gen8 vs gen7 runners comparison - Honda Accord Forum : V6 Performance Accord Forums
Like Tree5Likes
  • 4 Post By Sonnick
  • 1 Post By thisaznboi88
Old June 22nd, 2014, 11:54 AM   #1
I got a set of port and polished gasket matched gen 7 accord runners and a gen8 accord stock runners
Here are some of the changes
Gen 7
&mpt=[CACHEBUSTER]">
Gen 8
&mpt=[CACHEBUSTER]">&mpt=[CACHEBUSTER]">
Side by side &mpt=[CACHEBUSTER]">
Old June 22nd, 2014, 12:02 PM   #2
So if you are using the new magnesium manifold chances are you need to port the manifold to have it gasket match. You will need a 1-2mm increase.
Now why did I post this? Well I been getting a lot of request for PnP for people who wanted to gasket match the runners to the 3.7L manifold. But I am sure that the manifold also needs to be Ported to match the increase diameter of the runners. If anyone wants to measure the opening of the manifold to confirm this please post pictures
Using p2r gasket as reference probably not the best idea since they do deform over time &mpt=[CACHEBUSTER]">
Also don't ask if the gen 8 runners fit the gen7 runner!!! Just look at it!
Last note. Do not gasket match the side going to the head unless u also plan to match the head. I have gasket match TLS heads so it was okay for me to do so beacuase it presevers the flow and will not increase turbulence due to a lip on the head side
Old June 22nd, 2014, 05:23 PM   #3
accord325's Avatar
Did you measure the IM side down the row, meaning port #1,#2, then 3? Ill have to recheck mine but every runner set I have measured has had two identical and one slightly larger. Check it out.
FYI, unless you are swapping J37 heads as I did, u should never need to use these runners. I do see what you are saying thought. 8th Gen IM have smaller ports then the 7th gen runners. Very detailed !
Old June 22nd, 2014, 05:31 PM   #4
I did do a 1,2,3 but there too many pictures. And yes there was an odd ball one.
I also started port and polishing them. I can see why the gen8 accord made 15whp after port and polish runners. The size on the IM is restricting the flow.
Old June 22nd, 2014, 06:45 PM   #5
Sonnick's Avatar
Can I use 8G runners on my 7G?
Old June 22nd, 2014, 07:37 PM   #6
^ hurry up and put the tranney I. Your car first
Sonnick likes this.
