Accord V6 2006 5AT - 75 shot Nitrous - Honda Accord Forum : V6 Performance Accord Forums
Like Tree6Likes
  • 1 Post By Gorpo
  • 1 Post By RED_COUPE
  • 1 Post By accord325
  • 2 Post By Gorpo
  • 1 Post By Atlas.46
Old June 24th, 2014, 09:51 AM   #1
Gorpo's Avatar
Hi,
I want to share with you my last upgrade: 75 shot Nitrous!
Before:
4" Home made CAI with Velocity Stack
RV6 PCDs
ATLP V2 Jpipe
CAT delete
Custom 2.5" catback exhaust
Redline Racing Lightweight ATF
After:
75 shot single fogger Nitrous
Techrace Progressive Nitrous Controller and RPM Window (3000rpm to 6000rpm)
Dynojet
NA: 221.8whp/260.2N-m
Nitrous: 288.0whp/362.8N-m
&mpt=[CACHEBUSTER]">
Gtech Times: (Only one test after Nitrous with a bad launch)
NA: 0-100kmh -6.905s and 0-400mts - 14.908s @ 157.28kmh
Nitrous: 0-100kmh -6.384s and 0-400mts - 14.541s @ 160.88kmh
My Video Compilation:
Accord 2006 V6 5AT 75 shot Nitrous - YouTube
Hope you enjoy!
Sonnick likes this.
Gorpo is offline   Reply With Quote Quick reply to this message
Old June 24th, 2014, 11:59 AM   #2
SFL AV6
jiga21's Avatar
Very nice numbers with nitrous...must be nice! Can't imagine how much more power you would squeeze out tuned with hondata
Old June 24th, 2014, 12:54 PM   #3
pa1nt13aller's Avatar
you should post a video!
Old June 24th, 2014, 05:50 PM   #4
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
If I may make suggestion:
I would not recommend manually shifting the selector like that...just let the tranny and ECU do it's thing. You'll wearout the clutch packs fast like that.
Add a warmer to the bottle to keep your pressure constant for better fuel & N2o mix. That will help reduce an "issue" with using it at WOT.
do they make a remote temp and pressure gauge for it? might be cool to always see how the special sauce is doing.
otherwise, nice power from a decent shot.
What size N2o jet did you go with on that dyno run?
Old June 24th, 2014, 06:05 PM   #5
Mr. Detail
Scottwax's Avatar
Not so sure about that, manually shifting usually means you get full line pressure so the clutch packs should slip less.
Old June 24th, 2014, 08:21 PM   #6
The Jester
Personally, I felt it was faster to manual shift, however my times did not reflect that as long as my trans started in 1st and not 2nd.
And It did wear out my trans rather fast.
Old June 25th, 2014, 04:56 AM   #7
Gorpo's Avatar
Fuel: 27
Nitrous: 51
But looking at the O2 sensor voltage in ultragauge (last bottom one), it was rich, so I updated the nitrous jets to 54 after this dyno runs, now I am running better with this jets combination
Old June 25th, 2014, 10:19 AM   #8
accord325's Avatar
What Brand you have ? You Dry or Wet Shot ?
Old June 25th, 2014, 01:18 PM   #9
RED_COUPE's Avatar
Good stuff! But say good bye to your trans!
Sonnick likes this.
Xenocron Tuning Solutions -
Chipped ECUs, Injectors, Fuel Pump, Harnesses, DIY Parts, Widebands, and More
Hondata, eCtune, Neptune, Haltech, Precision Turbo, Injector Dynamics
RED_COUPE is offline   Reply With Quote Quick reply to this message
Old June 25th, 2014, 02:46 PM   #10
Gorpo's Avatar
Wet shot, powertech is a Brazilian company, but uses NOS fogger and jets.
Old June 25th, 2014, 03:53 PM   #11
How many miles/km are on your car?
Are you going to proactively replace the 3rd & 4th gear pressure sensors?
How many drain & refills did you do with Redline ATF? I believe it takes 3 to get ~80% new fluid.
