qaz393 budget build thread - Honda Accord Forum : V6 Performance Accord Forums
Like Tree9Likes
Old June 20th, 2014, 11:51 PM   #1
qaz393 budget beater ecobox build thread
Tomorrow is dyno day.
Bought the car for 1700.
So far the work that has been done are new timing belt and tensioner.
Mods so far are:
Intake tube delete with stock airbox
Tb coolant bypass
3.5 rl j35a8 intake manifold with butterfly delete
P2r manifold gasket + spacer
Rv6 pcd v3 and xlr8 v2 jpipe
Stock catback with one muffler removed.
Ur underdrive pulley
Xlr8 75a mounts
Tl lower trans mount
Hybrid racing shift bushing
Isc TL 14/10 race coilover
Tl-s front and rear sway bar
skunk2 front camber arm
ingalls rear camber kit
235/45r17 re11a on 17x8.5 rpf1
Minor weight reduction of trunk, roofliner and hoodliner.
Goal for tomorrow is to put down 200whp
I currently have bent valves and waiting for headgasket to do head swap.
Clutch is also problematic at high rpm with engagement point changing only when i getbinto high rev but does not slip
Car is also burning around 1 quart per fillup
Got my 3.7 tl manifold and zdx tb on order.
Old June 21st, 2014, 12:34 AM   #2
Sonnick's Avatar
Why are you putting the car on the dyno with all these issues?
Old June 21st, 2014, 12:49 AM   #3
Baseline and cheap dynoday
Old June 21st, 2014, 09:31 AM   #4
Results. 216whp
Old June 21st, 2014, 09:25 PM   #5
I noticed my torque dies off pretty early around 5k. Should i suspect bent exhaust valve or too tight of lash?
Old June 21st, 2014, 09:33 PM   #6
Damn it does as soon as the car goes into vtec
Old June 21st, 2014, 09:42 PM   #7
Just waiting on delray to ship me head gasket then I'll have pnp runners pnp heads and rl cams
Old June 21st, 2014, 09:44 PM   #8
Also have a zdx tb n 3.7 tl manifold in there
Old June 21st, 2014, 09:51 PM   #9
I lied. My car actually did 199.1 first pull but couldnt go home like that. Took some water to the tb manifold and runner. Gained 17whp with cooler air. Heat soak sucks and i already have the p2r thermal gasket
Old June 21st, 2014, 10:07 PM   #10
Stage 2 build in process. Will put motor in when my clutch goes. Hopefully my clutch problem rivht now is only my slave which is also being shipped by delray
Old June 21st, 2014, 10:07 PM   #11
This is why I run water meth
Old June 21st, 2014, 10:08 PM   #12
Where do u inject it??
Old June 21st, 2014, 10:16 PM   #13
Throught the manifold behind the Tb
Old June 21st, 2014, 10:18 PM   #14
How are u controlling the meth?
Old June 21st, 2014, 10:20 PM   #15
I have a control unit. The kit was from aqua mist
Old June 21st, 2014, 10:50 PM   #16
Sonnick's Avatar
While the trans is out you should so the FD....
RED_COUPE likes this.
Old June 21st, 2014, 10:52 PM   #17
Hopefully my clutch will last that long. Gonna be 3k+ just for flywheel clutch lsd/tranny and 3.8 fd
Thats double of price of my car
Old June 21st, 2014, 11:15 PM   #18
Gotta pay to play
Old June 23rd, 2014, 08:04 AM   #19
Sonnick's Avatar
Not if you do the OEM clutch/fly.
Instagram = j30_allmotor
Old June 23rd, 2014, 11:44 AM   #20
SFL AV6
jiga21's Avatar
Water meth sounds like a plan
Sonnick and Atlas.46 like this.
Old June 23rd, 2014, 04:20 PM   #21
Too bad p2r doesnt make a tb spacer for the 3.7 tb/manifold or else that be the easiest way to spray water meth there.....
Old June 23rd, 2014, 05:08 PM   #22
accord325's Avatar
^ u sure ?
Old June 23rd, 2014, 06:33 PM   #23
Ugh yeah they do, but does it have the 1\8npt port?
Old June 23rd, 2014, 09:09 PM   #24
The Jester
DIY, kit is usually less than 30 and requires all of a drill.
Old June 24th, 2014, 12:41 PM   #25
just did a compression test and my car did around 200psi on all cylinder. is this number right???
Old June 24th, 2014, 01:51 PM   #26
Yup all 200 is good
I have the die and tap kit. Make sure to get a good set if u want to tap yourself. My bits are diamond coated
Old June 24th, 2014, 01:53 PM   #27
Sad thing is that i wont be putting that j35 build in.
Looking to make my motor rev high after i do gead swap. Im thinking of ordering kms valvetrain and maybe a better oil pump as well. Goal is to have a reliable 8k build for now
Old June 25th, 2014, 01:54 PM   #28
RED_COUPE's Avatar
Do you have a flash pro? Those numbers seem very low for what you have done to the vehicle, bent valve or not...
Xenocron Tuning Solutions -
Chipped ECUs, Injectors, Fuel Pump, Harnesses, DIY Parts, Widebands, and More
Hondata, eCtune, Neptune, Haltech, Precision Turbo, Injector Dynamics
RED_COUPE is offline   Reply With Quote Quick reply to this message
Old June 25th, 2014, 02:21 PM   #29
Stovk ecu
Old June 26th, 2014, 10:06 PM   #30
Guys what crank/conrod bearings and piston rings should i get??? Oem from delray or rockauto aftermarket??
