Does the j32a3 auto bolt onto a 6 mt tranny j30a4 - Honda Accord Forum : V6 Performance Accord Forums
Old June 6th, 2014, 03:02 PM   #1
Any idea or confirmation?
Also the j35a8 block will not work with out tranny right?
Old June 6th, 2014, 03:09 PM   #2
Sleeper
NvrDwn's Avatar
First question I can't answer. The second is correct. You cannot.
Also, no need for two threads. You can put multiple question into one thread. Keeps thread clutter down.
Old June 6th, 2014, 09:50 PM   #3
It must be a J32A3 from a 04-06 TL.
Ibreak4change is offline   Reply With Quote Quick reply to this message
Old June 6th, 2014, 10:22 PM   #4
accord325's Avatar
^ that's correct. Bell housing is the same, shouldn't matter auto or MT
Old June 6th, 2014, 10:35 PM   #5
Sweet. Time to start wrenching a 3.5 into the j32a3 block.
Old June 7th, 2014, 12:58 AM   #6
The Jester
... What? combine the two blocks?
Do you mean making a j33 or something else?
Old June 7th, 2014, 06:37 AM   #7
J35 build.
J32a3 block with j35 type s piston con and crank
Old June 7th, 2014, 08:12 AM   #8
Why do a j35 do a j36 or j37 Noob
J37 stuff are much better use rlx piston and the crank from a polit.
On a side note j32 block doesn't have oil squirter not sure if u can transfer one over from a j35 or j37
Old June 7th, 2014, 10:06 AM   #9
Because cost. Im doing rl cam and a whole engine cost 600.
If i get a pilot crank dont i need con rods too?
Im building super budget
Old June 7th, 2014, 11:00 AM   #10
Alright. Hit up Yungone for the j35 crank if you already bought a j32 motor
Old June 7th, 2014, 11:18 AM   #11
accord325's Avatar
I suggest MDX cams 07'-09'. Not feeling these RL cams. May not be the right can profile for my J30, IDK. TLs and MDX re basically identical, TLS have shown improvement.
Point A to B
NA.... Till I Spray