Old June 25th, 2014, 04:08 PM   #12
Gorpo's Avatar
Near 70k milles, I did not change the pressure sensors yet.
I made a 3x3 ATF change, the first 2 with the OEM Honda and the last one with the Redline, but I feel the difference in the gearbox changes.
Old June 26th, 2014, 03:50 AM   #13
The Jester
Any intention of using a larger shot?
Old June 26th, 2014, 04:56 AM   #14
Gorpo's Avatar
Not now, because I am having problems with traction on 1st gear with nitrous and donīt want to destroy my tranny so fast!
Old June 26th, 2014, 09:45 AM   #15
accord325's Avatar
^ I think 75 wet is very safe, 75 dry is safe also. I wouldn't go 100+ unless you change plugs and cut some time. People say knock sensor will do the time cut, but yeah, only after knock is detected and you have rods poking out the engine block. .
Old June 26th, 2014, 09:51 PM   #16
The Jester
Hmm, trying to figure out how to do a 25 shot and 50 shot progressive... Or does a progressive controller really add nox progressively?
Also, direct inject addon to the fuel injector spot?
Nitrous Nozzles & Jets (scroll down)
Wonder if this works on our cars
Old June 26th, 2014, 10:34 PM   #17
accord325's Avatar
^ guy on Azine direct shot a 200 shot, made 500hp I think
Old June 26th, 2014, 11:34 PM   #18
nickisepik's Avatar
My buddy has a 50 shot he's willing to sell me, I believe wet shot. I have the same vehicle except it's the 6mt. Currently no modifications besides 2.5 custom piping behind the stock cats and headers and short ram intake. Could I just install without needing to reprogram the ecu? Could I do manual spray safely?
nickisepik is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2014, 02:57 AM   #19
nickisepik's Avatar
any chance we could get a parts list of everything you needed to spray?
Old July 23rd, 2014, 12:27 PM   #20
accord325's Avatar
^ Check out Zex Wet universal kit - 82021.
Dry kit wont work on our cars because it calls for a Vacuum line from the Fuel Regulator, which is in our gas tank.
nickisepik likes this.
Old August 21st, 2014, 01:39 AM   #21
Banned
i had a 90 shot dry untuned in my accord v6 6MT i know is carzy but i just did it for fun and the car was pulling hard man about 360-370 whp around there
Accord_J30A5 is offline   Reply With Quote Quick reply to this message
Old August 21st, 2014, 06:52 AM   #22
Carpe Diem
ikethegreat's Avatar
Old August 21st, 2014, 09:48 AM   #23
accord325's Avatar
Another Nestor ?? LMAO
Old August 21st, 2014, 02:47 PM   #24
no that is Nestor.
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old September 10th, 2014, 05:31 PM   #25
Gorpo's Avatar
Update!
Installed the Unorthodox Racing Lightweight Pulley and changed the size of the jets to 54/27 (nos/gas) and raised the RPM nitrous window to 6500rpm
The base jump from 221.8whp to 228.4whp with the Pulley
The Nitrous jump from 288.0whp to 313.7whp, now it is a like a 100 shot NOS.
Stock Pulley and Lightweight Pulley:
post images
Without nitrous and with 100 shot:
upload images free
75 shot 6000rpm and 100 shot 6500rpm
screen grab
Sonnick and Atlas.46 like this.
Old September 10th, 2014, 05:41 PM   #26
Have you been recording air fuel ratio during these dyno runs?
Old September 10th, 2014, 06:36 PM   #27
accord325's Avatar
How the hell are your NA torque numbers so high ?? 228 whp, 266 wtq on a V6 AT ? Impressive numbers, just baffling as hell
Old September 10th, 2014, 07:49 PM   #28
its newton meters so 288nm ~ 212 ft/lb (wtq)
accord325 likes this.
04 Accord 6-6 Coupe
Old September 10th, 2014, 07:54 PM   #29
Gorpo's Avatar
No, just checked the ultragauge lambda voltage, it was fine, little in the rich side.
Old September 10th, 2014, 09:05 PM   #30
accord325's Avatar
^ 11.3-11.8 is optimal AFR. 12 + is getting pretty lean
