Any of these parts work with our cars? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By Ibreak4change
Old June 5th, 2014, 07:36 AM   #1
2008 acura tl 36k!!! parting out
It's a 2008 acura tl.don't know anything about it yet or if he still has it, but could any of the parts be used in a 2003 accord auto v6?
Thanks!!!
Sent from my VK810 4G using Tapatalk
jagrave is offline   Reply With Quote Quick reply to this message
Old June 5th, 2014, 08:03 AM   #2
the ECU for hondata comes to mind
Old June 5th, 2014, 08:20 AM   #3
So the motor would work? If so, is it better to start with it or our motor? Thank you for the reply.: )
Old June 5th, 2014, 08:22 AM   #4
Sleeper
NvrDwn's Avatar
The motor can work
PCDS, Custom 3" exhaust, 3" HFC, 4" CAI, Polished ZDX TB, P&P Intake Manifold, P&P Runners, deleted butterfly valve, UDP, deleted a/c and p/s, 160lbs lighter, and smaller tires.
1/8th mile 9.06 @ 82.31
8's here I come.
Old June 5th, 2014, 08:22 AM   #5
I am not 100% sure if the 07-08 to motor will work. I just know the ecu would be good for hondata flashpro
Old June 5th, 2014, 09:27 AM   #6
Originally Posted by NvrDwn View Post
The motor can work
Wants $800 for just the motor. It's an auto. Better off putting that money into my motor, or buy this one? Or looking for a 3.5?
Sent from my SM-G900V using Tapatalk
Old June 5th, 2014, 09:51 AM   #7
Buy the motor and ask for the ecu with it
Old June 5th, 2014, 10:02 AM   #8
Sleeper
NvrDwn's Avatar
Actually now that I remember I think something did change on the 07-08 tl's. They may not bolt up to our trans. Even so, it could work regardless. Just have to spend more money.
8's here I come.
Old June 5th, 2014, 12:23 PM   #9
Block bolt pattern changed on 07-08 TL base and Type-S.
Atlas.46 likes this.
Ibreak4change is offline   Reply With Quote Quick reply to this message
Old June 5th, 2014, 03:34 PM   #10
what he said?
Also Hondata says to use the 07 auto base ecu. Not the 08 auto base for some reason.
Old June 5th, 2014, 06:28 PM   #11
Sleeper
NvrDwn's Avatar
Different bellhousing should fix that correct
8's here I come.
Old June 5th, 2014, 10:17 PM   #12
Yeah you could always change the clutch housing but it's kind of hard to tell from the parts diagram what all comes with it. Probably would have to get some new bearings also. The rest of the guts should transfer over.
Old June 5th, 2014, 10:31 PM   #13
Yeah I wish Honda never changed the bolt pattern or crank sensor location on the newer J series engines. If that were the case I would just go pull a 3.7 07+ Mdx motor out of the junk yard, apply bolt-ons plus hondata and be done. Luckily there are still a lot of cross compatible parts across many years of J series like the intake manifolds and throttle bodies.
Old June 5th, 2014, 11:36 PM   #14
SFL AV6
jiga21's Avatar
Direct fit just need the transmission bell housing from 07-08 transmission to bolt up too 03-07 transmission of accord. Much better motor with more displacement, higher compression, better cooling efficiency. I would buy that motor in heartbeat for $800 36k
