Does this injector mod apply to us?? - Honda Accord Forum : V6 Performance Accord Forums
Old June 1st, 2014, 09:35 PM   #1
Looks like a free 270cc to 490cc injector mod. No need to change clips and stuff.
Modded OEM 270cc injectors = 490cc - Club RSX Message Board
I am getting a long block tomorrow and i could do this with the 6 injectors that come with them.
Old June 1st, 2014, 10:58 PM   #2
The Jester
It looks like it would. However I wouldn't do this unless you have a separate injector control system like an AEM or Hondata. 310cc injectors already start to cause rich issues, much less 490
Old June 1st, 2014, 11:00 PM   #3
Of course. But the savings of 68 for rdx injector and 8 bucks for tc clips is roughly 75x6=450
Old June 1st, 2014, 11:36 PM   #4
The Jester
If you're going FI, or have a fuel controller, it'll be worth it. However the rdx injectors do have an even better spray pattern, so doing this to one of them would be the ultimate mod
http://www.xproductionz.com/forum/showthread.php?t=3769
Old June 2nd, 2014, 06:26 AM   #5
Its 3xx on eBay for rdx and clips. Your going to get crappy atomization to gain more flow. For N/A better atomization helps a lot.
Old June 2nd, 2014, 07:45 AM   #6
SFL AV6
jiga21's Avatar
Rdx injectors have been tweaked to 750cc easily. Another reason why I got em
Old June 2nd, 2014, 08:22 AM   #7
true. but free mod for temp before i get rdx is worth thinking of.
obviously i wont be using upgraded injectors till my hondata is set up.
by they way, the link i sent, the guy sent the injectors to rc eng and they said that flow pattern was good and turned to excellent. how bad can "good" or "excellent" be.
Old June 2nd, 2014, 10:23 AM   #8
Flow pattern is not atomization. It just sprays good
Old June 2nd, 2014, 10:48 AM   #9
accord325's Avatar
I personally wouldn't do it unless you know you need more fuel. I have worked heads, RL cams and DTB IM and lost power when going into the 11's with AFR. I am currently at 12.8 AFR at WOT on RDX injectors and have tons of injector left.
It an easy mod even with engine in the car, if you need it.
Old June 2nd, 2014, 10:36 PM   #10
The Jester
Honestly, I don't think the screens are going to modify flow pattern much. It's like using the shower setting vs the cone setting on a garden hose. one has less pressure and more streams(but bigger globs) or one stream and a cone pattern to spread.
I think the non screened might actually work better.
Old June 6th, 2014, 10:41 PM   #11
Are the RL or TLS injector a direct drop in in terms of the connector? I will be getting hondata soon
Old June 6th, 2014, 10:42 PM   #12
No they are not they use the same plugs as the rdx. I have a set also along with a fully built TLS head in my closet
Old June 6th, 2014, 11:23 PM   #13
whats in ur fully built head?
Old June 7th, 2014, 12:37 AM   #14
Stuff lol
Old June 7th, 2014, 06:36 AM   #15
No tb motorworks cams spring valve retainer no care.
Old June 7th, 2014, 06:26 PM   #16
^ be careful what you wish for. lol
