd, 2014, 12:12 AM   #9
yeah... once i got on a roll depinning it i didnt stop till all plugs were done... and then realized i didnt have to do it all. I was like crap..
Also after doing it all i didnt want to risk it not working so i decided to just buy the hondata harness.
Old June 2nd, 2014, 06:22 AM   #10
It was easier to just depin it all rather than search for the wire
